The Skylar Automated RCA Connector, also called the ze_connector service, continually checks your Skylar Automated RCA instance for suggestions and alerts. The Connector then looks for a Skylar One (formerly SL1) device that matches the Skylar Automated RCA alerts, and sends the Skylar Automated RCA suggestions and alerts to that device in Skylar One.
As a result, the Skylar Automated RCA Connector lets you view Skylar Automated RCA suggestions and alerts in the following locations in Skylar One:
- The Events page
- The Event Investigator page for a Skylar Automated RCA suggestion or alert
- The tab and the tab of the Device Investigator page
- The Timeline widget and the tab of the Service Investigator page
Workflow for Configuring the Skylar Automated RCA Connector
Before you can view Skylar Automated RCA data on these Skylar One pages, you will need to complete the following configuration steps in Skylar Automated RCA and Skylar One:
- Configure Skylar Automated RCA:
- Configure Skylar One:
- Configure the Skylar Automated RCA Connector:
Creating an Access Token in Skylar Automated RCA
You first need to access the Skylar Automated RCA user interface to get an access token that you will use in the Skylar One setup.
To create an access token in Skylar Automated RCA:
- In the Skylar Automated RCA user interface, go to the Access Tokens page (Settings (
) > Access Tokens). - Click . The Add Access Token dialog appears.
- Name. Type a name for this token.
- Role. Select Viewer.
- Deployment. Select the deployment that you want to monitor.
- Make sure the Enabled button is selected, and then click . The new token is added to the Access Tokens page. The token is in the format "Bearer <token>", such as Bearer abcdefghijk.
- Hover over the Name/Token column of the new token and click the button that appears.
- Save the access token for the next set of steps.
Configuring Skylar One
Complete the following steps to configure Skylar One so it can use the Skylar Automated RCA Connector.
Create a Service Connection in Skylar One
To create a Skylar Automated RCA (Zebrium) service connection in Skylar One:
- In Skylar One, go to the Service Connections page (Manage > Service Connections).
- Click Add Service Connection and select Skylar Automated RCA. The Create Skylar Automated RCA (Zebrium) Connection window appears.
- Name. Type a name for this new service connection.
- Access Token. Add the Access Token value from the Your Integration Info dialog or the Edit Integration dialog in the Skylar Automated RCA user interface. You can also access this information on the Access Tokens page (Settings (
) > Access Tokens) in the Skylar Automated RCA user interface. - Skylar Automated RCA (Zebrium) Endpoint URL. Add the Endpoint URL value from the Your Integration Info dialog or the Edit Integration dialog. Skylar Automated RCA Cloud users can use the default value in this field, while Skylar Automated RCA On Prem users will need to add the URL of their on-premises Skylar Automated RCA instance.
- Skylar Automated RCA (Zebrium) Deployment ID. Add the Deployment ID value from the Your Integration Info dialog or the Edit Integration dialog.
- Share data with. Select the All Organizations toggle (turn it blue) to share this connection with all existing and newly created organizations. Alternately, you can deselect the All Organizations toggle (turn it gray) and select one or more organizations from the Selected Organizations drop-down to limit access to this connection to only those organizations.
- Click . The service connection is added to the Service Connections page.
Create a Skylar One Authentication Token
Next, you will need to encode your Skylar One credentials to create a Skylar One authentication token:
Go to a Base64 encoding site like https://www.base64encode.org and paste your Skylar One username and password in the text box. Use the following format:
<username>:<password>
For example: myuser:mypassword
Use the default settings and click . Your encoded credentials will look like the following:
bXl1c2VyOm15cGFzc3dvcmQ=
The authentication token is in the format "Basic <token>".
Copy the newly encoded credentials, which will work as your Skylar One authentication token.
Create a Default Virtual Device (optional)
The Skylar Automated RCA Connector can send Skylar Automated RCA suggestions and alerts to any device in Skylar One. If you do not have a specific device that you want to use for this purpose, you can optionally configure a "default" Skylar One device. The Skylar Automated RCA Connector will send any Skylar Automated RCA suggestions and alerts that do not map to existing Skylar One devices to this default device.
For this purpose, you can create a virtual device in Skylar One to receive all of these unassigned suggestions and alerts.
To create a default virtual device in Skylar One:
- Ensure that Skylar One includes a device class for virtual devices. These device classes must have a device category of "virtual" and a collection type of "virtual".
- On the Device Manager page (Devices > Classic Devices, or Registry > Devices > Device Manager in the classic user interface), click the button and select Create Virtual Device. The Create Virtual Device modal appears.
- Device Name. Name of the virtual device.
- Organization. Organization to associate with the virtual device. Select from the drop-down list of all organizations in Skylar One.
- Device Class. The device class to associate with the virtual device. Select from the drop-down list of device classes. Only device classes with a device category of "virtual" and a collection type of "virtual" appear in the list.
- Collector. Specifies which instance of Skylar One will perform auto-discovery and gather data from the device. Can also specify a "virtual" connector. Select from the drop-down list of all collectors in Skylar One.
- Click to save the new virtual device. Skylar One displays the new device ID after the text Device Added.
- Before you close the modal, make a note of the ID for your new virtual device. You can sort for this ID on the Devices page in Skylar One to quickly locate this new virtual device.
Install the Skylar (Zebrium) Event Policies PowerPack
To convert the API alerts sent by the Skylar Automated RCA Connector into Skylar One events, you will need the Skylar Automated RCA event policies, which are available in the "Skylar Automated RCA (Zebrium) Event Policies" PowerPack. The event policies will be automatically enabled when you install the PowerPack.
To configure the Skylar (Zebrium) event policies:
- Install the PowerPack in Skylar One. For more information, see Importing and Installing a PowerPack.
- Go to the Event Policies page (Events > Event Policies) and sort by "Skylar (Zebrium)" in the Name column.
- Make sure all of the event policies from the PowerPack have a Status of Enabled. If not, check the boxes for the policies that are not enabled and click .
The Skylar Automated RCA Connector, also called the ze_connector service, continually checks your Skylar Automated RCA instance for suggestions and alerts. The Skylar Automated RCA Connector then looks for a Skylar One device that matches the Skylar alerts and sends the suggestions and alerts to that device in Skylar One.
You will need to install the Skylar Automated RCA Connector RPM file on the Skylar One server that you want to connect with Skylar Automated RCA.
System Requirements
The Skylar One server where you install this service must have the following:
- systemd
- Python 3.9
- sudo access to the server
- For version 0.0.3 of the Skylar Automated RCA Connector, Skylar One version 12.2.0 or later
- For versions 0.0.4 and 0.0.5 of the Skylar Automated RCA Connector, Skylar One version 12.3.0 or later
Your Skylar One system must be running Oracle Linux 8 or later, with the "Skylar (Zebrium) Event Policies" PowerPack installed.
ScienceLogic strongly recommends that you create a separate Skylar One account for the Skylar Automated RCA integration instead of using the default "em7admin" user account. For more information, see Manually Creating a New User Account in the Skylar One Product Documentation.
Download and Install the RPM file for the Skylar Automated RCA Connector
You will need to download the RPM file for the Skylar Automated RCA Connector from the ScienceLogic Support site, and then upload it to your Skylar One system.
To download and install the RPM file:
Go to the ScienceLogic Support site at https://support.sciencelogic.com/s/.
Click the tab and select Downloads. The Platform Downloads page appears.
Click the link for the Skylar One version you are currently running, such as Skylar One Ibiza Platform 12.3. The Release Version page appears.
In the Release Files section, click the RPM link for the Skylar Automated RCA Connector RPM file. A Release File page appears.
Click at the bottom of the Release File page.
SSH to the server where you are installing the RPM and run the following command to install the RPM:
sudo dnf install <ze_connector-filename> -y
sudo dnf install ze_connector-0.0.5-1.el8.noarch.rpm -y
Edit the config.yaml file as needed:
sudo vi /etc/ze_connector/config.yaml
Restart the service and verify:
sudo systemctl restart zeconnector
sudo systemctl status zeconnector
sudo journalctl -u zeconnector
tail /var/log/sl1/ze_connector.log
Configure the config.yaml file
The /etc/ze_connector/config.yaml file is supplied as part of the RPM install. You can use this sample configuration file to set up new jobs. This section explains the structure of the config.yaml file. You can copy this file and update it for the connector jobs.
This schema will be overwritten to track the most recent Skylar Automated RCA event found, specifically the poll_timing.poll_start_time_iso field.
Configuration Schema
- jobs: (array, required) - polling jobs to run
name: (str, required) - unique name of this job for log message readability
sl1_api_config: (obj, required)
- api_url: (str, required) - URL endpoint for the Skylar One API to query; do not include a "trailing slash" (/) at the end of the URL. Example: api_url: https://127.0.0.1
- api_auth: (str, required) - Basic authentication token for the Skylar One API (see Create a Skylar One Authentication Token for format)
poll_timing: (obj, optional)
- poll_sleep_seconds: (int, optional default:60) - number of seconds to sleep between polling requests
- poll_start_time_iso: (str, optional default:now) - ISO 8601 timestamp for when to start querying for Skylar Automated RCA alerts
sl1_default_device_ids: (array[str], optional default:[]) - list of Skylar One device IDs to send alerts to if no device is matched automatically; omit to not send an alert if no device is matched
ze_deployment_id: (str, required) - Deployment ID of the Skylar Automated RCA deployment to query. You can find this value in the Deployment ID column on the Deployments (Settings (
) > Deployments) page of the Skylar Automated RCA user interface. -
ze_service_groups: (array[str], optional default:[]) - list of Skylar Automated RCA service groups to query. You can view a list of service groups by clicking the button on the Alerts page of the Skylar Automated RCA user interface. The Selected Filter dialog contains a list of service groups in the Service Groups filter.
- If you want to enable sample alerts, add this line to the config.yaml file:
ze_service_groups: "integration_test" - If you do not want to specify a service group, or if a service group does not exist, use an empty array: ze_service_groups: []
sl1_override_event_time: (bool, optional default:False) - overrides using the Skylar Automated RCA alert timestamp and instead uses now as when the alert occurred.
Example Configuration
The following configuration will run two polling jobs:
- Job 1 will query my1.sl1.com using the defaults: poll every 60 seconds, starting from now
- Job 2 will query my2.sl1.com using overrides: poll every 120 seconds, starting from 09/05/2023, only query for Skylar Automated RCA service groups sg-1 and sg-2, send any unmatched events to Skylar One device_id 1.
jobs: # minimal config required job # will default to all Skylar Service Groups # will drop all alerts that don't match a Skylar One device # polling will occur every 60s, starting from now - name: example_job_1 ze_deployment_id: "sciencelogic_default" sl1_api_config: api_url: https://my1.sl1.com api_auth: "Basic dXNlcjpwYXNz" # maximal config job # will query only the 2 service groups provided # will send any alerts that don't match a Skylar One device to device/1 # will poll every 120 seconds from 9/5/2023 00:00:00 GMT to now - name: example_job_2 sl1_default_device_ids: - "1" ze_service_groups: - "sg-1" - "sg-2" - "integration_test" ze_deployment_id: "some_other_deployment" sl1_api_config: api_url: https://my2.sl1.com api_auth: "Basic dXNlcjpwYXNz" poll_timing: poll_sleep_seconds: 120 poll_start_time_iso: "2023-09-05 00:00:00" sl1_override_event_time: false
