Introduction to the Jira Service ManagementSyncPack
This section describes how you can use the Jira Service Management SyncPack to automatically synchronize Jira issues and SL1 events between Jira and SL1 systems. The integration is bidirectional, betweenSL1 and Jira.
  • A subscription that includes CMDB/Inventory Workflow Automations
  • Base Steps SyncPack version 1.3.2 or later
  • SL1 Notifications Base SyncPack version 1.0.1 or later
  • Administrator access to Jira
  • An IT Service Management Jira project to integrate with SL1
PowerFlow Jira API Any TCP 443 Jira API Access
PowerFlow SL1 Database Any TCP 7706 SL1 Database Access
Contents of the SyncPack
This section lists the contents of the Jira Service Management SyncPack.
PowerFlow Applications
  • Acknowledge SL1 Event. This application adds a comment to the associated Jira incident when an event is acknowledged in SL1.
  • Resolve SL1 Event from Jira. This application resolves an SL1 event when the associated Jira incident is closed.
  • Create Incident/Change Request in Jira from SL1 Event. This application creates an incident or change request in Jira when an event is triggered in SL1.
  • Show Jira Change Log in SL1 Event Notes. This application collects a summary of Jira incident data and adds the data to the event notes of the associated SL1 event.
For more information about how to configure these applications, see Configuring Applications for the Jira Service Management SyncPack.
Configuration Object
  • Jira ITSM Configuration. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to SL1, including the host, username, and password.
  • Details for connecting to Jira, including the URL, username, password, and API token.
  • Details for connecting SL1 events to your Jira issues, including project, event URL, severity, account, and request type ID. Other details include issue type, project key, priority, ticket descriptions, and impact.
  • Details for severity mapping.
Steps
  • Create Jira Incident
  • Get Closed Issues and Clear the SL1 Events
  • Get Jira Issue
  • Get Jira Log
  • Post Update To SL1
  • Read Event Id and Jira Key
  • Update Incident Details To SL1
  • Update SL1 Note
Installing the SyncPack
Downloading the SyncPack
  1. Go to the ScienceLogic Support Site.
  3. In the Search PowerPacks field, search for the SyncPack and select it from the search results. The Release Version page appears.
  4. On the PowerPack Versions tab, click the name of the SyncPack version that you want to install. The Release File Details page appears.
  5. Click the Download File button or click the name of the .zip file containing the .whl file for this SyncPack to start downloading the file.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see the following topic.
