Configuring Applications for the Cases SyncPack
This section describes how to configure PowerFlow applications for the "ServiceNow Cases" SyncPack.
With this SyncPack, any changes (except for acknowledgments) made to an SL1 event is sent to ServiceNow to update the corresponding case. Any status changes to the ServiceNow case are synced back to the corresponding SL1 event.
You can also use this SyncPack in conjunction with the "ServiceNow Configuration Management Database (CMDB)" SyncPack to create cases with a linked ServiceNow Configuration Item (CI).
The following workflows describe how to configure SL1 and PowerFlow to work with the "ServiceNow Cases" SyncPack.
Configuring SL1
  1. Create a ServiceNow credential
  2. Enable the following run book automation policies:
  • "ServiceNow: [Cases] Add/Update"
  • "ServiceNow: [Cases] Event Cleared"
  1. Enable and customize the "ServiceNow: Add/Update/Clear Case" run book action policy
  2. Optionally, send custom data to ServiceNow using the passthrough option
  3. Optionally, enable and configure the "ServiceNow: [Cases] Click to Create" policy
  4. Optionally, enable run book automation queue retries
Configuring PowerFlow
  1. Create a configuration object in the PowerFlow user interface
  2. Align the new configuration file with the following PowerFlow applications:
  • "Create or Update ServiceNow Case from SL1 Event"
  • "Resolve ServiceNow Case from SL1 Event"
  • "Sync Case or Incident State from ServiceNow to SL1 Event"
  1. Schedule the PowerFlow applications as needed
Configuring SL1
The following topics cover how to set up your SL1 instance to work with the "ServiceNow Cases" SyncPack.
To configure SL1 to communicate with ServiceNow, you must first create a SOAP/XML credential. This credential allows the run book automations in the "ServiceNow Base Pack" PowerPack to connect with your ServiceNow instance. These run book automations are responsible for sending the SL1 event data to PowerFlow, which ultimately sends the data to ServiceNow.
The ServiceNow RBA - Example credential from the "ServiceNow Base Pack" PowerPack is an example SOAP/XML credential that you can configure for your own use.
  2. Locate the ServiceNow RBA - Example credential and click its wrench icon (). The Edit SOAP/XML Credential page appears.
  • Profile Name. Type a new name for the ServiceNow credential.
  • Timeout. Leave as the default of "5000" ms.
  • Content Encoding. Make sure text/xml is selected.
  • Method. Make sure POST is selected.
  • HTTP Version. Select http/1.1.
  • URL. Type the URL for your PowerFlow instance.
  • HTTP Auth User. Type the username of your PowerFlow instance.
  • HTTP Auth Password. Type the password of your PowerFlow instance.
  1. Click Save & Close. The credential is added to the Credentials page
  2. On the Credentials page, make a note of the value in the ID column for the credential you just created. You will use this value with the sl1_credential_id parameter when you enable the snippet code of the "ServiceNow: Add/Update/Clear (Case/Event/Incident)" run book action policy.
Versions 104 and later of the "ServiceNow Base Pack" PowerPack separated these run book action policies by Cases, Events, and Incident, such as "ServiceNow: [Cases] - Add/Update".
Before you can run the "ServiceNow: Add/Update/Clear Case" run book action, you must enable the two case-specific run book automation policies in SL1:
  • ServiceNow: [Cases] - Add/Update
  • ServiceNow: [Cases] - Event Cleared
To enable the run book automation policies:
  1. Locate the "ServiceNow: [Cases] - Add/Update" automation policy and click its wrench icon (). The Automation Policy Editor page appears.
  • Available Actions. If it is not already selected, select "ServiceNow: Create, Update, Clear Incident or Event".
    By default, the "ServiceNow: [Cases] Add/Update" automation policy will create ServiceNow Cases for all devices. You can limit the devices affected by making changes to the Organization, Severity, Match Logic, Aligned Devices, and/or Aligned Events fields.
  2. Repeat steps 2-4 for the "ServiceNow: [Cases] - Event Cleared" run book automation policy.
The "ServiceNow: Add/Update/Clear Case" run book action policy contains snippet code that you can customize to use with the "ServiceNow Cases" SyncPack. You edit these values in the Input Parameters pane of the Actions page for this policy.
For example, you can choose to let PowerFlow create both an incident and a case in ServiceNow when an SL1 event is created, or you can choose to have PowerFlow create just an Incident when an SL1 event is created. You can edit this setting with the proactive parameter, which is described in the "Customizing the Snippet Code in the Input Parameters Pane" section, below.
Make sure you are using the most recent version of the run book action policy. If there are two policies with the same name, always use the policy with the higher number in the ID column of the Actions page.
Be sure to schedule the "Cache SL1 Users" PowerFlow application to run at least once a week to ensure that the user cache has the most recent data.
To enable and customize the Case run book action policy:
  1. In SL1, go to the Actions page (Registry > Run Book > Actions).
  2. Locate the ServiceNow: Add/Update/Clear Case policy and click its wrench icon (). The Action Policy Editor page appears:
  2. For the sl1_credential_id field in the Input Parameters pane, specify the credential ID from the ID column on the Credential Management page (System > Manage > Credentials). For example: "sl1_credential_id": "101"
  3. Edit the snippet code as necessary, using the information in the Customizing the Snippet Code in the Input Parameters Pane section, below.
SL1 run book action snippets are written in Python. In the event of a syntax error, the policies will no longer run. As a result, you must ensure that all edits adhere to Python standards. True and False options are case-sensitive and must not contain quotes.
You can customize the following values in the "ServiceNow: Add/Update/Clear Case" run book action snippet code:
  • sl1_credential_id. Specifies the ID of the credential object. You can find this value in the ID column of the Credentials page (Manage > Credentials of SL1. For example: "sl1_credential_id": "41"
  • configuration. Specifies the ID of the configuration object used on PowerFlow. The configuration ID is all lower-case, with spaces in the configuration object "friendly" name replaced by underscores. For example: "configuration": "docs_config"
    NOTE: To find the configuration ID with the API, make a GET request on this endpoint: https://<powerflow_hostname>/api/v1/configurations.
  • integration. Specifies the SyncPack you are using for this run book action. For example: "integration": "cases".
  • discard_if_no_ci. Specifies whether PowerFlow should create cases in ServiceNow for devices that do not have a matching CI record. Your options include:
  • true. If a device is not mapped to a CI, PowerFlow will not create a case in ServiceNow, and SL1 is not updated. The following log message appears: "No CI found".
  • false. If a device is not mapped to a CI, PowerFlowwill create a case in ServiceNow and update SL1. The default is false.
  • proactive. Creates both a Case and an Incident in ServiceNow when an SL1 Event is created, or creates just a Case when an SL1 Event is created. If a Case or Incident is assigned in ServiceNow, the SL1 Event will be acknowledged. Users will be matched first on username, then email, then first and last name. The default is "true".
  • true. Specify "true" if you want to create both a Case and an Incident in ServiceNow. This option creates an "External Ticket" link for the SL1 Event that opens the corresponding Case in ServiceNow. If an Event has a Case in ServiceNow, the case status will be populated; if not, the Incident status will be populated. If a Case or Incident is assigned in ServiceNow, the SL1 Event will be acknowledged.
  • false. Specify "false" if you only want to create an Incident in ServiceNow. This option creates an "External Ticket" link for the SL1 Event that opens the corresponding Incident in ServiceNow.
    If you change the proactive value from true to false after initial configuration and you have active Cases, the External Ticket link for the SL1 Event will continue to link to the Case record in ServiceNow. To avoid this situation, ensure that all synced Cases are Closed or Inactive before changing the proactive value. The External Ticket link will only be updated to the Incident record for new SL1 Events.
You can customize the following logging-related items in the "ServiceNow: Add/Update/Clear Case" run book action snippet code:
  • logfile = /data/tmp/ServiceNow_add_update_clear_incident.log
  • Location for logging output.
  • Will be created if it does not exist.
  • Will be appended with each Run Book job.
  • Is case-sensitive.
  • do_debug_logging = True
  • True is on, False is off.
  • For troubleshooting, these can be enabled or changed.
  • Writes logs to /data/tmp/servicenow_rba.log.
Sending Custom Data to ServiceNow Using the Passthrough Option
You can use the "ServiceNow: [(Cases/Events/Incidents)] Add/Update" run book automation and the "ServiceNow: Add/Update/Clear (Case/Event/Incident)" run book action to "pass through" custom data about SL1 cases, events, or incidents to ServiceNow (depending on the SyncPack you are using with PowerFlow).
For example, you might want to use the passthrough functionality to overwrite the impact and urgency of a ServiceNow incident, which is the only way to change the priority of the incident.
  • Create a new run book action that pulls the relevant data and adds it to a dictionary called EM7_RESULT.
  • Add the new run book action to the "ServiceNow: [(Cases, Events, or Incident)] Add/Update " run book automation Policy, ahead of the "ServiceNow: Add/Update/Clear (Case/Event/Incident)" run book action so that the new action runs first, and then is consumed by the ServiceNow action.
The following procedure describes how to configure the passthrough functionality, using the "ServiceNow: [Incident] Add/Update" run book automation and the "ServiceNow: Add/Update/Clear Incident" run book action as examples.
  1. In SL1, go to the Actions page (Registry > Run Book > Actions) and click Create to create a new run book action policy.
  • Action Name. Type a unique name for the action.
  • Complete the other fields as needed, or leave them at their default settings.
  1. In the Snippet Code pane, add the snippet code you want to include for the EM7_RESULT dictionary. For example, the following snippet code lets you override the ServiceNow Incident work notes with a hardcoded note:
  • A long snippet might delay the ticket being created
  2. Go to the Automation Policy Manager page (Registry > Run Book > Automation) and open the "ServiceNow: Add/Update Incident" run book automation Policy.
  1. In the Available Actions section, add the new run book action before the "ServiceNow: Create, Update, Clear Incident" run book action:
    The output of this new run book action will be consumed by the "ServiceNow: Create, Update, Clear Incident" run book action, ensuring that the EM7_RESULT dictionary is passed through to ServiceNow. The "ServiceNow: Create, Update, Clear Incident" run book action automatically populates the passthrough values with any values from EM7_LAST_RESULT. The passthrough overwrites any other previously defined fields, such as assignment group.
  1. You can add additional run book actions to the run book automation Policy for any additional workflows that you might want to run. The Automation Policy execute these Actions in a sequential, top-down order. However, the "ServiceNow: Create, Update, Clear Incident" run book action only consumes the EM7_RESULT dictionary from the run book action directly above it.
Passthrough Example
For the Dictionary Entry of the ServiceNow field on the import table, you can reference the XML of the record. You will need to copy the <sys_name> value so you can use that as the key for the passthrough.
In this example, you want to bring in an additional field called sl1 category.
  1. Create the new sl1 category field on the import table in ServiceNow. You can right-click on the header of the form to view the XML:
  2. Look for the <sys_name> value.
  3. Copy that value directly out and use that in your EM7_RESULT for the passthrough value (in the Snippet Code pane):
    EM7_RESULT = {'sl1 Category': 'test'}
The following snippet code example shows how to pull additional information and make it available for passthrough. All of the additional information that is going to be sent is contained in a dictionary variable called EM7_RESULT. You can pass through multiple items through in a single run book action by adding additional keys to the EM7_RESULT dictionary.
from future.utils import iteritems
def invert_mappings(mappings):
    Invert received one-to-many mappings and converts it into a one-to-one
    mapping.
    Args:
        mappings (dict): Dictionary of mapped values
    Returns:
        dict: inverted dictionary.
    inverted_mappings = dict()
    for key, values in iteritems(mappings):
        for sub_value in values:
            invert_mappings[sub_value] = key
    return inverted_mappings
# Example of assignment group to list of event policy ids mapping.
assignment_groups_to_event_policies = {
    "sys_id_1": [1, 2, 3, 4, 5],
    "sys_id_2": [6, 7, 8, 9, 10],
# which sys_id to use if the current event_policy_id isn't mapped
default_sys_id = "sys_id_3"
# invert the mappings
event_policy_to_assignment_group = invert_mappings(assignment_groups_to_event_policies)
# Send assignment group sys_id to IS RBA
EM7_RESULT = {
    "assignment_group": event_policy_to_assignment_group.get(
        EM7_VALUES["%3"], default_sys_id
Configuring the "ServiceNow: [Cases] Click to Create" Automation Policy
The "ServiceNow: [(Cases/Events/Incident)] - Click to Create" automation policy lets you manually create a case, event, or incident in ServiceNow by clicking the Actions button () in SL1 for an event and selecting "Create External Ticket" (or by clicking the life-preserver icon () for an event in the classic user interface).
This run book action policy is available in the "ServiceNow Base Pack" PowerPack.
To configure the "ServiceNow: Click to Create" run book action policy:
  2. Click Save to save your changes. You might need to log out of SL1 and log back into SL1 for the changes to update.
  3. Go to the Automation page (Registry > Run Book > Automation).
  4. Locate the "ServiceNow: (Cases/Events/Incident) - Click to Create" policy and click its wrench icon (). The Automation Policy Editor page appears:
  5. Update the following fields:
  • In the Criteria Logic section, select and external ticket IS requested in the fifth drop-down. Leave the other values in this section at their default settings.
  • Available Actions. If it is not already selected, select ServiceNow: Send to PowerFlow: ServiceNow: Add/Update/Clear Incident and add it to the Aligned Actions field.
  1. Click Save. The "Click to Create" feature is now available on the Events and Event Investigator pages.
Enabling Run Book Automation Queue Retries
You can enable run book action (RBA) queue retries to keep from losing any data if PowerFlow is unavailable. Those pending PowerFlow applications are added to an RBA queue that you can access to retry the applications that failed.
For more information, see Enabling Run Book Automation Queue Retries.
The following topics cover how to set up your PowerFlow instance to work with the "ServiceNow Cases" SyncPack.
To use this SyncPack, you will need to use an existing configuration object in the PowerFlow user interface or create a new configuration object. Next, you need to align that configuration object to the relevant applications that are triggered by the Run Book Actions in SL1.
Depending on your SL1 environment and the third-party environment with which you are syncing data, you might be able to use the same configuration object with more than one SyncPack.
  2. Click the Actions button () for the "ServiceNow SyncPack" configuration object and select Edit. The Configuration pane appears:
       "encrypted": false,
       "name": "<sl1_db_host>",
       "encrypted": false,
       "name": "sl1_db_host",
       "value": "10.2.11.42"
    Click Toggle JSON Editor to show the JSON code. Click the button again to see the fields. You can also click Add Value and add a new name-value pair in the Configuration Data Values section.
    1. If you want to use OAuth2 for authentication with ServiceNow, complete the following Configuration Data Values fields:
    • snow_oauth_client_id. Enter the OAuth2 Client ID from ServiceNow.
    • snow_oauth_client_secret. Enter the OAuth2 Client secret from ServiceNow.
    • snow_oauth_token_url. Enter the full authentication URL, including host and protocol from ServiceNow. For example, "https://<test-instance-name>.service-now.com/oauth_token.do"
    • snow_auth_method: Enter oauth or http_basic. If no value is provided, http_basic will be used for connection.
    The configuration options listed above are included by default with the sample configuration object provided in the "ServiceNow Base" SyncPack. The configuration options are only required in the configuration object if you plan to use OAuth2 to authenticate. If the values are not present in the configuration object, normal "http_basic" authentication will be used.
    Creating an OAuth2 Credential Record in ServiceNow
    In order to use OAuth2 for authentication with ServiceNow, you must create an OAuth2 credential record in ServiceNow. To configure the ServiceNow credential that will be used by the Connector Instance:
    1. Navigate to System OAuth > Application Registry. The Application Registries page appears.
    2. Click New.
    3. Select Create an OAuth API endpoint for external clients. A new record appears.
    4. Complete the following fields on the new record:
    • Name. Type a unique name for the credential. Required.
    • Client ID. The Client ID is automatically generated by the ServiceNow OAuth server.
    • Client Secret. Leave this empty. ServiceNow will auto-generate this when the record is saved.
    • Refresh Token Lifespan. Enter the length of time in seconds the Refresh Token will be valid.
    • Access Token Lifespan. Type the length of time in seconds that the Access Token will be valid. ScienceLogic recommends setting this to 3,600 seconds to avoid known issues for longer ServiceNow REST interactions.
    In a scenario where the Access Token Lifespan value is shorter than the duration of a PowerFlow step that makes multiple REST interactions with ServiceNow, the access token will expire and need to be refreshed. As a result, retries were added to several PowerFlow steps where this issue may occur. This issue will hopefully be addressed in future versions of the Base Steps SyncPack.
    1. Under the Auth Scope section at the bottom of the page, double click Insert a new row.
    2. In the search box that appears, click the magnifying glass icon, select the useraccount record, and click the checkmark icon to save.
    3. Click Submit to save the new record.
    Aligning a Configuration Object and Configuring PowerFlow Applications
    To run Case Sync, you must "align" the configuration object to run with the following PowerFlow applications:
    • Cache SL1 Users
    • Create or Update ServiceNow Case from SL1 Event
    • Resolve ServiceNow Case from SL1 Event
    • Sync Case or Incident State from ServiceNow to SL1 Event
    If you want to link cases with ServiceNow Configuration Items (CIs), you will need to run the "Sync Devices from SL1 to ServiceNow" application from the ServiceNow CMDB SyncPack. If this is the first time you are running Case Sync, you will need to run the "Sync Devices from SL1 to ServiceNow" application twice to build the internal cache. For more information, see Running a Device Sync in the ServiceNow CMDB SyncPack section.
    1. On the Applications page of the PowerFlow user interface, open one of the PowerFlow applications listed above and click Configure. The Configurations pane for that application appears:
      The values for eventDetails and the other parameters that appear in the Configuration pane with a padlock icon () are populated either by the configuration object you aligned with the application or by the Run Book Action. Do not modify these values. If you encounter an error, make sure your Run Book Action is configured properly.
    2. If needed, edit the retry values:
    • retry_jitter. Instead of using a defined interval between retries, the PowerFlow system will retry the step execution at random intervals. The default is unselected.
    • retry_backoff. Instead of using a defined interval between retries, PowerFlow will incrementally increase the interval between retries. The default is unselected.
    • retry_backoff_max.The maximum time interval for the retry_backoff option, in seconds. For example, This means, if you have retry_max set to 15, the delays will be 1, 2, 4, 8, 16, 32, 64, 120, 240, 480, 600, 600, 600, 600, and 600. The default is 600.
    • read_timeout. Specify the maximum amount of time in seconds that the application should wait for a response before timing out. The default is 20.
      Do not update any of the other parameters on the Configuration pane for any of these PowerFlow applications related to Case Sync. These values are updated by the "ServiceNow: Add/Update/Clear Case" Run Book Action.
    2. Repeat this process for the other PowerFlow applications. The "Cache SL1 Users" application is in the "System Utils" SyncPack.
    ScienceLogic recommends that you schedule the following PowerFlow applications:
    • "Cache SL1 Users": at least once a week
    • "Sync Case or Incident State from ServiceNow to SL1 Event": every 60 seconds
    Do not schedule the "Create or Update ServiceNow Case from SL1 Event" application or the "Resolve ServiceNow Case from SL1 Event" application. These applications should only be triggered by Run Book Automations.
