Introduction to the Infoblox: Inventory SyncPack
This section describes how you can use the "Infoblox: Inventory" SyncPack to synchronize IP addresses and devices between Infoblox and Skylar One. The integration is bidirectional, from Skylar One to Infoblox. The SyncPack can raise an event in Skylar One if an IP address mismatch occurs between a device monitored in Skylar One and Infoblox.
This SyncPack uses the "Infoblox: Workflow Configuration" PowerPack.
The "Infoblox: Inventory" SyncPack lets you synchronize IP addresses and devices between Infoblox and Skylar One. The integration is bidirectional, from Skylar One to Infoblox. The SyncPack can also raise an event in Skylar One if an IP address mismatch occurs between a device monitored in Skylar One and Infoblox.
This SyncPack includes the following integrations between Infoblox and Skylar One:
  • Use Skylar One to discover Infoblox devices. Queries Infoblox for existing IP addresses and if an IP address does not exist in Skylar One, a discovery session will be triggered and the device will be added to Skylar One.
  • Look for recently added Skylar One devices. Queries Skylar One via discovery session for recently added devices. If a device does not exist in Infoblox, the IP address will be added to Infoblox.
  • Check for mismatched IP addresses for synced devices. Queries both Infoblox and Skylar One for matching device names. If a device in Skylar One and Infoblox has the same name but different IP addresses, an event will be generated in Skylar One.
  • Update Infoblox device IDs. Queries both Infoblox and Skylar One for existing devices in Skylar One and matching IP addresses in Infoblox. Skylar One devices that match an IP address in Infoblox are assigned an Infoblox ID in a custom attribute in Skylar One.
For more information about how to configure these applications, see Configuring Applications for the Infoblox: Inventory SyncPack.
Contents of this SyncPack
This section lists the contents of the "Infoblox: Inventory" SyncPack.
PowerFlow Applications
  • Get Device List From Infoblox and Add To Skylar One. This application queries Infoblox for existing IP addresses and if an IP address does not exist in Skylar One, a discovery session will be triggered and the device will be added to Skylar One.
  • Get Device List From Skylar One Add To Infoblox. This application queries Skylar One via discovery session for recently added devices. If a device does not exist in Infoblox, the IP address will be added to Infoblox.
  • Get Mismatched IP List. This application queries both Infoblox and Skylar One for matching device names. If a device in Skylar One and Infoblox has the same name but different IP addresses, an event will be generated in Skylar One.
  • Update Infoblox Id. This application queries both Infoblox and Skylar One for existing devices in Skylar One and matching IP addresses in Infoblox. Skylar One devices that match an IP address in Infoblox are assigned an Infoblox ID in a custom attribute in Skylar One.
Configuration Object
  • Infoblox Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to Skylar One, including the host, username, and password
  • Details for connecting to Infoblox, including the URL, username, and password
  • Details for adding Skylar One devices to Infoblox, including zone name, time period, and custom attribute
  • Details for adding Infoblox IP addresses to Skylar One, including organization ID, credentials, device group, device template, ports, and time period
Steps
  • Active Discovery Session
  • Add Data To Custom Attribute
  • Add new Device To Infoblox
  • Checking Infoblox Record
  • Checking Infoblox Id
  • Create Custom Attribute
  • Create Discovery Session
  • Create Skylar One Alert
  • Get Skylar One Device List
  • Get Custom Attribute
  • Get Device Details
  • Get Discovery Session Log
  • Get Infoblox Device Reference Id
  • Get Infoblox Host List
  • Get Infoblox Host Records
  • Get IP List From Infoblox
  • Get Skylar One All Devices List
  • Get Skylar One Device Details
