Introduction to the ThousandEyes SyncPack
This section describes how you can use the "ThousandEyes" SyncPack to automatically trigger Skylar One events from ThousandEyes alerts. The integration is asynchronous, from ThousandEyes to Skylar One.
The "ThousandEyes" SyncPack processes ThousandEyes alert data and creates a Skylar One event. The integration is asynchronous, from ThousandEyes to Skylar One.
This SyncPack let you connect issues detected by ThousandEyes to Skylar One Behavioral Correlation and incident management workflows.
Contents of the SyncPack
This section lists the contents of the "ThousandEyes" SyncPack.
PowerFlow Applications
  • ThousandEyes: Process Alert. This application processes ThousandEyes alert data and creates a Skylar One event.
For more information about how to configure these applications, see Configuring the ThousandEyes Application.
Configuration Object
  • ThousandEyes Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to the Skylar One database, including the URL, username, and password
  • Details for converting ThousandEyes alerts into Skylar One events including event and yname format, device matching, default device, and custom attribute matching
Steps
  • Get Alert Data From ThousandEyes
  • Transform ThousandEyes Alert Data to Skylar One Event
  • Trigger ThousandEyes Event Payload
