Introduction to the xMatters Incident Integration PowerPack
This section describes how to use the automation policies and automation actions found in the xMatters Incident Integration PowerPack.
This PowerPack requires a subscription to ScienceLogic Standard solutions.
What is the xMatters Incident Integration PowerPack?
The xMatters Incident IntegrationPowerPack includes automation policies and actions that bidirectionally aligns alerts and incidents triggered and updated in xMatters and SL1.
Installing the xMatters Incident Integration PowerPack
Before completing the steps in this section, you must import and install the latest version of the xMatters Incident IntegrationPowerPack.
IMPORTANT: You must install and configure the xMatters SyncPack version 1.0.0 before using the xMatters Incident Integration PowerPack.
The xMatters Incident Integration PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the appropriate SL1 Release Notes.
