For this SyncPack, you can make a copy of the "Opsgenie Config" configuration object, which is the sample configuration file that was installed with the OpsgenieSyncPack.
The "Opsgenie Config" configuration object contains all of the required variables. Simply update the variables from that object to match your SL1 and Opsgenie settings.
To create a configuration object based on the "Opsgenie Config" configuration object:
Click the button (
) for the "Opsgenie Config" configuration object and select Edit. The Configuration pane appears:
Click . The Create Configuration pane appears.
- opsgenie_api_key. The API key for the Opsgenie Team that you want to send alerts to.
- opsgenie_univ_api_key. The universal API key for Opsgenie.
- proxy_host. The hostname or IP address of the HTTP proxy that will be used when making an API request to Opsgenie.
- proxy_protocol. The protocol of the HTTP proxy. Enter either 'HTTP' or 'HTTPS'.
- sl1_host. The hostname or IP address of the SL1 system the alerts will synchronize to.
- schedule_name. The name of the on-call schedule on Opsgenie to query when collection the current on-call user(s).
- maintenance_description. The description of your Opsgenie maintenance.
- maintenance_policy_id. The ID of your Opsgenie maintenance.
- maintenance_time_length. The time configuration of your Opsgenie maintenance.
- maintenance_state. The state rule defined in maintenance.
- device_id. The SL1 device ID that the Opsgenie Heartbeat application will use when sending alerts. Typically, this is a device that represents the Opsgenie service.
- heartbeat_name. The name of your Heartbeat URL.
- opsgenie_base_url. The base URL of the Alert Rest API.
- opsgenie_private_instance_url. The URL to use for links to the Opsgenie user interface. Enter the base URL you navigate to. This URL will be displayed in SL1 and will open your Opsgenie instance in a browser.
- resolve_from_org. The option to resolve events from Opsgenie
- default_ack_user. The default user to acknowledge events and alerts.
- populate_external_url. The option to add an Opsgenie incident URL to the corresponding SL1 event.
You can generate an API key for SL1 to use in the Integrations page of the Opsgenie Teams user interface.
For information on adding an API key in Opsgenie, see https://support.atlassian.com/opsgenie/docs/api-key-management/.
With this SyncPack, any status changes made to an SL1 event is sent to Opsgenie to update the corresponding alert. Any status changes to the Opsgenie alert are synced back to the corresponding SL1 event. You will need to align the Opsgenie applications with the relevant configuration object in PowerFlow, and, if needed, update any other fields on the Configuration pane for the applications.
- "Bulk Clear SL1 Events"
- "Create Opsgenie Maintenance"
- "Get Oncall Details From Opsgenie and Send to SL1"
- "Opsgenie Heartbeat"
- "Pass Acknowledgment details from Opsgenie to SL1"
- "Close Opsgenie Alert"
- "Save Accounts To Cache"
- "Create Alert in Opsgenie from a received SL1 event"
- Wait until you see the "App & Config modifications saved" pop-up message before proceeding.
To trigger some applications in this SyncPack, you must schedule the application. If you want to use the following applications, you must schedule the application:
| PowerFlow Application | Recommended Schedule Time |
| Bulk Clear SL1 | Every minute |
| Opsgenie Heartbeat | Every 5 minutes |
| Pass Acknowledged Alerts from Opsgenie to SL1 | Every minute |
| Save Accounts To Cache | Every hour |
To schedule an application:
On the Applications page (
Click . The schedule is added to the list of schedules on the initial Schedule window. Also, on the Applications page, the word "Scheduled" appears in the Scheduled column for this application, and the button contains a check mark:
When either multiple SL1 instance or multiple Opsgenie instances are involved with PowerFlow, you should create an individual configuration object for each SL1 or Opsgenie instance. Next, create an individual schedule for each configuration object. Each schedule should use a configuration object that is specific to that single SL1 or Opsgenie instance. Creating copies of a PowerFlow application from a SyncPack for the purpose of distinguishing between domains is not supported, and will result in issues on upgrades.
