Contents of the ServiceNow Base SyncPack
The contents of the ServiceNow Base SyncPack can be used by all of the ServiceNow SyncPacks.
This section lists the contents of the "ServiceNow Base" SyncPack.
PowerFlow Applications
Bulk Clear SL1 Events. Bulk clears SL1 events.
Bulk Update SL1 Events. Bulk updates SL1 events with a given payload.
Configuration Object
- ServiceNow SyncPack. Contains a set of required variables. As a best practice, use the button to make a copy of the configuration object, and then update the variables from that object to match your SL1 and ServiceNow settings. Do not use the original version of the configuration to run PowerFlow applications.
Steps
- Clear SL1 Events
- Fetch Parent Devices from SL1
- Merge and Chunk Payloads for ServiceNow
- MySQL Multiple
- Optional QueryGQL Call
- Parse ServiceNow Cases and Incidents
- Post Event Details to SL1
- Post ServiceNow Ticket Details to SL1
- Process IS Configs
- Process Event Data for Clear
- Process SL1 RBA for Incident of Case
- Pull and Process ServiceNow Companies
- Pull and Process SL1 Events
- Pull and Process SL1 Organizations
- Pull Tickets from ServiceNow
- ServiceNow POST with OAuth Option
- ServiceNow GET with OAuth Option
- ServiceNow DELETE with OAuth Option
- ServiceNow POST with paging
- Update SL1 Event with ServiceNow Ticket Data
