Introduction to the Slack SyncPack
This section describes how you can use the "Slack" SyncPack to automatically create an integration between Skylar One events and Slack channels. The integration is bi-directional between Skylar One and Slack.
This SyncPack uses the "Slack Integration" PowerPack.
The "Slack" SyncPack creates or updates Slack channels with details from Skylar One events, including updates like acknowledging and clearing events. You can also use this SyncPack to retrieve details about Skylar One business services and events, and display them in a Slack channel. The integration is bi-directional between Skylar One and Slack.
You can use the Slack SyncPack to perform the following actions:
  • Create a Slack channel for a Skylar One event: Based on your configuration, a new Slack channel will be created for Skylar One events that meet certain criteria, such as specific device type or event severity.
  • Send Skylar One event notifications to the Slack channel: If changes are made to an event in Skylar One that has a Slack channel associated with it, all users in that channel will receive a notification of the changes to the event. You can add a note to the event, acknowledge it, or resolve it. Additionally, you can click a link to navigate directly to the event in Skylar One.
  • Query devices and services: You can use slash commands such as /service [servicename] or /device [devicename] to retrieve service and device details to display in Slack. For example, typing /service [servicename] triggers the "Query Skylar One Service and Device Details" application in PowerFlow and displays back the Name, Health, Availability, and Risk information for the service in Slack. You can also click a link to navigate directly to the Service Investigator page in Skylar One directly from Slack.
Contents of the SyncPack
This section lists the contents of the "Slack" SyncPack.
PowerFlow Applications
  • Create Slack channel For Skylar One Event. This application creates a channel in Slack based on the event severity configured in Skylar One and will post the event to the created channel.
  • Notify Skylar One Event to new Slack Channel. This application creates a notification in a Slack channel from a Skylar One event.
  • Notify Skylar One Event to existing Slack Channel. This application sends a notification to Slack of a "Major" event in Skylar One
  • Query Skylar One Service and Device details. This application allows you to query Skylar One for service and device details from the Slack channel that ships with the SyncPack.
  • Sync Skylar One Event status from Slack. This application synchronizes an event update made in Slack with the event status in Skylar One.
For more information about how to configure these applications, see Configuring Applications for the Slack SyncPack.
Steps
  • Create Slack Channel
  • Create Skylar One Payload
  • Delete Event from Skylar One
  • Fetch Channel ID From Name
  • Fetch Slack Email
  • Invite Users To Channel
  • Post Event block To Slack
  • Post event details To Channel
  • Post Update To Skylar One
  • Process Slash Command
  • Receive Slack User Input Data
  • Slash Command Parse Args
Configuration Object
  • Sample Slack Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system.
