- A subscription that includes CMDB/Inventory Workflow Automations
PowerFlow | Infoblox API | Any | TCP 443 | Infoblox API Access |
Contents of the SyncPack
This section lists the contents of the Infoblox: Inventory SyncPack.
PowerFlow Applications
- Get Device List From Infoblox and Add To SL1. This application queries Infoblox for existing IP addresses and if an IP address does not exist in SL1, a discovery session will be triggered and the device will be added to SL1.
- Get Device List From SL1 Add To Infoblox. This application queries SL1 via discovery session for recently added devices. If a device does not exist in Infoblox, the IP address will be added to Infoblox.
- Get Mismatched IP List. This application queries both Infoblox and SL1 for matching device names. If a device in SL1 and Infoblox has the same name but different IP addresses, an event will be generated in SL1.
- Update Infoblox Id. This application queries both Infoblox and SL1 for existing devices in SL1 and matching IP addresses in Infoblox. SL1 devices that match an IP address in Infoblox are assigned an Infoblox ID in a custom attribute in SL1.
For more information about how to configure these applications, see Configuring Applications for the Infoblox: Inventory SyncPack.
Configuration Object
- Infoblox Base Config. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
- Details for connecting to SL1, including the host, username, and password
- Details for connecting to Infoblox, including the URL, username, and password
- Details for adding SL1 devices to Infoblox, including zone name, time period, and custom attribute
- Details for adding Infoblox IP addresses to SL1, including organization ID, credentials, device group, device template, ports, and time period
Steps
- Active Discovery Session
- Add Data To Custom Attribute
- Add new Device To Infoblox
- Checking Infoblox Record
- Checking Infoblox Id
- Create Custom Attribute
- Create Discovery Session
- Create SL1 Alert
- Get SL1 Device List
- Get Custom Attribute
- Get Device Details
- Get Discovery Session Log
- Get Infoblox Device Reference Id
- Get Infoblox Host List
- Get Infoblox Host Records
- Get IP List From Infoblox
- Get SL1 All Devices List
- Get SL1 Device Details
Installing the SyncPack
Downloading the SyncPack
- Click the .zip file containing the .whl file for this SyncPack to start downloading the file. button or click the name of the
If you are installing or upgrading to the latest version of this SyncPack in an offline deployment, see "Installing or Upgrading in an Offline Environment" in the SyncPack release notes to ensure you install any external dependencies.
Importing the SyncPack
- On the SyncPacks page (
) appears.
