The following workflows describe how to configure Skylar One, Jira, and PowerFlow to work with the "Jira Service Management" SyncPack.
Configuring Skylar One
- Edit the Jira Service Management run book actions
- Enable the Jira Service Management run book automations
Configuring Jira
- Create an API token
- Locate the account ID
- Locate the request type ID
- Locating the severity custom ID
- Configuring a Skylar One event URL custom field
Configuring PowerFlow
- Create a PowerFlow configuration object
- Align the configuration object and configure the PowerFlow applications
The following topics cover how to set up your Skylar One instance to work with the "Jira Service Management" SyncPack.
You will need to create a SOAP/XML credential so that the action policies included in the "Jira Service Management Automation Policies" PowerPack can access your PowerFlow system. The PowerPack includes the "PowerFlow Jira" sample credential, which you can use as a template for the SOAP/XML credential.
- In Skylar One, go to the Credentials page (Manage > Credentials).
- Locate the "PowerFlow Jira" sample credential, then click its icon (
) and select Duplicate. A copy of the credential, called "PowerFlow Jira copy" appears.
- Take note of the Skylar One-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the run book actions included in the PowerPack, below.
Editing the Jira Service Management Run Book Actions
The "Jira Service Management Automation Policies" PowerPack includes two action policies that use the "Run Integration Service Application" action type to trigger the PowerFlow application that sends and receives data to Jira. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- In Skylar One, go to the Actions page (Registry > Run Book > Actions).
Enabling the Jira Service Management Run Book Automations
The "Jira Service Management Automation Policies" PowerPack includes the following run book automation policies that you will need to enable:
- "Jira: Create Issue"
- "Jira: Timeline Event"
These policies update the Jira issue with the state of the associated Skylar One event. When an event is first detected in Skylar One, an issue is created in Jira. When an event is acknowledged in Skylar One, a comment is added to the associated Jira incident.
| Jira: Create Issue | All events | Jira: Alert |
| Jira: Timeline Event | All events | Jira: Create Timeline Event |
- In Skylar One, go to the Automation page (Registry > Run Book > Automation).
- Locate a Jira automation policy and click its wrench icon (
- Repeat steps 2-4 for other "Jira" run book automation policy.
Configuring Jira
The following topics cover how to set up your Jira instance to work with the "Jira Service Management" SyncPack.
Creating an API Token
To let PowerFlow communicate with Jira, you must create a Jira API token and enter it in your PowerFlow configuration object.
To create an API token in Jira:
- In Jira, click on your profile icon and select Account Settings.
- Navigate to the API Tokens page (Security > Create and manage API tokens).
- Click to generate a new API token.
- Make a note of the API token so that you can use it in your PowerFlow configuration object.
Locating the Account ID
To let PowerFlow to make changes to Jira, you must enter a Jira account ID in your PowerFlow configuration object.
To locate your Jira account type ID:
- Click on your profile icon and select Account.
- The page reloads, and you can find the account ID at the end of the URL.
- Make a note of the ID so that you can use it in your PowerFlow configuration object.
Locating the Request Type ID
To let PowerFlow make changes to Jira, you must enter a Jira request type ID for the type of request you want in your PowerFlow configuration object.
To locate a Jira incident request type ID:
- Select the Jira project you want to use.
- Navigate to the Incidents page (Project Settings > Request Types > Incidents).
- Select the request type (for example, "Report a system problem"). The page reloads and you can find the request type ID at the end of the URL.
Locating the Severity Custom ID
To let PowerFlow identify the severity of a Jira issue, you must enter a severity custom ID in your PowerFlow configuration object.
To locate your severity custom ID in Jira:
- Navigate to the Screens page (Project Settings > Screens).
- If you have not already added the Severity field to your issues list, select any of the screens to expand its details and select the Edit issue link. You can then add the Severity issue by selecting Severity in the Select Field drop down at the bottom of the Issuespage.
- On the Screens page, select any of the screens to expand its details and select the Create Issue link.
- Navigate to the Field Configurations page (Fields > Field configurations).
- Select Default Field Configuration.
- Locate the Severity field and click Edit.
- The page reloads and you can find the severity custom ID at the end of the URL.
Configuring a Skylar One Event URL Custom Field
To let PowerFlow make changes to Jira, you must enter a Skylar One event URL field ID in your configuration object.
To configure a Skylar One event URL custom field in Jira:
- Select the Jira Service Management: Change Management Screen Scheme window to expand its details and select the Create Issue link.
- Navigate to the Custom Fields page (Fields > Custom fields).
- Click and select URL Field.
- Supply a value in the required field and click .
- The page reloads and you can find the custom field ID in the URL.
- Repeat these steps for the Jira Service Manage: Incident Management Screen Scheme window.
The following topics cover how to set up your PowerFlow instance to work with the "Jira Service Management" SyncPack.
For this SyncPack, you should make a copy of the "Jira ITSM Configuration" configuration object, which is the sample configuration file that was installed with the Jira Service Management SyncPack.
The "Jira ITSM Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Jira settings.
To create a configuration object based on the "Jira ITSM Configuration" configuration object:
Click the button (
) for the "Jira ITSM" configuration object and select Edit. The Configuration pane appears.
- sl1_host. Type the hostname or IP address of the Skylar One system the alerts will synchronize with.
- jira_username. Type the username for your Jira system.
- jira_password. Type the password for your Jira system.
- jira_token. Enter a Jira API token.
- jira_url. Type the URL for your Jira system.
- project_key. Type the project key for the Jira project you want to be used when making the API request.
- populate_external_url. Type whether to add an Jira ticket URL to the corresponding Skylar One event. The default value is 'enabled'.
- account_id. Enter the Jira account ID.
- issue_type. Type the type of ticket you want to be created in Jira when an event is triggered in Skylar One.
- jira_request_type_id. Type the Jira request type ID.
- severity_field_id. Enter the Jira severity field ID.
- event_url_field_id. Enter the Skylar One event URL field ID from Jira.
- prirority. Type the Jira incident priority value for incidents created from Skylar One events.
- impact. Type the impact value for incidents created from Skylar One events.
- severity_def. Toggle the JSON editor to define severity mapping between Skylar One and Jira.
- add_template. Toggle the JSON editor to define a message for the description field in Jira.
For more information on creating a Jira API token, see Creating an API token in Jira.
For more information on your Jira account ID, see Locating the Account ID in Jira.
For more information on your Jira request type ID, see Locating the Request Type ID in Jira.
For more information on your severity field ID, see Locating the Severity Custom ID in Jira.
For more information on your Jira Event URL Field, see Configuring a Skylar One Event URL Custom Field in Jira.
For more information about the Jira terms and concepts in this section, see the Jira documentation.
With this SyncPack, you can synchronize your Skylar One events and Jira issues including creating Jira incidents, updating acknowledgment data, resolving Skylar One events and updating Skylar One event notes. You will need to align the "Jira Service Management" SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click . The Configurations pane for that application appears:
To trigger the applications in the SyncPack, you must schedule the following PowerFlow applications, which are included in the SyncPack:
- "Resolve Skylar One Event from Jira"
- "Show Jira Change Log in Skylar One Event Notes"
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple Skylar One instances or multiple Jira instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or Jira instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Jira instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
