This PowerPack requires a subscription to ScienceLogic Standard solutions.
What is the PagerDuty Incident Integration PowerPack?
The PagerDuty Incident IntegrationPowerPack includes automation policies that align incidents triggered and updated in PagerDuty to events in SL1. The PowerPack also includes an automation action that is executed on the SL1 Database Server.
In addition to using the standard content, you can use the content in the PagerDuty Incident Integration PowerPack to:
- Create your own automation policies that include the pre-defined action that runs different sets of diagnostic commands.
- Use the supplied "Run Integration Service Application" custom action type to configure your own automation action by supplying a set of commands.
Installing the PagerDuty Incident Integration PowerPack
IMPORTANT: You must install and configure the PagerDuty SyncPack version 1.0.0 before using the PagerDuty Incident Integration PowerPack.
The PagerDuty Incident Integration PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
