Configuring Applications for the Jenkins SyncPack
This section describes how to set up the run book automations in Skylar One and how to configure the PowerFlow applications in the "JenkinsSyncPack.
The following workflows describe how to configure Skylar One and PowerFlow to work with the "Jenkins" SyncPack.
Configuring Skylar One
  1. Enable the Jenkins event policies
  2. Create a SOAP/XML credential to access PowerFlow
  3. Edit the Jenkins run book actions
  4. Enable the Jenkins run book automations
Configuring PowerFlow
  1. Create and align a PowerFlow configuration object
  2. Configure the Jenkins PowerFlow applications
The following topics cover how to set up your Skylar One instance to work with the "Jenkins" SyncPack.
Enabling the Jenkins Event Policies
The "Jenkins AutomationsPowerPack includes 11 event policies that you can enable to trigger the events detected by the applications included in the"JenkinsSyncPack and its associated automation action policy.
To enable the event policies:
  1. Go to the Event Policies page (Events > Event Policies, or Registry > Events > Event Manager in the classic user interface).
  2. Click the check boxes for all of the "Jenkins" event policies. A row of buttons appear at the top of the list.
  3. Click Enable. The Status for all 11 policies is updated to "Enabled".
You will need to create a SOAP/XML credential in Skylar One so that the action policies included in the "Jenkins Automations" PowerPack can access your PowerFlow system. The PowerPack includes the "PowerFlow Jenkins" sample credential, which you can edit for use with your PowerFlow system.
  2. Locate the "PowerFlow Jenkins" sample credential, click its Actions icon (), and select Duplicate. A copy of the credential, called "PowerFlow Jenkins copy" appears.
Editing the Jenkins Run Book Actions
The "Jenkins Automations" PowerPack includes eleven following run book action policies. These action policies use the "Run Integration Service Application" action type to trigger the corresponding PowerFlow application that collects data from Ansible. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
  2. Locate the action policy that you want to use, and then click its wrench icon (). The Editing Action page appears.
Enabling the Jenkins Run Book Automations
The "Jenkins AutomationsPowerPack includes eleven run book automation policies that you will need to enable. These policies update the Skylar One event with the state of the associated Jenkins job. When a node is offline, a failure occurs, or a major event is detected in Jenkins, Skylar One creates an event and updates the associated event with relevant job details.
  2. Locate a"Jenkins" automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Jenkins automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
  2. Repeat steps 2-4 for the remaining "Jenkins" run book automation policies.
Jenkins Node: Healthy Jenkins: Healthy Event Jenkins: Event Update
Jenkins Node: Major Jenkins: Major Event Jenkins: Alert
Jenkins: Job Pending Jenkins: Pending Event Jenkins: Event Update
Jenkins: Job Failure Jenkins: Major Event Jenkins: Alert
Jenkins: Healthy Jenkins: Healthy Event Jenkins: Event Update
Jenkins: Trigger Jenkins: Trigger Jenkins: Trigger
Jenkins: Trigger Healthy Jenkins: Healthy Event Jenkins: Event Update
Jenkins: Trigger Job Pending Jenkins: Pending Event Jenkins: Job Pending State
Jenkins: Pipeline Job Failure Jenkins: Major Event Jenkins: Alert
Jenkins: Pipeline Job Healthy Jenkins: Healthy Event Jenkins: Event Update
Jenkins: Pipeline Job Pending Jenkins: Pending Event Jenkins: Job Pending State
The following topics cover how to set up your PowerFlow instance to work with the "Jenkins" SyncPack.
Creating and a Configuration Object
For this SyncPack, you should make a copy of the "Base Jenkins Configuration" configuration object, which is the sample configuration file that was installed with the Jenkins SyncPack.
The "Base Jenkins Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Jenkins settings.
To create a configuration object based on the "Base Jenkins Configuration" configuration object:
  2. Click the Actions button () for the "Base Jenkins Configuration" configuration object and select Edit. The Configuration pane appears.
  • sl1_host. Type the hostname or IP address of the Skylar One system the alerts will synchronize with.
  • jenkins_url. Enter the URL for your Jenkins system.
  • jenkins_username. Type the username for your Jenkins system.
  • jenkins_password. Type the password for your Jenkins system.
  • job_name. Type the name for your Jenkins job.
  • receiver_mail. Type the email address that you want to receive updates on Skylar One events and your Jenkins jobs.
  • sender_mail. Type the email address that you want updates on Skylar One events and your Jenkins jobs to send from.
  • sender_mail_password. Type the password for the sender email address that you entered.
  • mailserver. Type the server for your sender email.
  • mailserverport. Type the port for your sender email.
  • node_device_class_id. Type the device class ID for your Jenkins instance.
  • job_device_class_id. Type the device class ID for your Jenkins job.
  • guid_node_major_event. Enter the GUID of the Skylar One event policy.
  • collector_group_id. Type the collector group ID for your Jenkins instance.
  • device_id. Type the device ID for your Jenkins instance.
  • guid_job_major_event. Enter the GUID of the Skylar One event policy.
  • guid_job_trigger_event. Enter the GUID of the Skylar One event policy.
  • guid_pipeline_job_major_event Enter the GUID of the Skylar One event policy.
With this SyncPack, you can create Skylar One events based on Jenkins jobs. You will need to align the Jenkins SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
  1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure (). The Configurations pane for that application appears.
  2. Repeat this process for the other PowerFlow applications.
To trigger the applications in the SyncPack, you must schedule the PowerFlow applications that are included in the SyncPack.
To create a schedule:
When either multiple Skylar One instances or multiple Jenkins instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or Jenkins instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Jenkins instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
