This PowerPack is available with a ScienceLogic SL1 Standard solution. Contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
What is the Network Connectivity Automations PowerPack?
The Network Connectivity Automations PowerPack enriches SL1 network connectivity events, such as availability and latency issues, by automatically running common network diagnostic commands and adding the output to the SL1 event log or an associated incident. This PowerPack includes custom action types for running ping, traceroute, nslookup, and nmap commands with parameters that you specify. The PowerPack also includes two dynamic device groups for IPv4 devices and IPv6 devices.
The Network Connectivity Automations PowerPack does not contain or require credentials to operate. The Network Connectivity Automations actions are executed from the SL1 All-In-One Appliance or Data Collector.
Installing the PowerPack
The Network Connectivity Automations PowerPack requires SL1 version 8.10.0 or later. For details on upgrading SL1, see the appropriate SL1Release Notes.
You must install version 101 of the Datacenter Automation Utilities PowerPack before proceeding.
To use the standard automation policies, no other configuration is necessary. These automation policies run in response to network connectivity-related events that are included in SL1.
