CyberArk
CyberArk is not provided with Skylar One. You must purchase and manage the CyberArk Vault independently.
Skylar One can source credential data from external CyberArk vaults using a credential gateway service. This service allows you to download the CyberArk Credential Provider—sometimes referred to as the CyberArk Credential Agent—from your instance of CyberArk and install the agent on Skylar One Data Collectors. This agent syncs with credentials on the CyberArk vault server and uses those credentials to collect data from Skylar One-monitored devices when necessary. When a Skylar One system has been set up with the CyberArk Agent and the credential gateway service, you can enter vault tags in any secret/encrypted credential field in Skylar One instead of entering the password or secret value itself.
CyberArk credentials are stored in the memory of the CyberArk Agent, not in Skylar One Data Collectors.
Installing the CyberArk Credential Agent on Every Collector
Install the CyberArk Credential Provider (Agent) by following the instructions outlined in CyberArk’s knowledge base article: Install the Credential Provider.
The CyberArk Agent must be installed on your Skylar One Data Collectors. These appliances retrieve credential data from the CyberArk vaults.
Reinstalling the CyberArk Credential Agent on a Rebuilt Data Collector
In cases where you need to rebuild your Data Collector, you will first need to remove the previous Data Collector from the CyberArk Credential Agent. After rebuilding the Data Collector, you will then need to reinstall the agent on that rebuilt appliance.
To reinstall the agent, follow the steps outlined in CyberArk's knowledge base article: Install the Credential Provider.
Defining a Custom CyberArk Delimiter
You can define a custom CyberArk delimiter when sourcing credential data from external CyberArk vaults. If you want to use a custom CyberArk delimiter, you must do so before starting the Credential Gateway Service:
Use the SSH protocol to connect to the Data Collector.
Enter the following commands
sudo vi /opt/em7/lib/python3/sl_credential_gateway/sl_credential_gateway.sh
Uncomment the line #export CYBERARK_DELIMITER='!' and change the ""!"" character to a different delimiter character.
Save and exit the sl_credential_gateway.sh file.
Starting the Credential Gateway Service on Every Data Collector
The Credential Gateway Service is the method Skylar One uses to interact with the CyberArk Credential Provider (Agent). You must complete the following steps for every Data Collector you are utilizing:
- Use the SSH protocol to connect to the Data Collector as the em7admin user.
- Enter the following command:
- Then, run the following command:
- A message appears indicating that the "Credential Gateway Service environment has been created and the service is running."
cd /opt/em7/lib/python3/sl_credential_gateway/
sudo bash sl_credential_gateway.sh
If you already have a running Credential Gateway Service and then rerun this script, the service will stop and start a new one. Future development includes integrating this service into systemd instead of using this script so all systemd service functionality is supported.
Troubleshooting Credential Gateway Service Issues
If you are encountering errors while running the sl_credential_gateway.sh script, perform the following actions:
Check that the directory /opt/em7/lib/python3/sl_credential_gateway/venv/ exists. If it does, try to activate it with the command source /opt/em7/lib/python3/sl_credential_gateway/venv/bin/activate and see if it gives you any errors. You can also delete the venv directory and re-run sl_credential_gateway.sh.
Check whether the gunicorn process runs with the command pgrep -x "gunicorn". You should see two process IDs. If you see anything other than two IDs, kill them with the command ps -ef | grep gunicorn | grep -v grep | awk '{print $2}' | xargs kill and then re-run sl_credential_gateway.sh.
Check /var/log/sl1/cgs-error.log for additional error information and search for troubleshooting guidance.
If gunicorn is not running, check to see if /var/run/em7/cgs.sock exists. If it does, delete it and re-run sl_credential_gateway.
Setting Up Vault Tags in Your Credential
When a Skylar One system has been set up with the CyberArk Credential Provider (Agent) and the Skylar One Credential Gateway service, you can enter vault tags in any secret/encrypted credential field instead of entering the password/secret itself. Any time you use the credential in discovery or collections, Skylar One will detect the vault tag, use the provided query string to retrieve a secret from the CyberArk credential provider, and then use it in this field.
You can set up vault tags only in the classic Skylar One user interface.
- Click the button and then select the type of credential you want to create. The Credential Editor modal appears.
- If there's a secret/encrypted credential field, enter the appropriate vault tag instead of entering the password/secret itself.
The vault tag entered should be in the following format: <vault id>:<appid>;<safe>;<object>
For example, a query string for an SNMP Credential might appear as the following: vault:123:appid=testappid;safe=Test;object=snmp_v2.
For CyberArk, the query string contains the following parameters:
- appid. The ID of the application registered in the CyberArk vault for Skylar One.
- safe. The ID of the safe in which the object resides.
- object. The ID of the object that holds the secret/encrypted data.
These parameters must be lowercase in the vault tag.
The vault ID value indicates which CyberArk vault Skylar One should check first for the credential information. For Skylar One 12.1.0, any numeric value can be entered for the vault ID.
Example: Vault Tags
In this example, any time the EM7 Default V2 Tag credential is used in the Profile Name field, Skylar One will retrieve the secret from the object snmp_v2 contained in the Test safe as application testappid, from the CyberArk credential provider. Then, this secret will be used for the SNMP Community (Read-Only) field value.
