Introduction to the Linux SSH Automations PowerPack
This section describes how to use the automation policies and run book actions in the "Linux SSH Automations" PowerPack to enrich problematic events with additional diagnostic information for monitored Linux devices.
This PowerPack can retrieve diagnostic data such as CPU, file system, and memory data, as well as interface configurations. Each set of data has its own associated policies and actions that run automatically in response to relevant events.
This PowerPack is intended to be used in conjunction with the "Linux Base Pack" PowerPack.
What is the Linux SSH Automations PowerPack?
The "Linux SSH Automations" PowerPack includes run book automation policies that:
  • Enrich Skylar One events for Linux devices (for example, from the "Linux Base Pack" PowerPack and native SNMP collection) by automatically running diagnostic commands using a remote SSH connection. The command output is added to the Skylar One event log or associated incident. Supported events include CPU, swap, file system, interface, and system process issues.
  • Run remediation commands using a remote SSH connection in response to Skylar One system process events for Linux devices in the "Linux Automation" device group.
The Linux SSH run book actions are executed on the Skylar One All-In-One Appliance or Data Collector.
In addition to using the standard content, you can use the content in the "Linux SSH Automations" PowerPack to:
  • Create your own run book automation policies that include the pre-defined actions that run different sets of diagnostic commands.
  • Use the supplied "Execute Shell Commands" custom action type to configure your own run book action by supplying a set of commands to be executed via SSH.
The automation policies in this PowerPack can also be used as "User-Inititated" Automations.
Installing the Linux SSH Automations PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Linux SSH Automations" PowerPack.
This PowerPack requires version 200 of the "Datacenter Automation Utilities "PowerPack.
This PowerPack also requires Skylar One version 12.1.2 or later. For details on upgrading Skylar One, see the appropriate Skylar One Release Notes.
