Prerequisites for the SyncPack
- The latest "Webex Automations" PowerPack
- Administrator access to SL1
- Webex administrator access
For the latest System Requirements, see the SL1 PowerFlow SyncPack Release Notes.
PowerFlow | Webex API | Any | TCP 443 | Webex API Access |
Downloading and Installing the Webex SyncPack
Downloading the SyncPack
- Click the PowerPacks & SyncPacks. tab and select
- In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
- On the SyncPack version that you want to install, and select Show File Details. The Release File Details page appears. tab, click the down arrow next to the
- Click the SyncPack. button to download the
Importing the SyncPack
- On the SyncPacks page (
Installing the SyncPack
If you do not see the SyncPack that you want to install, click the Filter icon (
) appears.
Installing the Webex Automation PowerPack
The "Webex Automations" PowerPack includes run book automation policies and actions that create channels and trigger event updates between SL1 and Webex.
The "Webex Automations" PowerPack requires SL1 version 11.1.0 or later. For details on upgrading SL1, see the SL1 Platform Release Notes.
