Introduction to the Skylar One Agent
This section describes the Skylar One (formerly SL1) agent and provides instructions for viewing device and interface data collected by the agent.
If your current ScienceLogic Skylar One solution subscription does not include the Skylar One Agent, contact your ScienceLogic Customer Success Manager or Customer Support to learn more.
What is the Skylar One Agent?
The Skylar One agent is a program that you can install on a device monitored by Skylar One (formerly SL1). There is a Windows agent, an AIX agent, a Solaris agent, and a Linux agent. The agent collects data from the device and pushes that data back to Skylar One.
The following minimum agent versions are required for Skylar One 12.5.1 and later:
  • Windows version 154
  • Linux version 196
  • AIX version 196
  • Solaris version 196
Users who require agent-based log collection on a device with a Windows agent or a Linux agent must have the minimum Windows agent or Linux agent version. If you do not have the minimum required agent versions, ScienceLogic recommends that you upgrade using the Upgrade button on the Agents page (Devices > Agents), or by downloading and upgrading the agent manually. For more information, see the section on Upgrading an Agent.
Agent Versions for Skylar One
The following table shows the most recent Linux and Windows agent versions for each Skylar One release.
Skylar One (SL1) Version Agent Version
12.1.0.2-12.1.1
Linux v184
Windows v145
12.1.2
Linux v191
Windows v148
12.2.0
Linux v188
Windows v147
12.2.1.1-12.2.4
Gen 1 agent:
Linux v190
Windows v148
Gen 3 agent:
Linux v188
Windows v147
12.2.5-12.2.7
Linux v191
Windows v148
12.3.0
Linux v191
Windows v148
12.3.1-12.3.6
Linux v193
Windows v150
12.3.7
Linux v196
Windows v154
12.5.1
Linux v196
Windows v154
How the Skylar One Agent Works in Different Environments
There are two supported "generations" of the Skylar One agent that you can use to gather data: Gen 1 and Gen 3. The agent itself is the same from one generation to the next; the only difference between the generations is the environment where the agent is used.
In brief, a Gen 1 agent uses the Skylar One Distributed Environment to upload data directly to a Message Collector (MC), while a Gen 3 agent uses the Skylar One Extended Architecture to upload data to the "Streamer" service running on the Skylar One Compute Node cluster.
The following list provides more details about how Skylar One uses the different generations of the Skylar One agent:
  • Gen 1 agent: Introduced in Skylar One version 8.2.0, the Gen 1 agent uses a Distributed Environment to upload data directly to a Message Collector (MC). Next, Dynamic Applications running on a Data Collector query data from the Message Collector with an API. The Data Collector (DC) then sends the data to the Skylar One Database Server:
    The Gen 1 agent provides limited infrastructure health reporting, including Log File Monitoring, Processes, and System Vitals like Availability, CPU Usage, Memory Usage, and Disk Usage. This agent is sometimes called the "P0" agent.
  • Gen 2 agent: This version of the agent has been deprecated.
  • Gen 3 agent: Introduced in Skylar One version 8.12.0, the Gen 3 agent uses the Skylar One Extended Architecture to upload data through a load balancer to the "Streamer" service running on the Skylar One Compute Node cluster. The Streamer service then forks and forwards data to other services, and eventually some services will store parsed data in the Skylar OneDatabase Server:
    The Gen 3 agent provides full infrastructure health reporting, including system vitals (file system, network interface, and Windows service data), log monitoring, and optionally allows you to align PowerShell Dynamic Applications to your device. Also, the Dynamic Applications in the ScienceLogic: Agent PowerPack are automatically aligned with the device with the Gen 3 agent installed on it.
  • The Collection Frequency column on the Network Interfaces page (Registry > Networks > Interfaces) is grayed out for Gen 3 agents because it does not apply to interfaces of agent-monitored devices. The agent interface collection data defaults to 5 minutes and is not configurable for Gen 3 agents.
If you are already running the Gen 1 agent in a distributed environment and you upgrade your Skylar One system to use the Skylar One Extended Architecture, any existing devices monitored by Skylar One agents will work the same as before (streaming data to a Message Collector). However, if you upgrade to the Skylar One Extended Architecture, ScienceLogic recommends that you start streaming your agents to the Compute Node cluster instead of to a Message Collector.
To identify the version of the agent installed on a device:
  • Gen 1. On the Devices > Device Investigator > Settings tab for that device, the Collection Poller field displays the name of the collector group that includes the Message Collector used by the agent. On the Device Manager page (Devices > Classic Devices), the Collection Group column displays the name of the collector group that includes the Message Collector used by the agent.
  • Gen 3. On the Devices > Device Investigator > Settings tab for that device, the Collection Poller field displays the label Agents. On the Device Manager page (Devices > Classic Devices), the Collection Group column displays the label Agents.
The following table provides an overview of the features available when using the Gen 1 or the Gen 3 agent:
Product Capability Gen 1 Agent Gen 3 Agent
System Vitals
Availability and Uptime
Yes
Yes
CPU, Memory, File Systems, and Network Interface
CPU and Memory only
Yes
Processes and Windows Services
Processes only
Yes
Installed Software
No
Yes
Log Monitoring
Event Logs
Yes
Yes
Syslog
Yes
Yes
Text Logs
Yes
Yes
Extensible Collection
PowerShell
No
Yes
JMX
No
Yes
For a detailed list of the system vital metrics you can monitor with the Skylar One agent, see What System Vital Metrics Can the Skylar One Agent Collect?
For a current list of supported operating systems and host system requirements for the Skylar One agent, see the System Requirements for the Agent page at the ScienceLogic Support Site.
Users who are running version 102 or later of the Microsoft: Windows Server PowerPack can collect data via the Skylar One agent. For more information, see Monitoring Windows Systems with PowerShell.
The following sections describe the system vitals that can be collected with Skylar One and with the Skylar One Agent, including definitions of each metric type and the collection methods that are and are not supported for each.
Metric Descriptions
The following table describes the system vital metrics that can be collected with Skylar One and the Skylar One Agent:
Metric Type Description
Availability Performance The ability to communicate with the managed entity or device.
File Systems Configuration The configuration of the file systems found within a managed entity that can include attributes like name, size, and type.
File Systems Performance Time series data associated with file system utilization that can include metrics like free space, size, and usage percentage.
Installed Software Configuration The software found on a managed entity that can include attributes like name, version, and installation date.
Network Interfaces Configuration The configuration of the network interface found within a managed entity that includes attributes like MAC address, IP address, position, and speed.
Network Interfaces Performance Time series data associated with physical memory utilization that includes metrics like inbound and outbound utilization, number of errors, and discard and usage percentage.
Physical Memory Configuration The configuration of the physical memory found within a managed entity that can include attributes like memory size.
Physical Memory Performance Time series data associated with physical memory utilization that can include metrics like memory used.
Ports Configuration The ports discovered on a managed entity.
Ports Performance Time series data associated with port availability.
Ports (Illicit) Performance An analysis of ports. When a port from the illicit port list is found on a managed system, the system will trigger an event indicating an illicit port has been found.
Processes Configuration The processes found on a managed entity that can include attributes like name, process ID (PID), and state.
Processes Performance Time series data associated with process performance that can include metrics like availability percentage.
Processor Configuration The configuration of the processor found within a managed entity that can include attributes like number of cores, processor model, processor speed, cache size, and CPU ID.
Processor Performance Time series data associated with processor utilization that can include metrics like CPU idle time, CPU wait time, and overall CPU time.
Restarts Performance An analysis of uptime. When uptime is less than 15 minutes, the system triggers an event indicating the system was restarted.
SSL Certificates Configuration The certificates found on a managed system.
SSL Certificates Performance An analysis of certificate expiration date. The system will trigger an event when certificates are nearing expiration.
Uptime Performance The timespan since the managed entity was last initialized.
Virtual Memory (Swap) Configuration The configuration of the virtual memory found within a managed entity.
Virtual Memory (Swap) Performance Time series data associated with virtual memory utilization.
Windows Services Configuration The services found on a managed entity that can include attributes like name and state.
Windows Services Performance Time series data associated with service performance that can include metrics like availability percentage.
The following table describes which methods of data collection are supported when running Skylar One and the Skylar One Agent on monitored Windows systems:
Metric Type Agentless Agent-Based
SNMP WMI PowerShell Gen-01 Gen-03
Availability Performance Yes Yes Yes Yes Yes
File Systems Configuration Yes Some Yes Some Yes
File Systems Performance Yes Some Yes Some Yes
Installed Software Configuration Yes No Yes No Yes
Network Interfaces Configuration Yes Some Yes Some Yes
Network Interfaces Performance Yes Some Yes Some Yes
Physical Memory Configuration Yes Yes Yes Yes Yes
Physical Memory Performance Yes Yes Yes Yes Yes
Ports Configuration Yes No Yes Yes No
Ports Performance Yes No Yes Yes No
Ports (Illicit) Performance Yes No Yes Yes No
Processes Configuration Yes Some Yes Yes Yes
Processes Performance Yes No Yes Yes Yes
Processor Configuration Yes Yes Yes Yes Yes
Processor Performance Yes Yes Yes Yes Yes
Restarts Performance Yes No Yes Yes Yes
SSL Certificates Configuration Yes No No No No
SSL Certificates Performance Yes No No No No
Uptime Performance Yes No Yes Yes Yes
Virtual Memory (Swap) Configuration Yes Yes Yes Yes Yes
Virtual Memory (Swap) Performance Yes Yes Yes Yes Yes
Windows Services Configuration Yes Some Yes No Yes
Windows Services Performance Yes Some Yes No Yes
The following table describes which methods of data collection are supported when running Skylar One and the Skylar One Agent on monitored Linux systems:
SNMP SSH Gen-01 Gen-03
File Systems Configuration Yes Yes Some Yes
File Systems Performance Yes Yes Some Yes
Installed Software Configuration Yes No No Yes
Network Interfaces Configuration Yes Yes Some Yes
Network Interfaces Performance Yes Yes Some Yes
Ports Configuration Yes Yes Yes No
Ports Performance Yes Yes Yes No
Ports (Illicit) Performance Yes Yes Yes No
Processes Configuration Yes Yes Yes Yes
Processes Performance Yes Yes Yes Yes
Restarts Performance Yes Yes Yes Yes
Uptime Performance Yes Yes Yes Yes
Windows Services Configuration N/A N/A N/A N/A
Windows Services Performance N/A N/A N/A N/A
In addition to the capabilities listed above, you can use the Skylar One agent for "extensible collection", where you align the agent with Dynamic Applications to gather metrics and attributes from other infrastructures and applications.
The Skylar One Extended Architecture supports aligning PowerShell Dynamic Applications to devices monitored by the Skylar One Windows agent. The Skylar One Extended Architecture supports aligning JMX Dynamic Applications to devices monitored by the Skylar One Linux agent.
For more information, see Configuring Extensible Collection.
Agent PowerPacks
Skylar One includes two PowerPacks that can be used to collect agent-based system configuration and performance data: the ScienceLogic: Agent PowerPack and the Host Agent PowerPack.
Both PowerPacks are installed by default on your Skylar One system, and they include the following features:
  • Dynamic Applications that collect configuration data and performance metrics from devices that are using agent-based collection
  • Event Policies and alerts that are triggered when devices that are using agent-based collection meet certain status criteria
The ScienceLogic: Agent PowerPack collects agent-based data for devices on Skylar One systems running on the Skylar One Extended Architecture (Gen 3 agents). This PowerPack contains two Dynamic Applications:
  • The "ScienceLogic Agent: System Configuration" Dynamic Applications collects the following data:
  • CPU
  • CPU Information
  • CPUs
  • Hardware Totals
  • Memory
  • Speed (MHz)
  • Swap Capacity
  • The "ScienceLogic Agent: System Performance" Dynamic Applications collects the following data:
  • CPU Name
  • CPU Utilization
  • CPU Utilization Breakdown
  • Disk Average Queue Length
  • Disk IO Utilization
  • Disk Name
  • Memory Utilization
  • Network Read
  • Network Write
  • Sample Time
  • Swap Utilization
The Host Agent PowerPack, which collects agent-based data for devices on Skylar One systems running on a Distributed Architecture (Gen 1 agents). This PowerPack contains two Dynamic Applications:
  • The "Host Agent: System Config" Dynamic Applications collects the following data:
  • CPU
  • CPU Information
  • CPUs
  • Disk
  • Disk Information
  • Disk Space
  • Disks
  • Hardware Totals
  • Memory
  • Size
  • Speed (MHz)
  • The "Host Agent: System Perf" Dynamic Applications collects the following data:
  • CPU Name
  • CPU Utilization
  • Disk Name
  • Disk Utilization
  • Network Read
  • Network Write
  • Sample Time
  • Storage Available
  • Storage Name
  • Storage Total
  • Storage Utilization
Because the ScienceLogic: Agent PowerPack is required to collect data from devices that are using agent-based collection, Skylar One does not enable you to delete or modify this PowerPack.
Agent-Compatible PowerPacks
In addition to the ScienceLogic: Agent PowerPack and the Host Agent PowerPack, there are several other Agent-compatible PowerPacks that you can use to collect data from specific device types.
Windows Devices
The following PowerPacks include the Skylar One Agent PowerShell Default credential and Skylar One Agent device template, which you can use to execute the Skylar One Agent on Windows devices with PowerShell:
  • Microsoft: Windows Server
  • Skylar One Agent Templates for Microsoft PowerPacks, which includes templates for the following:
  • Microsoft: DHCP Server
  • Microsoft: DNS Server
  • Microsoft: Exchange Server
    The "Microsoft: Exchange Server" PowerPack has two device templates. If the Exchange server monitored contains all Exchange roles, use the "Skylar One Agent for Microsoft: Exchange Server Template." If your Exchange server has an Exchange Transport role, use the Skylar One Agent for Microsoft: Exchange Transport Server Template."
  • Microsoft: IIS Server
  • Microsoft: Lync Server
  • Microsoft: SharePoint Server
  • Microsoft: SQL Server
For more information, see the section on Executing the Skylar One Agent with Windows PowerShell.
Java Management Extensions (JMX) Resources
You can also use the JMX Base Pack  PowerPack to monitor JMX resources with the Skylar One agent.
For more information, see the section on Executing the Skylar One Agent with JMX.
Agent Architecture
The following sections describe how the Skylar One agent works in the Skylar One Distributed Architecture and in the Skylar One Extended Architecture.
In a Skylar One Distributed Architecture, the Skylar One Agent collects data from the device on which it is installed and transfers that data to a Message Collector in a Skylar One system using the HTTPS protocol. The Data Collector on which the Dynamic Applications and collection processes run then poll the Message Collector using the HTTPS protocol to transfer data to Skylar One.
In a Distributed Architecture, the Skylar One agent requires a standalone, dedicated Message Collector. The Message Collector does not need to be dedicated to agent usage, but the Message Collector cannot be a Data Collector that also performs message collection
NOTE: Message Collectors that process data from the agent have different system requirements than Message Collectors that do not process data from the agent. For more information about the system requirements when running agents in a Distributed Architecture, see the System Requirements page at the ScienceLogic Support Site.
The diagram below shows the collection layer of a Distributed System containing both Data Collectors and Message Collectors in which the Skylar One Agent is installed on a managed device.
The collection layer of a distributed system
In the Skylar One Extended Architecture, an Skylar One agent collects data from the device on which it is installed and sends that data to a Load Balancer in front of a Compute Cluster. The Compute Cluster transforms the data and stores high-volume performance data in the Storage Cluster and other performance and configuration data in the Database Server.
If required, agents can use an HTTP proxy server as an intermediate step in sending data to Skylar One.
In the diagram below:
  • The Skylar One agent collects data from managed devices and sends the data to the Load Balancer and Compute Node cluster for processing.
  • The optional Message Collector collects asynchronous traps and syslog messages and sends them to the Database Server.
  • The Data Collector collects data from managed devices and sends the data to the Load Balancer and Compute Node cluster for processing and then storage.
A diagram showing the relationship between the Skylar One agent, the Message Collector, and the Data Collector
Using an agent in the Skylar One Extended Architecture provides more configuration and performance data than using an agent in a Distributed Architecture. This additional data includes system vitals, log data, and extensible collection.
Uploads that occur in 20-second intervals, sometimes called "snapshot uploads", are no longer supported. These 20-second uploads were replaced with the 1-minute upload default in Skylar One version 11.2. ScienceLogic highly recommends that you ensure your agents are uploading in 1-minute summarized uploads prior to upgrading. You can verify your uploads from the Settings tab in the current Skylar One user interface.
NOTE: For more information about the system requirements when running agents in an Extended Architecture, see the System Requirements page at the ScienceLogic Support Site.
