This PowerPack is intended to be used in conjunction with the "VMware: vSphere Base Pack" PowerPack.
What is the VMware Automation PowerPack?
The "VMware Automation" PowerPack includes the following content:
- Run book automation policies that are triggered when events from the "VMware: vSphere Base Pack" PowerPack occur:
- VMware Automation: Get vCenter Service Logs
- VMware Automation: Get VMKernel Log and Syslog
- VMware Automation: Get VMware hostd and vCenter Agent ESXi Logs
- Run book actions that you can configure to collect additional diagnostic information when events occur:
- Get All Available VMware Diagnostic Logs. This action attempts to retrieve the last 10 lines of data from all available log files on the target device (vCenter root device).
- Get vCenter Service Logs. This action attempts to retrieve the last 50 lines from the vpxd.log file.
- Get VMware hostd and vCenter Agent ESXi Logs. This action attempts to retrieve the last 50 lines from the hostd.log file and vpxa.log file.
- Get VMware VMKernel Log and Syslog. This action attempts to retrieve the last 50 lines of data from the vmkernel.log and syslog.log log files on the target device (vCenter root device).
- A custom action type that you can use to create new run book actions:
- Get VMware Diagnostic Logs
The "VMware Automation" run book actions are executed on the Skylar One All-In-One Appliance or Data Collector.
In addition to using the standard content, you can use the content in the "VMware Automation" PowerPack to:
- Create your own automation policies that include the pre-defined action.
- Use the supplied "Get VMware Diagnostic Logs" custom action type to configure your own run book action by supplying a set of parameters for diagnostic log collection.
The automation policies in this PowerPack can also be used as "user-inititated" automations.
Installing the VMware Automation PowerPack
You must also install version 201 of the "Datacenter Automation Utilities" PowerPack, which provides the output formats for the run book actions included in this PowerPack.
If you have the "VMware: vSphere Base Pack" PowerPack installed and are monitoring your VMware devices, no other configuration is necessary. The automation policies in the "VMware: vSphere Base Pack" PowerPack will run in response to aligned events.
