Introduction to the Jenkins Automation PowerPack
This section describes the Run Book Automation policies and Run Book Action policies found in the Jenkins Automation  PowerPack.
This PowerPack requires a subscription that includes CMDB/Inventory Workflow Automations.
What is the Jenkins Automation PowerPack?
The Jenkins Automation PowerPack includes automation policies and action policies that bidirectionally sync jobs, pipeline jobs, and node status between Jenkins and SL1.
Installing the Jenkins Automation PowerPack
Before completing the steps in this section, you must import and install the latest version of the Jenkins Automation  PowerPack.
IMPORTANT:: You must install and configure the Jenkins SyncPack version 1.0.0 before using the Jenkins Automation PowerPack.
The Jenkins Automation  PowerPack requires SL1 version 11.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
