For this SyncPack, you should make a copy of the "Base Jenkins Configuration" configuration object, which is the sample configuration file that was installed with the Jenkins SyncPack.
The "Base Jenkins Configuration" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Jenkins settings.
To create a configuration object based on the "Base Jenkins Configuration" configuration object:
Click the
) for the "Base Jenkins Configuration" configuration object and select Edit. The Configuration pane appears:
button (
- Click Create Configuration pane appears. . The
- jenkins_url. Enter the URL for your Jenkins system.
- jenkins_username. Type the username for your Jenkins system.
- jenkins_password. Type the password for your Jenkins system.
- job_name. Type the name for your Jenkins job.
- receiver_mail. Type the email address that you want to receive updates on SL1 events and your Jenkins jobs.
- sender_mail. Type the email address that you want updates on SL1 events and your Jenkins jobs to send from.
- sender_mail_password. Type the password for the sender email address that you entered.
- mailserver. Type the server for your sender email.
- mailserverport. Type the port for your sender email.
- node_device_class_id. Type the device class ID for your Jenkins instance.
- job_device_class_id. Type the device class ID for your Jenkins job.
- guid_node_major_event. Enter the GUID of the SL1 event policy.
- collector_group_id. Type the collector group ID for your Jenkins instance.
- device_id. Type the device ID for your Jenkins instance.
- guid_job_major_event. Enter the GUID of the SL1 event policy.
- guid_job_trigger_event. Enter the GUID of the SL1 event policy.
- guid_pipeline_job_major_event Enter the GUID of the SL1 event policy.
For more information about the Jenkins terms and concepts in this section, see the Jenkins documentation.
With this SyncPack, you can create SL1 events based on Jenkins jobs. You will need to align the Jenkins SyncPack applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
To trigger the applications in the SyncPack, you must schedule the PowerFlow applications that are included in the SyncPack:
To schedule an application:
On the Applications page (
When either multiple SL1 instances or multiple Jenkins instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Jenkins instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Jenkins instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
