Introduction to the xMattersSyncPack
This section describes how you can use the "xMatters" SyncPack to automatically trigger, acknowledge, and resolve SL1 events and xMatters incidents between your xMatters and SL1 systems. The integration is bi-directional and synchronizes SL1 and xMatters.
This SyncPack requires the Base Steps and SL1 Notifications Base SyncPacks.
  • A subscription to the SL1 Standard solution
  • Base Steps SyncPack version 1.3.2
  • SL1 Notifications Base SyncPack version 1.0.0
PowerFlow SL1 Database Any TCP 7706 SL1 Database Access
Contents of the SyncPack
This section lists the contents of the xMattersSyncPack.
PowerFlow Applications
  • Bulk Resolve SL1 Events. This application collects resolved incident data from xMatters and clears the corresponding SL1 event. To use this application, the incident description must include the event ID.
  • Get Acknowledged Incidents and Post Data to SL1. This application collects acknowledged incident data from xMatters and acknowledges the corresponding SL1 event. To use this application, the incident description must include the event ID and you must run the "Save Accounts To Cache" application.
  • Get Event Details and Post Incident URL to SL1. This application collects event details from SL1 and creates a new incident in xMatters. This application can optionally populate the External Ticket ID field with a link to the xMattersincident.
  • Get Oncall Details and Post Oncall List to SL1. This application collects xMatters oncall details and populates the corresponding SL1 event notes with oncall details.
  • Pass Acknowledgment details from SL1 to xMatters. This application collects acknowledged event data from SL1 and updates the corresponding xMatters incident. To use this application, the incident description must include the event ID.
  • Pass Resolution to xMatters from RBA. This application collects resolved event data from SL1 and updates the corresponding xMatters incident. To use this application, the incident description must include the event ID.
  • Save Accounts to Cache. This application collects user details from SL1. The user's email address is used by the "Pass Acknowledgment details from xMatters to SL1" application to match the acknowledging user in xMatters to the SL1 user.
For more information about how to configure these applications, see Configuring and Aligning a Configuration Object in PowerFlow.
  • Xmatters Config Template. This configuration object can be used as a template after the SyncPack is installed on the PowerFlow system. The configuration object includes the following:
  • Details for connecting to the SL1 API, including the URL, username, and password
  • Details for connecting to the xMatters API, including the API webhook, instance URL, group ID, username, and password.
  • Details for connecting to an HTTP Proxy when communicating with xMatters, including the hostname or IP address, username, and password
  • Mapping between SL1 events and xMatters incidents including, the default acknowledged user, whether an xMatters link should be added to the SL1 event, and whether an event should be resolved from xMatters.
Steps
  • Accounts to URI Mapping
  • Create Bulk SL1 Payloads
  • Converting Xmatters Incident Response into SL1 Payload
  • Post Event Details To Xmatters
  • Get Acknowledger Details From XM
  • Get Acknowledgment From SL1 And Pass to Xmatters
  • Get Event Details from SL1 Create Xmatters Alert
  • Get Resolved Incidents And Pass To SL1
  • Get Oncall Details from Xmatters
Installing the SyncPack
Downloading the SyncPack
  2. Click the Product Downloads tab and select PowerPacks & SyncPacks.
  3. In the Search field, search for the SyncPack and select it from the search results. The Release Version page appears.
Importing the SyncPack
  4. You will need to activate and install the SyncPack in PowerFlow. For more information, see the following topic.
