After you have integrated your Opsgenie and SL1PowerFlow systems, you must create a SOAP/XML credential so that the automation actions included in the Opsgenie Incident IntegrationPowerPack can access your SL1PowerFlow system. The Opsgenie Incident IntegrationPowerPack includes a template for a SOAP/XML credential that you can edit for use with your PowerFlow system.
- Click the wrench icon (
) for the PowerFlow Opsgenie credential. The Credential Editor modal window appears:
- Profile Name. Type a new name for the credential.
- URL. Type the URL for your SL1PowerFlow system.
- HTTP Auth User. Type the username for your SL1PowerFlow user account.
- HTTP Auth Password. Type the password for your SL1PowerFlow user account.
- Click the button to save the new SOAP/XML credential.
- SL1 assigns the credential an ID number. Take note of the ID number that appears in the Credential Editor heading, as you will need this when editing the input parameters of the automation actions included in the Opsgenie Incident IntegrationPowerPack.
