This PowerPack is available with a ScienceLogic SL1 Standard solution. Contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
What is the Windows PowerShell User-Initiated Automations PowerPack?
The Windows PowerShell User-Initiated Automations PowerPack includes automation policies that you can use to run Windows diagnostic commands from the SL1 event console , using Event Tools. This PowerPack is supplemental to the Windows PowerShell Automations PowerPack and is not meant for standalone use.
In addition to using the standard content, you can customize the automation policies, or you can create your own automation policies using any available automation actions.
Installing the Windows PowerShell User-Initiated Automations PowerPack
The Windows PowerShell User-Initiated Automations PowerPack requires SL1 version 10.1.0 or later. For details on upgrading SL1, see the appropriate SL1Release Notes.
You must also install the Datacenter Automation Utilities PowerPack, which provides the output formats for the automation actions included in this PowerPack.
Standard Automation Policies
The Windows PowerShell User-Initiated Automations PowerPack includes standard automation policies that trigger automation actions that will run Windows diagnostic commands from the SL1 event console.
The automation policies available in this release of the PowerPack are tied to included ScienceLogic SL1 events generated by the Dynamic Applications from the Microsoft: Windows Server PowerPack.
The automation policies are of Policy Type, "User Initiated". This means that for an event that matches the criteria, you can run these automation policies from the Event Console.
For these automation policies to be visible from the Event Tools in the Event's drawer, the following three things must be true between the event and the automation policy configuration:
- Organization. The organization associated with the event must match the organization configured in the automation policy. Policies in the "System" organization match all organizations.
- Aligned Devices. The device for which the event is triggered must be configured as a Aligned Device in the automation policy.
- Aligned Event. The event must match one of the Aligned Events configured in the automation policy.
The following table shows the automation policies, their aligned events, and the automation actions that run in response to the events.
The aligned events are included as part of the Microsoft: Windows Server PowerPack and are not installed with the SL1 platform. You must install the PowerPack to obtain these events.
| Automation Policy Name | Aligned Events | Automation Action |
| Run CPU & Memory Diagnostics (PowerShell) |
| Run CPU Diagnostics (PowerShell) |
| Run Disk I/O Diagnostics (PowerShell) |
| Run Memory Diagnostics (PowerShell) |
| Run Print Job Error Diagnostics (PowerShell) |
Running a User Initiated Automation Policy
To run a user initiated automation policy, open the drawer for the event and click in the Tools section. Any available user initiated automation policy will be available to run on demand.
Viewing Automation Actions for an Event
The following figure shows a VMware event with major criticality on the Events page. Click the [Actions] button () for an event, and select View Automation Actions to see the automation actions triggered by the events.
The results shown for this event, in the Event Actions Log, include the automation policy that ran (shown at the top of the following figure), along with the collected data. The following figure shows an example of this output.
To learn more about which logs are collected by default for a given automation action, see the Customizing Windows PowerShell Actions section.
Although you can edit the automation policy described in this section, it is a best practice to use "Save As" to create a new automation policy, rather than to customize the standard automation policies.
