Introduction to the Low-code Tools PowerPack
This section describes how to use the "Low-code Tools" PowerPack.
The "Low-code Tools" PowerPack is part of the Skylar One Studio suite of tools. For more information, see https://support.sciencelogic.com/s/skylar-one/skylar-one-studio.
What is the Low-code Tools PowerPack?
The "Low-code Tools" PowerPack provides the Snippet Framework, which is the standard way to write Dynamic Applications using Snippet Arguments to define what information to collect, how to collect it, where to get the data, and how to interpret it. This process is Snippet Argument driven, meaning that you direct the Snippet Framework using Snippet Arguments in a Dynamic Application.
The "Low-code Tools" PowerPack is a single, consolidated version of the "CLI: Toolkit", "Prometheus: Toolkit", and "REST: Toolkit" PowerPacks. You can perform all of the same functions in the "Low-code Tools" PowerPack as you would in any other PowerPacks toolkits. This PowerPack contains REST, CLI and Prometheus tools for building Dynamic Applications.
What Does the Low-code Tools PowerPack Include?
The "Low-code Tools" PowerPack provides a single comprehensive toolkit with specialized steps for simplified monitoring and data collection. This unified toolkit enables users to build monitoring solutions across multiple protocols with minimal coding requirements.
The "Low-code Tools" PowerPack includes the following features:
Installing the Low-code Tools PowerPack
Before you can use the Snippet Framework, you must import and install the latest version of the "Low-code Tools" PowerPack.
  3. In the PowerPack Manager page, click the Actions button, then select Import PowerPack.
  4. The Import PowerPack dialog box appears.
  5. Click the [Browse] button and navigate to the PowerPack file.
  6. When the PowerPack Installer modal appears, click the Install button to install the PowerPack.
If you exit the PowerPack Installer without installing the imported PowerPack, the imported PowerPack will not appear in the PowerPack Manager page. However, the imported PowerPack will appear in the Imported PowerPacks page. This page appears when you click the Actions menu and select Install PowerPack.
Documentation for the Low-code Tools PowerPack
Full documentation for the "Low-code Tools" PowerPack is provided at the following location:
https://docs.sciencelogic.com/dev-docs
