Prerequisites for the Jira Service Management SyncPack
- The latest "Jira Service Management Automation Policies" PowerPack
- The latest "SL1 Notifications Base" SyncPack
- Administrator access to Jira
- An IT Service Management Jira project to integrate with SL1
For the latest System Requirements, see the SL1 PowerFlow SyncPack Release Notes.
PowerFlow | Jira API | Any | TCP 443 | Jira API Access |
Downloading and Installing the Jira Service Management SyncPack
Downloading the SyncPack
- Click the PowerPacks & SyncPacks. tab and select
- In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
- On the SyncPack version that you want to install, and select Show File Details. The Release File Details page appears. tab, click the down arrow next to the
- Click the SyncPack. button to download the
Importing the SyncPack
- On the SyncPacks page (
Installing the SyncPack
If you do not see the SyncPack that you want to install, click the Filter icon (
) appears.
Installing the Jira Service Management Automation Policies PowerPack
The "Jira Service Management Automation Policies" PowerPack includes automation policies and action policies that bidirectionally sync issues and events in Jira and SL1.
The " Jira Service Management Automation Policies" PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the SL1 Platform Release Notes.
Ensure that you are running version 12.1.2 or later of SL1 before installing this PowerPack. For details on upgrading SL1, see the relevant SL1 Platform Release Notes.
