The following workflows describe how to configure Skylar One and PowerFlow to work with the "Webex" SyncPack.
Configuring Webex
Configuring Skylar One
- Edit the Webex run book actions
- Enable the Webex run book automations
Configuring PowerFlow
- Align the configuration object and configure the Webex PowerFlow applications
Configuring Webex
The following topics cover how to set up Webex to work with the SyncPack.
Creating a Bot in Webex
Create a bot in Webex:
- Log in to developer.webex.com.
- Select your profile, and then select My Webex Apps.
- Select Create a New App, and then select Create a Bot.
- When you have created the bot, save the access token from the bot. This will be used for posting messages and creating rooms.
- Add the bot that you created to the appropriate team.
Creating a Webhook
Next, you will need to create an API Key in PowerFlow and a webhook in Webex:
- In PowerFlow, go to the API Keys page.
- Select Create API Key and copy the key when it is generated.
- Create the following URL, inserting your PowerFlow IP address and the API key from step 2 where indicated:
- Go to Webhooks - Create a Webhook | Webex for Developers.
- Use the Bot token in Authorization while creating the webhook using the API.
- Add the following parameter values:
https://<Your PowerFlow IP Address>/api/v1/applications/sync_event_status_from_webex_to_sl1/run?PF-APIKEY=<API Key>
- targetUrl. Use the URL you created using your API key.
- resource. attachmentActions
- event. created
The following topics cover how to set up your Skylar One instance to work with the "Webex" SyncPack.
You will need to create a SOAP/XML credential so that the automation actions included in the "Webex Automations" PowerPack can access your PowerFlow system. The "Webex Automations" PowerPack includes the "PowerFlow Webex Teams" credential, which you can use as a template for the SOAP/XML credential.
- In Skylar One, go to the Credentials page (Manage > Credentials).
- Click the wrench icon (
) for the "PowerFlow WebexTeams" credential. The Credential Editor modal window appears: - Complete the following fields:
- Take note of the Skylar One-assigned ID number for the new credential on the Credentials page, in the ID column. You will need the ID number when editing the input parameters of the run book actions included in the PowerPack, below.
Editing the Webex Run Book Actions
The "Webex Automations" PowerPack includes run book actions that use the "Run Integration Service Application" action type to trigger the PowerFlow applications that send and receive data to and from Webex. You can specify the credential ID in a JSON structure that you enter in the Input Parameters field in the Action Policy Editor modal.
- In Skylar One, go to the Actions page (Registry > Run Book > Actions).
Enabling the Webex Run Book Automations
The "Webex Automations" PowerPack includes six standard automation policies that you will need to enable. These policies create Webex channels, acknowledge or clear Webex room notifications, and update Skylar One events created from Webex.
The following table shows the run book automation policy, its aligned events, and the run book action that runs in response to the events.
| Webex: Create Channel |
All Events |
Webex: Create Room |
| Webex: Created Room Notification - Acknowledge |
All Events |
| Webex: Created Room Notification - Clear |
All Events |
| Webex: [Events] - Acknowledge |
All Events |
Webex: Acknowledge |
| Webex: [Events] - Add/Update |
All Events |
Webex: Add/Update |
| Webex: [Events] - Cleared |
All Events |
Webex: Clear |
- In Skylar One, go to the Automation page (Registry > Run Book > Automation).
- Locate a Webex run book automation policy and click its wrench icon (
- Available Actions. If it is not already selected, select the "Run Integration Service Application: <name>" action that corresponds with the Webex automation policy you selected in step 2, and click the arrows to move it to Aligned Actions.
- Repeat steps 2-4 for the remaining Webex run book automation policies.
The following topics cover how to set up your PowerFlow instance to work with the "Webex" SyncPack.
For this SyncPack, you can make a copy of the " Config" configuration object, which is the sample configuration file that was installed with the Webex SyncPack. Then you need to align that configuration object to the relevant applications.
The "Sample Webex Config" configuration object contains all of the required variables. Simply update the variables from that object to match your Skylar One and Webex settings.
To create a configuration object based on the "Sample Webex Config" configuration object:
Click the button (
) for the "Sample Webex Config" configuration object and select Edit. The Configuration pane appears.
- sl1_host. The hostname or IP address of the Skylar One system the alerts will synchronize to.
- sl1_user. The username for your Skylar One system.
- sl1_password. The password for your Skylar One system.
- token. Webex bot token.
- default_ack_user. The default user to acknowledge events and alerts.
- team_id. ID of the team to create the channel for.
- users. Comma-separted list of Webex user emails to invite to the created channel.
- room_id. ID of the room to post messages in.
With this SyncPack, any status changes made to a Skylar One event is sent to Webex to update the corresponding alert. Any status changes to the Webex alert are synced back to the corresponding Skylar One event.
- Create Room For Event"
- "Created Room Event Notification"
- "Major Event Notification"
- "Sync Event Status From Webex To Skylar One"
) are populated either by the configuration object you aligned with the application or by the run book action. Do not modify these values. If you encounter an error, make sure your run book action is configured properly.
To create a schedule:
- On the Applications page (
- Click the down arrow icon (
) and select.
When either multiple Skylar One instance or multiple Webex instances are involved with PowerFlow, you should create an individual configuration object for each Skylar One or Webex instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single Skylar One or Webex instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
