Run Book Variables
This appendix defines the different variables you can use when creating an action policy.
This appendix covers the following topics:
Run Book Variables
You can include variables when creating an action policy. These variables are listed in the table below.
Variable
Source
Description
%A Account Username
%a Entity IP address
%F Dynamic Alert Alert ID for a Dynamic Application Alert
%g Asset Asset serial
%h Asset Device ID associated with the asset
%I (uppercase "eye") Dynamic Alert For events with a source of "dynamic", this variable contains the index value from SNMP. For events with a source of "syslog" or "trap", this variable contains the value that matches the Identifier Pattern field in the event definition.
%i (lowercase "eye") Asset Asset Location
%K Asset Asset Floor
%k Asset Asset Room
%L Dynamic Alert Value returned by the label variable in a Dynamic Application Alert.
%m Automation Automation policy note
%N Action Automation action name
%n Automation Automation policy name
%P Asset Asset plate
%p Asset Asset panel
%Q Asset Asset punch
%q Asset Asset zone
%T
Dynamic Alert
Value returned by the Threshold function in a Dynamic Application Alert.
%U
Asset
Asset rack
%u
Asset
Asset shelf
%v
Asset
Asset tag
%W
Asset
Asset make
%w
Asset
Asset model
%V
Dynamic Alert
Value returned by the Result function in a Dynamic Application Alert.
%_category_id
Entity
Device category ID associated with the entity in the event.
%_category_name
Entity
Device category name associated with the entity in the event.
%_class_id
Entity
Device class ID associated with the entity in the event.
%_class_name
Entity
Device class description associated with the entity in the event.
%_parent_id
Entity
For component devices, the device ID of the parent device.
%_parent_name
Entity
For component devices, the name of the parent device.
%_root_id
Entity
For component devices, the device ID of the root device.
%_root_name
Entity
For component devices, the name of the root device.
%_service_investigator_url
Entity
The URL of the Business Service Investigator page for the event that triggered the automation (for run book actions that run against events aligned with business services).
%1 (one)
Event
Entity type. Possible values are:
  • 0. Organization
  • 1. Device
  • 2. Asset
  • 4. IP Network
  • 5. Interface
  • 6. Vendor
  • 7. Account
  • 8. Virtual Interface
  • 9. Device Group
  • 10. IT Service
  • 11. Ticket
%2 Event
Sub-entity type.
Possible values for organizations are:
  • 9. News feed
Possible values for devices are:
  • 1. CPU
  • 2. Disk
  • 3. File System
  • 4. Memory
  • 5. Swap
  • 6. Component
  • 7. Interface
  • 9. Process
  • 10. Port
  • 11. Service
  • 12. Content
  • 13. Email
%4 Event Text string of the user name that cleared the event.
%5 Event Date/time when event was deleted.
%6 Event Date/time when event became active.
%7 Event
Event severity (1-5), for compatibility with previous versions of Skylar One. 1=critical, 2=major, 3=minor, 4=notify, 5=healthy.
NOTE: When referring to an event, %7 represents severity (for previous versions of Skylar One). When referring to a ticket, %7 represents the subject line of an email used to create a ticket.
%c Event Event counter
%d Event Date/time when last event occurred.
%D Event Date/time of first event occurrence.
%e Event Event ID
%H Event URL link to event
%M Event Event message
%s Event severity (0 - 4). 0=healthy, 1=notify, 2=minor, 3=major, 4=critical.
%S Event Severity (HEALTHY - CRITICAL)
%_user_note Event Current note about the event that is displayed on the Events page.
%x Event Entity ID
%X Event Entity name
%y Event Sub-entity ID
%Y Event Sub-entity name
%Z Event Event source (Syslog - Group)
%z Event Event source (1 - 8)
%_ext_ticket_ref Event For events associated with an external Ticket ID, this variable contains the external Ticket ID.
%3 Event Policy Event policy ID
%E Event Policy External ID from event policy
%f Event Policy Specifies whether event is stateful, that is, has an associated event that will clear the current event. 1 (one)=stateful; 0 (zero)=not stateful.
%G Event Policy External Category
%R Event Policy Event policy cause/action text
%_event_policy_name Event Policy Name of the event policy that triggered the event.
%B Organization Organization billing ID
%b Organization Impacted organization
%C Organization Organization CRM ID
%o (lowercase "oh") Organization Organization ID
%O (uppercase "oh") Organization Organization name
%r System Unique ID / name for the current Skylar One system
%7 Ticket
Subject of email used to create a ticket. If you specify this variable in a ticket template, Skylar One will use the subject line of the email in the ticket description or note text when Skylar One creates the ticket.
NOTE: When referring to a ticket, %7 represents the subject line of an Email used to create a ticket. When referring to an event, %7 represents severity (for previous versions of Skylar One).
%t Ticket Ticket ID
%J Ticket Description field from the Skylar One ticket.
