Introduction to the Opsgenie Incident Integration PowerPack
This section describes how to use the automation policies and automation actions found in the Opsgenie Incident Integration PowerPack.
This PowerPack requires a subscription to ScienceLogic Standard solutions.
What is the Opsgenie Incident Integration PowerPack?
The Opsgenie Incident IntegrationPowerPack includes automation policies and actions that bidirectionally aligns alerts and events triggered and updated in Opsgenie and SL1.
Installing the Opsgenie Incident Integration PowerPack
Before completing the steps in this section, you must import and install the latest version of the Opsgenie Incident IntegrationPowerPack.
IMPORTANT: You must install and configure the Opsgenie SyncPack version 1.0.0 before using the Opsgenie Incident Integration PowerPack.
The Opsgenie Incident Integration PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
