Introduction to the ServiceNow Service Catalog SyncPack
This section describes the "ServiceNow Service Catalog" SyncPack, which lets you initiate a discovery session to discover devices in Skylar Automation (formerly PowerFlow) from ServiceNow. This SyncPack also lets you place Skylar One devices into and out of maintenance mode using ServiceNow change requests.
The "ServiceNow Service Catalog" SyncPack is the ScienceLogic integration with the ServiceNow Service Catalog Request Application. This SyncPack lets you initiate a discovery session to discover devices in Skylar One from ServiceNow. You can also use this SyncPack to place Skylar One devices into and out of maintenance mode using ServiceNow change requests.
ScienceLogic created this SyncPack to improve maintainability and certification time. This SyncPack includes the Discovery module, which was previously available with the "ServiceNow CMDB" SyncPack, and the Change module, which was available with the "ServiceNow Change Management” SyncPack.
You can use this SyncPack with or without a ServiceNow MID Server.
This SyncPack includes the following integrations:
  • Discovery Sync. The Discovery Sync integration lets you initiate a discovery session to discover devices in Skylar One from ServiceNow. With Discovery Sync, you start a Skylar One discovery session from ServiceNow and then sync the newly discovered Skylar One devices or virtual devices and their data with ServiceNow. You can also remove devices from being monitored.
    You will need to configure the following Skylar Automation applications to run the Discovery Sync:
    • Sync Catalog Requirements
    • Sync Discovery Session Status from Skylar One to ServiceNow
    • Sync Service Requests from ServiceNow to Skylar One
  • Change Management Sync. The Change Management Sync integration facilitates event generation and moving devices in and out of maintenance mode in Skylar One. The Skylar One event contains data about the change request from ServiceNow, including a hyperlink to the ServiceNow change record. The event is aligned with a device in Skylar One, and if the device is part of a business service in Skylar One version 12.2.0 or later, the event displays on the Changes tab for that business service in Skylar One.
    You will need to configure the following Skylar Automation applications to run the Change Management Sync:
    • Update Skylar One Event With ServiceNow Change Request Info
    If using a MID Server:
    • Create or Update Maintenance Schedule from ServiceNow Trigger
    • Trigger Device Maintenance Updates via MID Server
    If you are not using a MID Server:
    • Sync Maintenance Schedules from ServiceNow to Skylar One
For more information, see Configuring Applications for the ServiceNow Service Catalog SyncPack.
Contents of the SyncPack
This section lists the contents of the "ServiceNow Service Catalog" SyncPack.
Skylar Automation Applications
The following applications are included with the "ServiceNow Service Catalog" SyncPack, and you will need to configure these applications before you can run Discovery or Change Management Syncs:
  • Sync Discovery Session Status from Skylar One to ServiceNow. Collects and processes Discovery sessions from Skylar One, and collects Discovery session logs.
  • Sync Service Requests from ServiceNow to Skylar One. Processes Discovery sessions and posts Discovery sessions and new virtual devices to Skylar One. Also enables device decommissioning for devices you no longer want to monitor.
  • Sync Catalog Requirements. Sends configuration data from Skylar Automation to ServiceNow to use with change management and other processes.
  • Sync Discovery Templates from Skylar One to ServiceNow. Syncs Skylar One discovery sessions that contain a configured string to ServiceNow and creates Service Catalog templates in ServiceNow. You can use those templates for discovering or monitoring CIs.
  • Sync Maintenance Schedules from ServiceNow to Skylar One. Syncs maintenance windows from ServiceNow change requests (CHG)s to Skylar One devices to place the synced devices into maintenance mode for the scheduled change window. If you are scheduling this application, ScienceLogic recommends that you schedule it to run every hour or so, depending on your environment. This process does not require the use of a ServiceNow MID Server.
  • Trigger Device Maintenance Updates via MID Server. Lets you sync maintenance windows from ServiceNow to Skylar One using a ServiceNow Management, Instrumentation, and Discovery (MID) Server.
  • Create or Update Maintenance Schedule from ServiceNow Trigger. Handles scheduling and canceling maintenance schedules in Skylar One using a trigger from a ServiceNow Management, Instrumentation, and Discovery (MID) Server. When triggered, the application gathers data about the change request in ServiceNow and generates a Skylar One Event with a severity of Notice.
  • Update Skylar One Event with ServiceNow Change Request Info. Updates a Skylar One Event with ServiceNow Change Request info
Of the applications listed above, the Discovery Sync only requires you to configure:
The Change Management Sync requires you to configure:
Skylar Automation Applications (Internal)
The following applications are "internal" applications that should not be run directly, but are automatically run by applications from the previous list. To view the internal Skylar Automation applications, click the Filter icon () on the Applications page and select Show Hidden Applications. Internal applications are hidden by default.
  • Cancel Maintenance. Cancels a scheduled maintenance in Skylar One.
  • Create Discovery Session in Skylar One. Creates and starts a Discovery session in Skylar One and updates the ServiceNow service request.
  • Create Maintenance. Creates a scheduled maintenance in Skylar One.
  • Create Virtual Device in Skylar One. Creates a virtual device in Skylar One and updates the Requested Item (RITM) value.
  • Modify Maintenance. Updates a scheduled maintenance in Skylar One.
  • Post Discovery Template Data to ServiceNow. Posts the discovery template date to ServiceNow.
  • Post Attribute Rest Calls to Skylar One. Posts attribute REST calls to Skylar One.
  • Process Create Schedule Requests. Schedules and posts maintenance tasks in ServiceNow.
  • Process Remove Device Requests from ServiceNow to Skylar One.
  • Pull and Post Discovery Logs. Pulls Discovery session logs from Skylar One and posts updates to ServiceNow.
  • Remove Maintenance. Removes a scheduled maintenance in Skylar One.
  • Run MySql Queries. Creates notices for event changes that come in from ServiceNow.
  • Schedule Maintenance. Creates a scheduled maintenance in Skylar One.
  • Update Devices and Post Maintenance Status to ServiceNow. Updates Skylar One devices and posts Maintenance Status to ServiceNow.
  • Sync Configs from PowerFlow to ServiceNow. Syncs configuration data from Skylar Automation to ServiceNow.
  • Sync Device Groups from Skylar One to ServiceNow. Collects all device groups and group IDs from Skylar One and posts device group data to ServiceNow. To prevent errors when running this application or a device sync, make sure that the device group names are not already being used by existing groups in ServiceNow.
  • Sync Organizations from Skylar One to ServiceNow Dependents Table. Sends Skylar One organizations to the Discovery Dependents table in ServiceNow. This is not a bi-directional sync , and Skylar One is the source of truth. This sync does not interact with the core company table in ServiceNow.
Steps
  • Add External Ticket Reference to Skylar OneEvent
  • Check Skylar One Device Schedules
  • Compare Organizations
  • Delete Tasks or Schedules from Skylar One
  • Disable Devices in Skylar One
  • Parse Skylar One Event Details
  • Post Discovery Session
  • Post Maintenance Task to Skylar One
  • Post Maintenance Status to ServiceNow
  • Post Remove Schedule and Task Results
  • Post Virtual Device
  • Process Change Requests
  • Process Maintenance Schedule Triggers
  • Process Maintenance Triggers
  • Pull and Process Active Discovery Sessions
  • Process Collectors and Collector Groups
  • Pull and Process Credentials from Skylar One
  • Reconcile Skylar One Make and Model with ServiceNow
  • Process Device Templates
  • Pull and Process Discovery Sessions
  • Pull and Process PF Configs
  • Pull and Process Service Requests
  • Process Virtual Device Classes
  • Pull Change Tasks
  • Pull Devices and Validate Delete Requests
  • Pull Discovery Session Logs from PF Cache and Skylar One
  • Task and Schedule Call to SL
  • Update and Process Devices
