You can use the run book actions in this PowerPack to collect additional diagnostic information when events occur and to provide instructions on how to troubleshoot issues. This additional information about an event is intended to assist the engineer responsible for troubleshooting and resolving that event.
What is the Datacenter Advanced Enrichment Actions PowerPack?
The "Datacenter Advanced Enrichment Actions" PowerPack contains run book actions that you can use with run book automations to collect additional diagnostic information when events occur and to provide instructions on how to troubleshoot issues. This additional information about an event is intended to assist the engineer responsible for troubleshooting and resolving that event.
What Technologies are Supported?
The "Datacenter Advanced Enrichment" PowerPack contains over 350 run book actions that define different diagnostic information to be collected. In other words, you can execute over 350 different sets of commands with this PowerPack. Each set of commands is specific to a type of device.
The following table lists the number of command sets for each type of device:
| Device Type | Number |
| Cisco ACE | 2 |
| Cisco CSP | 2 |
| Cisco Route/Switch | 33 |
| Cisco IOS | 80 |
| Cisco IOS-XE | 33 |
| Cisco IOS-XR | 35 |
| Cisco NSO | 3 |
| Cisco NX-OS | 12 |
| Cisco OLT | 1 |
| Cisco StarOS | 32 |
| Cisco Collaboration | 3 |
| Cisco Unified Communication Manager | 20 |
| Cisco UCS | 17 |
| Cisco UCS C-Series | 17 |
| Cisco Wireless | 18 |
| Citrix NetScaler | 10 |
| F5 | 21 |
| Juniper JUNOS | 3 |
| Juniper ScreenOS | 3 |
| NetApp | 3 |
Unsupported Configurations
The following configurations are not supported by the "Datacenter Advanced Enrichment Actions" PowerPack:
- Customer-created run book actions that build command lists to be executed by the "Enrichment: Util: Collect Enrichment Data" run book action are not supported without prior authorization from ScienceLogic.
- Modifications of any kind to the code supplied in the "Datacenter Advanced Enrichment Actions" PowerPack are not supported without prior authorization from ScienceLogic.
Overview of Configuring the PowerPack
There are two general steps you need to take to configure the content in the "Datacenter Advanced Enrichment Actions" PowerPack:
- Configure one or more run book automation policies that use the run book actions included in the PowerPack. This is described in the Creating Run Book Automation Policies chapter.
- Configure credentials for the devices that are aligned with the run book automation policies. This is described in the Configuring Device Credentials chapter.
Installing the Datacenter Advanced Enrichment Actions PowerPack
