What is the HTTP Action Type PowerPack?
The HTTP Action Type PowerPack contains an automation action template that can be used to create custom automation actions that perform HTTP requests. The PowerPack also includes action types that are used by the automation action.
Installing the HTTP Action Type PowerPack
Ensure that you are running version 12.1.2 or later of SL1 before installing this PowerPack. For details on upgrading SL1, see the relevant SL1 Platform Release Notes.
