Configuring Applications for the Service Graph Connector SyncPack
This section describes how to configure Device Sync between Skylar One and ServiceNow using the ServiceNow Service Graph Connector.
The following workflows describe how to configure ServiceNow and PowerFlow to work with the "ServiceNow Service Graph Connector" SyncPack.
Configuring ServiceNow
  1. Configure the Service Graph Connector for ScienceLogic
  2. Create a ServiceNow Group
  3. Create a ServiceNow User
Configuring PowerFlow
  1. Install the ServiceNow Service Graph Connector SyncPack and its dependencies
  2. Create a configuration object in the PowerFlow user interface
  3. Align the new configuration object with the following PowerFlow applications:
  • "Cache Skylar One Orgs and Device Classes"
  • "Sync Devices from Skylar One to ServiceNow via SGC"
  • "Sync File Systems from Skylar One to ServiceNow via SGC"
  • "Sync Interfaces from Skylar One to ServiceNow via SGC"
  1. Run or schedule the following applications, in the following order:
The following topics cover how to set up your ServiceNow instance to work with the "ServiceNow Service Graph Connector" SyncPack.
Configuring the Service Graph Connector for ScienceLogic
In ServiceNow, you can use the Guided Setup process to configure the Service Graph Connector for ScienceLogic.
  1. In ServiceNow, go to Service Graph Connectors > ScienceLogic > Guided Setup. The ScienceLogic Integration with CMDB page appears.
  2. In the Integration Account section, click Get Started and complete the tasks in order.
  3. Click Configure button to configure each task.
  4. After you complete each task, click Mark as Complete.
  5. After you finish all the tasks in the Integration Account section, go to the PowerFlow Setup section and click Get Started:
  6. These PowerFlow tasks are described in the following sections of this manual:
  1. After you complete each task in PowerFlow, click Mark as Complete in the PowerFlow Setup section in ServiceNow.
  2. When are done with all the tasks in the PowerFlow Setup section, continue to the next topic, "Creating a ServiceNow Group".
For best practice and security, create a dedicated ServiceNow account that has restricted access to only the groups, access control lists (ACLs), and roles needed for ScienceLogic integration.
To create a ServiceNow Account for ScienceLogic integration:
  1. In ServiceNow, search in the filter navigator for "groups".
  2. On the Groups page (System Security > Groups), click New. A New record page appears.
  1. In the New record page, type the group name and any additional information. Name is the only required field:
  1. At the bottom of the Group form, select the Roles tab and click Edit:
  1. Search for cmdb_import_api_admin and x_sclo_devicesync.admin and move them to the Roles List column using the arrow buttons:
  1. Click Save. Your ServiceNow Group now has two assigned Roles:
  1. Next, create a ServiceNow user to use with this Group. See the following procedure for the details.
Creating a ServiceNow User
NOTE: The ServiceNow user you create in this procedure will not be able to log into the ServiceNow user interface with the username and password you give this user. However, you will use the username and password in the relevant configuration objects in the PowerFlow user interface to run applications. For more information about configuration objects, see Creating and Aligning a Configuration Object.
To create a ServiceNow Account for ScienceLogic Incident management:
  1. In ServiceNow, search in the filter navigator for "users".
  2. On the Users page (System Security > Users), click New. A New record page appears.
  • User ID. Type a user ID. Required.
  • First Name. Type the user's first name.
  • Last Name. Type the user's last name.
  • Password. Type a password. Required.
  • Active. Select this checkbox. Required.
  • Web Service Access Only. Select this checkbox. Required.
  • Time Zone. Select GMT. Required.
  • Date Format. Select System (yyyy-MM-dd).
  1. Right-click the gray header and click Save to save the user.
  1. Select the Groups tab at the bottom of the record and click the Edit button:
  1. Find the group you created previously and move the group to the right-hand column using the arrow buttons:
  1. Click Save. After the user has been added to the group, you can see their Roles and Groups at bottom of the record:
NOTE: As a best practice, you should use a non-administrator ServiceNow user for the PowerFlow configuration object.
The following topics cover how to set up your PowerFlow instance to work with the "ServiceNow Service Graph Connector" SyncPack.
A configuration object supplies the login credentials and other required information needed to execute the steps for an application in PowerFlow. The Configurations page () of the PowerFlow user interface lists all available configuration objects for that system.
You can create as many configuration objects as you need. A PowerFlow application can only use one configuration object at a time, but you can use (or "align") the same configuration object with multiple PowerFlow applications.
To use this SyncPack, you will need to create one or more configuration objects in the PowerFlow user interface and align that configuration object to the applications that let you sync data between Skylar One and ServiceNow.
Depending on your Skylar One and ServiceNow environments, you might be able to use the same configuration object with other ServiceNow SyncPacks.
When either multiple Skylar One stacks or multiple ServiceNow systems are involved with PowerFlow, you should create an individual configuration object for each Skylar One stack or ServiceNow system. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One stack or ServiceNow system. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
The "ServiceNow SyncPack" configuration object contains all of the required variables. Make a copy of the configuration object and update the variables from that object to match your Skylar One and ServiceNow settings.
  2. Click the Actions button () for the "ServiceNow SyncPack" configuration object and select Edit. The Configuration pane appears:
       "encrypted": false,
       "name": "<sl1_db_host>",
       "encrypted": false,
       "name": "sl1_db_host",
       "value": "10.2.11.42"
    Click Toggle JSON Editor to show the JSON code. Click the button again to see the fields. You can also click Add Value and add a new name-value pair in the Configuration Data Values section.
    If you are using Skylar One with an External Database (Skylar One Extended architecture or a cloud-based architecture), update the "value" of that block of code to be the host of your database. This field accepts IP addresses. For example: "value": "db.sciencelogic.com". If you are not using the Skylar One Extended architecture or a cloud-based architecture, you do not need to make any changes to the block of code other than pasting the code into the configuration object.
    The region value is a user-defined variable that identifies your Skylar One instance within ServiceNow.
    1. If you want to use OAuth2 for authentication with ServiceNow, complete the following Configuration Data Values fields:
    • snow_oauth_client_id. Enter the OAuth2 Client ID from ServiceNow.
    • snow_oauth_client_secret. Enter the OAuth2 Client secret from ServiceNow.
    • snow_oauth_token_url. Enter the full authentication URL, including host and protocol from ServiceNow. For example, "https://<test-instance-name>.service-now.com/oauth_token.do".
    • snow_auth_method: Enter oauth or http_basic. If no value is provided, http_basic will be used for connection.
    The configuration options listed above are included by default with the sample configuration object provided in the "ServiceNow Base" SyncPack. The configuration options are only required in the configuration object if you plan to use OAuth2 to authenticate. If the values are not present in the configuration object, normal "http_basic" authentication will be used.
    Before you can run the applications in this SyncPack, you must first "align" a configuration object with those applications. The applications you need to align include the following:
    • Cache Skylar One Orgs and Device Classes. Reads all existing Skylar One Device Classes and writes them to a cache. You must run this application before you run the "Sync Devices from Skylar One to ServiceNow via SGC" application.
    • Sync Devices from Skylar One to ServiceNow via SGC. Syncs devices and their organizations and relationships from Skylar One to ServiceNow.
    The first time you run both of these applications, ScienceLogic recommends that you run them on Debug Mode to help you identify any misconfigurations.
    1. From the Applications page of the PowerFlow user interface, open the relevant application and click Configure (). The Configurations pane for that application appears:
    2. From the Configuration drop-down, select the configuration object you want to use.
    3. Click Save to align that configuration with the application.
    4. Wait for the "App & Config modifications saved" pop-up message to appear. The Configuration automatically closes after this message appears.
    5. Repeat this process for the remaining PowerFlow applications in this SyncPack.
    The values for eventDetails and the other parameters that appear in the Configuration pane with a padlock icon () are populated by the configuration object. Do not modify these values.
    Creating an OAuth2 Credential Record in ServiceNow
    In order to use OAuth2 for authentication with ServiceNow, you must create an OAuth2 credential record in ServiceNow. To configure the ServiceNow credential that will be used by the Connector Instance:
    1. Navigate to System OAuth > Application Registry. The Application Registries page appears.
    2. Click New.
    3. Select Create an OAuth API endpoint for external clients. A new record appears.
    4. Complete the following fields on the new record:
    • Name. Type a unique name for the credential. Required.
    • Client ID. The Client ID is automatically generated by the ServiceNow OAuth server.
    • Client Secret. Leave this empty. ServiceNow will auto-generate this when the record is saved.
    • Refresh Token Lifespan. Enter the length of time in seconds the Refresh Token will be valid.
    • Access Token Lifespan. Type the length of time in seconds that the Access Token will be valid. ScienceLogic recommends setting this to 3,600 seconds to avoid known issues for longer ServiceNow REST interactions.
    In a scenario where the Access Token Lifespan value is shorter than the duration of a Skylar Automation step that makes multiple REST interactions with ServiceNow, the access token will expire and need to be refreshed. As a result, retries were added to several Skylar Automation steps where this issue may occur. This issue will hopefully be addressed in future versions of the Base Steps SyncPack.
    1. Under the Auth Scope section at the bottom of the page, double click Insert a new row.
    2. In the search box that appears, click the magnifying glass icon, select the useraccount record, and click the checkmark icon to save.
    3. Click Submit to save the new record.
    Managing Organizations
    Two fields are used to select a company. The first non-null value returned will be used for the company. These fields include the following, in order:
    • CRM ID. The org_crm_id supplied is validated using a lookup of the sys_id to validate that the sys_id match is found on the core company table.
    • Name: The org_name is used in a lookup to find a matching name on the core company table.
    Syncing Devices from Skylar One to ServiceNow
    To perform a Device Sync between Skylar One and ServiceNow, run the following applications in the PowerFlow user interface:
    • Cache Skylar One Orgs and Device Classes. Reads all existing Skylar One Organizations and Device Classes and writes them to a cache.
    Currently, all data is synced from Skylar One to ServiceNow only.
    To sync Skylar One devices with ServiceNow:
    1. In the PowerFlow user interface, select the "Cache Skylar One Orgs and Device Classes" application from the Applications page, click Configure (), align a configuration object, and then click Run ().
    2. Select the "Sync Devices from Skylar One to ServiceNow via SGC" application from the Applications page and click Configure (). The Configuration pane appears:
    3. Complete the following fields, as needed:
    • Configuration. Select the configuration object with the relevant Skylar One and ServiceNow credentials to align with this application. You cannot edit fields that are populated by the configuration object. Required.
      The region field (along with other fields related to user names and passwords) is populated by the configuration object you aligned with this application. The region value must match the value in the Skylar One Region field in ServiceNow. If you need to update this value, you will need to define the region variable in the configuration object that is aligned with this application, or align a different configuration object that has the correct region value.
    • read_timeout. Specify the maximum amount of time in seconds that the application should wait for a response before timing out. The default is 30 seconds. If the Device Sync continually times out, you might want to increase the timeout to 120 seconds, as this sync can be data-intensive.
      Scroll past the mappings section to access the next set of fields. For more information about the mappings section, go to step 6.
    • Include_Orgs. If you want to include Skylar One Organizations in the device sync, add the Organization IDs from Skylar One in this field, separated by commas. Leave this field empty to sync all Skylar One Organizations.
    • Include_CUGs. If you want to include Skylar One Collector Groups (CUGs) in the device sync, add the Collector Group IDs from Skylar One in this field, separated by commas. Leave this field empty to sync all Skylar One Collector Groups.
    • sl1_chunk_size. Specify the number of devices to include in each chunk sent to in the Skylar One GraphQL query when you run this application. The default chunk size is 500 devices.
    • sl1_url_override. Update this field if you want to use an URL that is different from the standard Skylar One URL that gets sent to the ServiceNow CI record. Optional.
    • excluded_devices. Type a list of comma-separated device names or device IDs for any devices that you want to exclude from the device sync. Optional.
    • selected_devices. If you want to sync a sub-set of all discovered devices, type a comma-separated list of the Device IDs from Skylar One for only the devices that you want to sync. Leave this field empty to sync all Skylar One devices.
    • lookup_chunk_size. Specify the number of devices in each chunk when pulling the device cache from Couchbase. The default is 1000 devices.
    • max_count_for_relationships. Defines the maximum number of ids to query for sets of relationships in a single chunk.
    • all_devices_template. Add a Jinja2 Template to apply to all devices. The result must be a dictionary (Key | Value pair) and will then be included in each JSON device object.
    • snow_chunk_size. Specify the number of devices per chunk to post to ServiceNow when you run this application. The default chunk size is 2000 devices.
      Scroll down to the bottom of the Configuration pane to access the following fields.
    • retry_backoff_max.The maximum time interval for the retry_backoff option, in seconds. For example, This means, if you have retry_max set to 15, the delays will be 1, 2, 4, 8, 16, 32, 64, 120, 240, 480, 600, 600, 600, 600, and 600. The default is 600.
    • exclude_inactive. Select this option to prevent syncing devices to ServiceNow that are disabled, unavailable, or in maintenance. By default, this field is not selected.
    • enable_device_active. Select this option to enable the Device Active block in the device GraphQL query, which contains information about the active state of the Skylar One device. By default, this field is not selected. Accessing this data in the attribute mappings requires a Jinja2 Template.
    • enable_asset_networks. Select this option to enable the assetNetworks block in the device GraphQL query, which returns a list of asset networks. By default, this field is not selected. Accessing this data in the attribute mappings requires a Jinja2 Template.
      Please note that enabling this option might cause performance issues on the Skylar One side.
    • retry_jitter. Instead of using a defined interval between retries, the PowerFlow system will retry the step execution at random intervals. The default is unselected.
    • retry_backoff. Instead of using a defined interval between retries, PowerFlow will incrementally increase the interval between retries. The default is unselected.
    • enable_advanced_topology. Toggle on (blue) this option to enable the advanced topology query when you run this application.
    • verify_snow_ssl. Toggle on (blue) this option to enable verification of the SSL certification when you run this application.
    • gql_filter. Using JSON, define a custom GraphQL filter to apply to the devices in the sync. To test a GraphQL filter, go to the GraphiQL interface in Skylar One by typing the URL or IP address for Skylar One in a browser, add /gql to the end of the URL or IP address, and press Enter. Search the built in GraphQL docs for DeviceSearch and determine how to set up your custom filter. An example of a Device Search query using JSON: {"name": {"doesNotBeginWith": "jc-is-ma"}}
    1. The sgc_uri_categories and the sgc_category_overrides sections lets you send specific Skylar One Device Classes to a custom transform target within ServiceNow:
      • In the sgc_uri_categories section, you can map from a category name or a tag to a ServiceNow import table.
      • In the sgc_category_overrides section, you can map from the category names or tags in the first section to Device Classes.
      You can use the default settings in these two sections without making any changes. ScienceLogic recommends that only advanced users edit or create new mappings in these sections. Any Device Classes that are not listed in these sections will be included in the default "Hardware" rule.
    2. Click Save and wait for the "App & Config modifications saved" pop-up message to appear. The Configuration pane automatically closes after this message appears.
    3. Run the "Sync Devices from Skylar One to ServiceNow via SGC" application. If this is the first time you are running this application, run it a second time to build the internal cache.
    Syncing File Systems from Skylar One to ServiceNow
    To perform a File System Sync between Skylar One and ServiceNow, run the following applications in the PowerFlow user interface:
    • Sync File Systems from Skylar One to ServiceNow via SGC. Syncs file systems and their organizations and relationships from Skylar One to ServiceNow.
    To sync Skylar One file systems with ServiceNow:
    2. Select the "Sync File Systems from Skylar One to ServiceNow via SGC" application from the Applications page and click Configure (). The Configuration pane appears:
    • Include_Orgs. If you want to include a specific set of Skylar One Organizations in the sync, add the Organization IDs from the Skylar OneOrganizations page () in this field, separated by commas. If this field is enabled, PowerFlow will pull only the Organizations listed in this field; PowerFlow does not pull all Organizations and then drop those not on the list. Leave this field empty to sync all Skylar One Organizations. Optional.
    • snow_chunk_size. Specify the number of objects to send in each chunk or in each sub-payload with a batch. The default is 2000 objects per chunk or sub-payload.
    • retry_backoff_max. The maximum time interval for the retry_backoff option, in seconds. For example, if you have retry_max set to 15, the delays will be 1, 2, 4, 8, 16, 32, 64, 120, 240, 480, 600, 600, 600, 600, and 600. The default is 600.
    • read_timeout. Specify the maximum amount of time in seconds the application should wait for a response before timing out. The default is 30 seconds.
    • include_hidden. Select this option to sync hidden file systems. This filter is only applied on the Skylar One side of the sync. By default, this option is not selected.
    • sync_unsupported_file_systems. Select this option to send file systems which have a parent device class of Network Switch or Network Router. By default, this option is not selected.
    • include_stale. Select this option to sync stale file systems. This filter is only applied on the Skylar One side of the sync. By default, this option is not selected.
      Be cautious when applying the include options, as enabling one or both options might cause unwanted disconnects if the File System Sync is run with these options enabled and then run with the options disabled.
    1. Run the "Sync File Systems from Skylar One to ServiceNow via SGC" application.
    Syncing Interfaces from Skylar One to ServiceNow
    To perform an Interface Sync between Skylar One and ServiceNow, run the following applications in the PowerFlow user interface:
    • Sync Interfaces from Skylar One to ServiceNow via SGC. Syncs network interfaces and their organizations and relationships from Skylar One to ServiceNow.
    To sync Skylar One network interfaces with ServiceNow:
    2. Select the "Sync Interfaces from Skylar One to ServiceNow via SGC" application from the Applications page and click Configure (). The Configuration pane appears:
    • sl1_chunk_size. Specify the number of interfaces to pull from Skylar One in each chunk. The default is 500.
    • enabled_only. Select this option to only sync interfaces where the administrationStatus field from Skylar One is set to "Up".
    • gql_filter. Using JSON, you can optionally define a custom GraphQL filter to apply to the interfaces in the sync. To test out a GraphQL filter, go to the GraphiQL interface in Skylar One by typing the URL or IP address for Skylar One in a browser, add /gql to the end of the URL or IP address, and press Enter. Search the built in GraphQL docs for InterfaceSearch and determine how to set up your custom filter.
    1. Run the "Sync Interfaces from Skylar One to ServiceNow via SGC" application.
    You can create one or more schedules for a single application in the Skylar Automation user interface. When creating each schedule, you can specify the queue and the configuration file for that application.
    To schedule an application:
    3. To delete the selected schedule, click the Actions icon () and select Delete.
    On the Scheduler window for a Skylar Automation application, you can click the Copy as button from the Schedule List pane to make a copy of an existing schedule.
    Known Issues
    This section covers known issues with this release of the SyncPack.
    Adding or Checking Hosting Dependent Relationships
    Versions of the ServiceNow CMDB CI Class Models application older than version 1.30.0 do not include the following two relationships, which are required for correct mapping:
    cmdb_ci_vcenter_datastore:
    Parent Class Relationship Child Class
    ESX Resource Pool Hosted on::Hosts Logical Datacenter
    cmdb_ci_esx_resource_pool:
    VMware vCenter Datastore Hosted on::Hosts Logical Datacenter
    These two relationships are included in version 1.30.0 and later of the "ServiceNow CMDB CI Class Models" application. You can download the application from the ServiceNow Store.
    In addition, not all classes are mapped. Only a limited set of classes are handled by default. Currently, if not specified, all classes from Skylar One will be sent to the physical hardware import table.
    Known Issue with VMware Sync
    Base ServiceNow Discovery of VMware is incompatible with the VMware mapping in this SyncPack. At the request of ServiceNow, PowerFlow lines up VMware with the cloud management model for mapping, which is different if you do not have the cloud management plugin installed.
    In the future, ServiceNow will update Base ServiceNow discovery for VMware to bring it in line with cloud management mapping.
    For more information about addressing specific issues, see the Troubleshooting chapter.
    Additional Known Issues
    The Physical Robust transform map will filter out devices that do not have virtual type of Physical:
    Virtual Types
    Physical
    Component
    Virtual
    DCMR (PowerFlow-generated)
    Cloud service account (PowerFlow-generated)
    Physical Hardware and Hardware within ServiceNow do not line up exactly. There is some "best guess" handling when OIDs do not match to get the Device close to the correct class in ServiceNow.
    Also, the OID list within ServiceNow and ScienceLogic do not always match up, which might cause some devices to either end up on the hardware table or a "best guess".
