This SyncPack uses the "PagerDuty Incident Integration" PowerPack.
The "PagerDuty" SyncPack lets you automatically trigger, acknowledge, and resolve Skylar One events and PagerDuty incidents between PagerDuty and Skylar One. The integration is bidirectional, from Skylar One to PagerDuty.
You can configure this SyncPack to perform the following integrations:
- Create an alert in PagerDuty from a Skylar One event.
- Collect on-call details from PagerDuty and add it to the notes of the corresponding Skylar One event.
- Update a synced PagerDuty alert when an event is acknowledged in Skylar One, including closing an alert in PagerDuty that was resolved by a corresponding Skylar One event.
- Collect resolved alert data from PagerDuty and clear the corresponding Skylar One event.
Contents of the SyncPack
This section lists the contents of the "PagerDuty" SyncPack.
PowerFlow Applications
- Create Event in PagerDuty from Skylar One Event. This application sends Skylar One event information to PagerDuty. The application translates and formats the event data from Skylar One so that it can be consumed by PagerDuty to trigger, acknowledge, or resolve an incident.
- Get PagerDuty log and incident data. This application queries the PagerDuty API to collect log entries and incident data. The collected entries are formatted and passed to subordinate applications that process the data to update, acknowledge, and clear events in Skylar One.
- Clear resolve event from ScienceLogic. This application clears an event in Skylar One that was resolved in PagerDuty. This application is called by the "Create resolve alert data from PagerDuty" application for each event that needs to be cleared.
- Post event updates to ScienceLogic. This application updates Skylar One events using the data collected from the PagerDuty API.
For more information about how to configure these applications, see Configuring and Aligning the PagerDuty Applications.
PowerFlow Applications (Internal)
The following applications are "internal" applications that should not be run directly, but are automatically run by applications from the previous list:
- Create resolve alert data from PagerDuty. This application is called by the "Get PagerDuty log and incident data" application to process log messages that indicate that an incident has been resolved. This application queries the PagerDuty API for the alerts associated with the resolved incidents. If the alert was triggered from a Skylar One event, the application calls the "Clear resolve event from ScienceLogic" application to clear the event.
- Get trigger alert data from PagerDuty. This application is called by the "Get PagerDuty log and incident data" application to process log messages that indicate that an incident has been triggered. This application queries the PagerDuty API for the alerts associated with those triggered incidents. If the alert was triggered from a Skylar One event, the application calls the "Post event updates to ScienceLogic" application to add to incident ID to the event.
- Get alert and user data from PagerDuty and ScienceLogic. This application is called by the "Get PagerDuty log and incident data" application to process log messages that indicate that an incident has been acknowledged. This application queries the PagerDuty API for the alerts associated with acknowledged incidents. If the alert was triggered from a Skylar One event, the application updates the Skylar One event so that the acknowledgment matches PagerDuty. This application also determines the date of the most recently processed alert and stores that value to be used by the next execution of the "Get PagerDuty log and incident data" application.
Configuration Object
- PagerDuty Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
- Details for connecting to the Skylar One API, including the URL, username, and password
- Details for connecting to the PagerDuty API, including the URL, username, and password
- Details for connecting to the PagerDuty REST API, including the URL and API key
- Details for connecting to an HTTP Proxy when communicating with PagerDuty, including the hostname or IP address, username, and password
- An optional identifier that appends the event ID to create a PagerDuty dedup key. This can be used to avoid routing collisions when multiple Skylar One platforms connect to the same PagerDuty instance.
- Mapping between Skylar One events and PagerDuty incidents including, event summary formats, event data, and indications to resolve or link incidents between Skylar One and PagerDuty
Steps
- Acknowledge the alert by user
- Check for since parameter after query
- Check conditional
- Get alert count and acknowledge the alert by user
- Get incident and user data
- Get resolve incident data
- Get trigger incident data
- Get user email from user details
- Convert ScienceLogic event data to PagerDuty event
