Monitoring with the SL1 Agent
The SL1 agent is a program that you can install on a device monitored by SL1. There is a Windows agent, an AIX agent, a Solaris agent, and a Linux agent. The agent collects data from the device and pushes that data back to SL1.
The following minimum agent versions are required for SL1 12.1.1: Windows version 131; Linux version 174; AIX version 180; and Solaris version 180.
If your current ScienceLogic SL1 solution subscription does not include the SL1 Agent, contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
You can you can install an agnet on a number of operating systems from the Agents page (Devices > Agent). After installing the agent, you can configure the agent on the Device Investigator page for the device on which the agent is running:
