Using the PowerFlow SyncPack SDK
The PowerFlow SyncPack Software Development Kit (SDK) contains a functional environment for developing and testing SyncPacks, without the need for a full PowerFlow System. The SDK includes auto-completion and other features to help you quickly create a SyncPack for PowerFlow.
This section describes how to set up and use the PowerFlow SyncPack SDK to create custom SyncPacks. This chapter also covers how you can use the PowerFlow SyncPack Pytest Fixtures to set up unit test coverage of individual steps.
The PowerFlow SyncPack SDK is part of the Skylar One Studio suite of tools.
The SyncPack SDK is meant to be used by developers with expertise in Python development.
The SDK is not included in a PowerFlow system by default. To download the SDK files, you need to complete the following procedure to set up the SDK.
Setting up the PowerFlow SyncPack SDK
To set up the PowerFlow SyncPack SDK:
  1. Log in to the SL container registry:
    docker login registry.scilo.tools
    You can find the credentials for this step by logging in to the Harbor user interface with the user name and password that you use for the ScienceLogic Support site. In the Harbor user interface, click your user name in the top right and select User Profile. From the User Profile dialog, copy the username and CLI secret (key) you will need to authenticate with when running the docker login command. For more information, see Obtaining Your Harbor Credentials.
  2. Install the Cookiecutter repository and set up the SyncPack directory structure.
  3. Open the newly created directory for SyncPacks using VS Code or PyCharm, following the steps below.
VS Code
The generated package contains a VS Code Dev Container. For more information about Dev Containers, see https://code.visualstudio.com/docs/devcontainers/containers.
When you open the newly created directory for SyncPacks directory with VS Code, you will get a prompt to open the workspace within the container.
To open the new directory with VS Code:
  1. Install the dev containers add-on.
  2. Install the Python tools and add-on recommended by VS Code.
  3. After installing the Cookiecutter repository, open the newly created directory for SyncPacks in VS Code. The .devcontainer folder should be detected, and you should be prompted to re-open the workspace in the container.
  4. Click Yes.
  5. If you are not prompted, or if you miss the prompt, open the command pallet (Ctrl+Shift+P) and run the following command:
    Remote-Containers: Reopen in Container
    If you need any additional SyncPacks or packages to be available, run a pip install them into your container. Be sure to add those SyncPacks or packages to your dependencies.
  6. Verify that the container is running by running docker ps.
  7. To make sure that the SyncPack workspace was correctly set up, run the "DummyStep" test script located in tests/steps/test_DummyStep.py by running pytest https://code.visualstudio.com/docs/python/testing.
  8. You can now start using the SDK to create steps and applications for the new SyncPack. Auto-completion and documentation is enabled for all of the PowerFlow classes and methods.
For a list of additional VS Code tasks, see the Tasks section in the README.md file at the SyncPacks Cookiecutter GitHub page. For a list of available snippets, see the Snippets section in the README.md file at the SyncPacks Cookiecutter GitHub page.
PyCharm Professional Edition
The Cookiecutter generated package includes PyCharm configuration settings to improve the process for developing SyncPacks.
To use PyCharm:
  1. After installing the Cookiecutter repository, open the newly created directory for SyncPacks in PyCharm.
    If you are working with more than one SyncPack repository, ScienceLogic recommends that you open the root directory where the needed repositories are located.
  2. Right-click the SyncPack directory, select Mark Directory, and select Sources Root.
  3. Configure the docker-compose.yml file located in .pycharm_devcontainer as a Docker Compose Remote Python interpreter. Follow the instructions in the PyCharm official documentation: https://www.jetbrains.com/help/pycharm/using-docker-compose-as-a-remote-interpreter.html#docker-compose-remote.
  4. Select the interpreter that you created in step 3 as the default for your workspace.
  5. Check the test profile for the tests/steps/test_DummyStep.py to make sure that the Python Interpreter is set to the Docker Compose Interpreter configured above. Follow the instructions in PyCharm Run Test Documentation to set the corresponding interpreter: https://www.jetbrains.com/help/pycharm/creating-run-debug-configuration-for-tests.html.
  6. To make sure that the SyncPack workspace was correctly set up, run the "DummyStep" test script located in tests/steps/test_DummyStep.py, using the steps in the PyCharm Run Tests documentation: https://www.jetbrains.com/help/pycharm/performing-tests.html#test-mutliprocessing.
  7. You can now start using the SDK to create steps and applications for the new SyncPack. Auto-completion and documentation is enabled for all of the PowerFlow classes and methods.
For advanced settings, see Advanced Setup.
The PowerFlow pytest fixtures allows for unit test coverage of individual steps. The pytest fixtures are included in the PowerFlow SyncPack SDK.
You can access the fixtures by running pytest --fixtures in the devcontainer that contains the following fixtures:
  • test_is_conf. The consistent configuration object for Step Run tests.
  • patched_logger. The patched logging instance that allows for assert tests and output to the console.
  • content_manager. The generic content manager fixture, which can be patched for further testing needs.
  • syncpack_step_runner. Runs a PowerFlow step.
  • powerflow_content_manager. Provides a Content Manager instance that can be asserted against.
These fixtures allow for unit test coverage of a wide variety of steps, including steps that use data from previous steps, read or write from the cache, make API calls, and require patching. The fixtures also let you assert against log messages.
Enabling Unit Tests for PowerFlow Steps
To enable unit tests using the pytest fixtures:
  1. Choose the step to test. Be sure to understand the goal of the step, which step parameters are needed, and what the execute method is doing. For more information, see Creating a Step.
  2. In the tests directory, add a file called test_{step_name}.
  3. Copy the content of tests/steps/test_DummyStep.py into the new test step file.
  4. Rename the test function to test_{step_name}.
  5. Edit the following test function arguments:
    • stepdict. The step definition as it would be defined in an application.
      • name and file. Use the name of your step.
      • syncpack. Uses the current SyncPack by default. No changes are needed.
      • custom step parameters. Parameters in your step.
    • in_data. Input data that helps to simulate the data received from the previous step.
    • out_data. Output data that represents the data saved for the next step using the save_data_for_next_step method. This is useful to compare the result generated by the step with the expected(out_data) data.
  6. Parametrize any other argument the test step may need. The following is a simple example of how to mock API responses using the library requests_mock and a mock_data argument.
    from requests_mock import Mocker
    def test_GetREST(
        step_dict, in_data, mock_data, out_data, syncpack_step_runner):
        req_mock = kwargs.get("req_mock")
        req_mock.get(
            f"https://snow.test/api/x_sclo_scilogic/v1/sciencelogic/file_systems?
    region=pytest&sysparm_limit={step_dict['chunk_size']}",
            mock_data,
        syncpack_step_runner.data_in = in_data
        data = syncpack_step_runner.run(step_dict)
        assert data == out_data
  7. Use any of the pytest fixtures as needed inside your step test code. The following fixture is included by default as a test argument, and it should be always part of the step’s test arguments:
    • syncpack_step_runner. Helps execute the step defined in the stepdict argument.
  8. Run the unit tests using pytest, based on your development environment:
Using the iscli Tool
You can use the iscli tool with VS Code and PyCharm Professional Edition
Using iscli with VS Code
After the SDK is up and running, you can open a bash terminal and execute iscli commands to build and upload SyncPacks as mentioned in the iscli section.
VS Code tasks created by the Cookiecutter tool can also be used to execute some iscli commands. For more information, see the Tasks section in the README.md file at the SyncPacks Cookiecutter GitHub page.
For Linux environments, you will need to uncomment the line "runArgs": ["--network", "host"] in the .devcontainer/devcontainer.json file, so that SyncPacks can be published to remote systems using iscli, and dependencies can be installed from Pypi.
Using iscli with PyCharm
PyCharm currently does not support keeping a container alive as VS Code does.
To be able to open a terminal and execute commands inside the SDK container:
  1. Using the Docker tool window that PyCharm offers, start a container by selecting Services > Docker > right-click on the running container > Create terminal.
  2. When the terminal is up and running, you can execute bash commands in it, including iscli commands. For more information, see https://www.jetbrains.com/help/pycharm/docker.html#interacting-with-containers.
The following image is an example of a Docker profile in Linux:
You can also perform this action using the following Docker command:
docker run -it --volume /home/syncpack_test/:/workspace/syncpack_test --name devcontainer_iscli --user=1000 --rm registry.scilo.tools/sciencelogic/pf-syncpack-devcontainer:2.4.1 /bin/bash
Use --network host for Linux environments, if needed. Be sure the user UUID matches your local user.
When the container is running, you can execute iscli commands inside the container.
Advanced Setup
This section explains how a developer can use third-party online or offline dependencies, and how to load more than one SyncPack directory into only one workspace.
Load Dependencies into a SyncPack Workspace
When developing SyncPacks, most of the time external dependencies are needed, such as ScienceLogic SyncPacks or third-person Python libraries.
Be sure to update the "requires_dist" array in the meta.json file with the dependencies needed. For more information about how to edit this file, see SyncPack Properties.
Advanced Setup: VS Code
To address offline dependencies (.whl files):
  1. Copy all of the necessary .whl files, including ScienceLogic SyncPacks, into the .offline_dependencies directory.
  2. Run the following task to install the SyncPack using those offline dependencies:
    PF: Install SP - Offline Dependencies
To address dependencies from a PowerFlow System
  1. Choose a PowerFlow system that has the ScienceLogic SyncPacks that are needed as dependencies for this SyncPack. You will need the corresponding credentials for that PowerFlow system.
  2. Run the following task to install the SyncPack using packages from the PowerFlow system:
    PF: Install SP - Dependencies from PF(devpi)
If dependencies from a PowerFlow system need to be used along with offline dependencies, run the following task PF: Install SP - Dependencies from PF(devpi) + Offline dependencies.
Advanced Setup: PyCharm
To address offline dependencies (.whl files), copy all of the needed .whl files (including ScienceLogic SyncPacks) into the .offline_dependencies directory.
To address dependencies from a PowerFlow System:
  1. Add the PF System to the /syncpack_name/.pycharm_devcontainer/pip.conf file:
    [global]
    timeout = 0
    retries = 0
    extra-index-url = https://isadmin:password@PF_HOST:3141/isadmin/syncpacks
    trusted-host = PF_HOST
  2. When the file is configured, configure the Docker Compose file as a Remote Python Interpreter if it was not done already: https://www.jetbrains.com/help/pycharm/using-docker-compose-as-a-remote-interpreter.html#docker-compose-remote.
  3. Rebuild the image if needed, follow PyCharm documentation if needed: https://www.jetbrains.com/help/pycharm/using-docker-compose-as-a-remote-interpreter.html#tw.
  4. Run the tests normally. The environment should have the necessary dependencies installed.
Opening Multiple SyncPack Directories on One Workspace
This section describes how to set multiple SyncPack directories in only one workspace to make it easier to update SyncPacks that share dependencies.
Multiple Directories: VS Code
  1. Select a SyncPack directory as primary.
  2. Edit the .devcontainer/devcontainer.json file by adding the root directory /home/username/pf_syncpacks_workspace as a bind volume:
    "mounts": [
    "source=/home/username/pf_syncpacks_workspace,target=/workspaces,type=bind"
  3. Edit the /.vscode/pf-syncpack.code-workspace file and add the secondary SyncPack paths.
    	"folders": [
    			"path": ".."
    			"path": "/workspaces/pf_syncpack_test"
    			"path": "/workspaces/pf_syncpack_other"
  4. Open the SyncPack directory in VS Code selecting the option Reopen in the container as explained in the Cookiecutter README.md file: https://github.com/ScienceLogic/is_syncpack_cookiecutter#devcontainer. Rebuild the container, if necessary.
  5. Go to the primary SyncPack file .vscode/pf_syncpacks_workspace.code-workspace and select Open Workspace. This should be done after the DevContainer was started successfully in step 4.
  6. Install all the secondary SyncPacks using any of the tasks to install Syncpacks PF: Install SP ... . This enables the tests to run.
For more information, see the VS Code multi-root workspaces documentation: https://code.visualstudio.com/docs/editor/workspaces#_multiroot-workspaces.
Multiple Directories: PyCharm
  1. Open the root SyncPack directory mentioned above at /home/username/pf_syncpacks_workspace.
  2. Make sure that all of the SyncPack directories are located in that directory. PyCharm will automatically recognize any new SyncPack located in the root directory
  3. Right-click each SyncPack directory, select Mark Directory, and select Sources Root.
  4. When all of the SyncPacks are marked as sources, the tests for all of them can run normally.
Using Templates to Create Steps and Application JSON Files
This section describes how to use templates to create new applications, steps, and step test files. When creating many new files, the use of templates can help speed up the process.
Using Templates: VS Code
Because VS Code does not have a way of configuring templates, you can configure something similar using snippets. The Cookiecutter includes three snippets that can help you quickly add an application, step, and step test code into a file.
To use the Cookiecutter snippets:
  1. Create the corresponding empty file: app.json or StepName.py.
  2. Start writing the prefix of any of the snippets: pfapp or pfstep or pfsteptest, and when VS Code suggests the expected snippet to use, press Enter.
  3. The cursor will be positioned in the property that needs to be edited, press tab to go to the next property to edit.
For more information, see the Cookiecutter README.md file: https://github.com/ScienceLogic/is_syncpack_cookiecutter#devcontainer.
To create your custom snippet:
  1. Create a new file in the .vscode directory called {SnippetName}.code-snippets.
  2. Copy the needed code into the VS Code Snippet generator: https://snippet-generator.app/. Use variables if needed; check the current snippets the SyncPack has for reference.
  3. Copy the resulting .JSON code into the {SnippetName}.code-snippets file.
Using Templates: PyCharm
PyCharm lets you create file templates. When creating many new files, the use of templates can help speed up the process.
The Cookiecutter includes a zip file with three templates in /.pycharm_devcontainer/settings.zip with basic information to create a new step, application, and step test.
  1. To import the zip file, see https://www.jetbrains.com/help/resharper/Templates__Managing_Templates__Importing_and_Exporting_Templates.html#cb67c1bc.
  2. To use the templates, select New and select any of the three templates.
To create your custom template with PyCharm:
  1. Create a File Template: https://www.jetbrains.com/help/pycharm/using-file-and-code-templates.html#create-new-template.
  2. Copy the corresponding code inside the template as follows, define custom templates variables if needed: https://www.jetbrains.com/help/pycharm/file-template-variables.html#custom_template_variables.
  3. Save the template: https://www.jetbrains.com/help/pycharm/using-file-and-code-templates.html#save-file-as-template.
Frequently Asked Questions
Can I remove the dummy steps and applications created by the Cookiecutter tool?
Yes. The only purpose of those is to be examples.
Should git be initialized in the newly created SyncPack directory?
It is not needed, but it is recommended to push and save the changes to the corresponding code repository.
You can also do this with VS Code tasks. For a list of VS Code tasks, see the Tasks section in the README.md file at the SyncPacks Cookiecutter GitHub page.
Should I use the SDK within a PowerFlow system ?
No. You should only use the SDK in a local development environment, and not in a PowerFlow system.
