The following workflows describe how to configure Skylar One and PowerFlow to work with the "Ansible" SyncPack.
Configuring Skylar One
- Enable the Ansible event policies
- Edit the Ansible run book actions
- Enable the Ansible run book automations
Configuring PowerFlow
- Align the configuration object and configure the Ansible PowerFlow applications
The following topics cover how to set up your Skylar One instance to work with the "Ansible" SyncPack.
Enabling the Ansible Event Policies
The "Ansible Automation" PowerPack includes the following event policies that you can enable to trigger the events detected by the applications included in the "Ansible" SyncPack:
- "Ansible-Command"
- "Ansible-Tower"
To enable the event policies:
- In Skylar One, go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic user interface).
- Click the check boxes for the "Ansible-Command" and "Ansible-Tower" event policies. A row of buttons appear at the top of the list.
- Click . The Status for both policies is updated to "Enabled".
You will need to create a SOAP/XML credential so that the action policies included in the "Ansible Automation" PowerPack can access your PowerFlow system.
- In Skylar One, go to the Credentials page (Manage > Credentials).
- Click and select Create SOAP/XML Credential. The Create Credential window appears.
- Take note of the Skylar One-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the run book actions included in the PowerPack, below.
Editing the Ansible Run Book Actions
The "Ansible Automation" PowerPack includes the following run book action policies:
- Ansible: Command (triggers the "Call Playbook from Ansible CLI" application in PowerFlow)
- Ansible: Tower (triggers the "Call Playbook from Ansible Tower" application in PowerFlow)
These action policies use the "Run Integration Service Application" action type to trigger the corresponding PowerFlow application that collects data from Ansible. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- In Skylar One, go to the Actions page (Registry > Run Book > Actions).
- Locate the action policy that you want to use ("Ansible: Command" or "Ansible: Tower"), and then click its wrench icon (
Enabling the Ansible Run Book Automations
The "Ansible Automation" PowerPack includes the following run book automation policies that you will need to enable, depending on which Ansible application you are monitoring:
- "Ansible:Command"
- "Ansible:Tower"
These policies update the Skylar One event with the state of the associated Ansible Command or Ansible Tower.
- In Skylar One, go to the Automation page (Registry > Run Book > Automation).
- Locate the "Ansible:Command" run book automation policy and click its wrench icon (
- Repeat steps 2-4 for the "Ansible:Tower" run book automation policy.
The following topics cover how to set up your PowerFlow instance to work with the "Ansible" SyncPack.
For this SyncPack, you should make a copy of the "Sample Ansible Configuration" configuration object, which is the sample configuration file that was installed with the "Ansible" SyncPack.
The "Sample Ansible Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Ansible settings.
To create a configuration object based on the "Sample Ansible Configuration" configuration object:
Click the button (
) for the "Sample Ansible Configuration" configuration object and select Edit. The Configuration pane appears.
- sl1_host. Type the hostname or IP address of the Skylar One system the alerts will synchronize with.
- ansible_url. Enter the URL for your Ansible system.
- ansible_username. Type the username for your Ansible system.
- ansible_password. Type the password for your Ansible system.
- template_id. Type the Ansible Tower template ID. This field is only required if you are monitoring an Ansible Tower.
- host_name. Type the host name for your Ansible system.
- playbook. Type the name of your Ansible playbook.
- inventory_id. Type the Ansible Tower inventory ID. This field is only required if you are monitoring an Ansible Tower.
- credential_id. Type the Ansible Tower credential ID. This field is only required if you are monitoring an Ansible Tower.
- ssh_username. Type your SSH username.
- ssh_password. Type your SSH password.
- host_name_status. Toggle on (blue) to enter the host name status from the event details.
- ssh_pem_status. Toggle on (blue) to enter the SSH status from the event details.
- ssh_pem. Enter the RSA key for SSH connection and type "\n" before and after your RSA key.
- ssh_host. Type your SSH host name.
- add_template. Toggle the JSON editor to define a message for the description field in the Skylar One event.
For more information about the Ansible terms and concepts in this section, see the Ansible documentation.
In PowerFlow, you will need to align the "Ansible" SyncPack applications with the relevant configuration object, and, if needed, update any other fields on the Configuration pane for the applications.
- On the Applications page of the PowerFlow user interface, open one of the Ansible PowerFlow applications and click . The Configurations pane for that application appears.
If you want to use the following PowerFlow applications, you must schedule them. ScienceLogic recommends that you schedule the following PowerFlow applications:
- "Ansible Tower Job Status Update": Every five minutes
- "Clear Skylar One Events": Every 10 minutes
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple Skylar One instances or multiple Ansible instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or Ansible instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Ansible instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
