This example monitors two hosted, mission-critical, MS SQL database servers for availability and latency. The MS SQL database servers are leased by the company Acme and hosted by a service provider.
Creating an IT Service Policy
- Define a service name and basic properties. This example monitors two MS SQL database servers. The name of the IT Service policy will be "Acme: MS SQL Database Servers".
- Define a list of devices (model) for the IT Service that includes all the devices associated with the IT Service. This example includes two MS SQL servers in the IT Service.
- Optionally, define service sets. A service set is a sub-group of devices. This example does not use service sets.
- Define metrics. A metric is based on your business processes and examines all devices or one or more service sets to evaluate the state of the IT Service. For each IT Service, Skylar One provides a default metric called Average Device Availability, based on the availability of all devices in the IT Service. You can define additional metrics, based on default data collected by Skylar One (availability, latency, CPU usage, memory usage, swap usage, device state, and device count), data collected by a Dynamic Application, and data about network interfaces, TCP/IP ports, system processes, Windows services, Email round-trip time, web content, SOAP/XML transactions, and DNS availability.
NOTE: When Skylar One evaluates a metric, it performs an aggregation, that is, Skylar One evaluates the data for all devices specified in the definition of the metric, over a specified time period (the Aggregation Frequency). Depending on the definition of the metric, Skylar One calculates the average, maximum, minimum, sum, standard deviation, or count value for all devices specified in the definition of the metric.
- Define alerts and associated events. Each alert and its associated event is triggered by a metric. In our example, we will define alerts for each metric.
- Select the button. The IT Service Editor page appears, with the tab and sub-tab selected.
- Supply the following values in the following fields:
- IT Service Name. Name of the IT Service policy. We entered "Acme: MS SQL database_servers".
- Sharing Permissions. Specifies whether other users can view and use the IT Service policy, in both the IT Service Manager page, IT Service Editor page, and in the pages in Skylar One where the IT Service is visible. We selected Shared with users in your organization. The IT Service policy can be viewed and used by other users who belong to the same organization as the creator.
- Aggregation Frequency. Frequency at which Skylar One will collect data from all devices in the IT Service and "crunch" the data for each metric into a single value. We specified Every 3 minutes.
- Raw Data Retention. Specifies how long Skylar One should store the raw data for the IT Service Policy. We accepted the default value.
- Frequent Rollup Retention. Deprecated field no longer used by Skylar One.
- Hourly Rollup Retention. Specifies how long Skylar One should store the "hourly" normalized data for the IT Service policy. We accepted the default value.
- Daily Rollup Retention. Specifies how long Skylar One should store the "daily" normalized data for the IT Service policy. We accepted the default value.
After defining the name and basic properties of an IT Service Policy, you must next determine the devices to include in your IT Service policy. You do this in the sub-tab.
When you define the list of devices to include in your IT Service policy, that list of devices appears as a device group throughout Skylar One.
In our example, we will add a static list of devices that includes two MS SQL servers to the IT Service policy.
- To add a static list of one or more devices to the list of devices for the IT Service policy, go to the Static Devices pane.
- Select the button. The Device Alignment modal page appears and displays a list of all devices in Skylar One.
- In the Device Alignment modal page, we selected the checkbox for devices "ALLIANCECOPIA" and "BDC-TMS01". Each is a device running the Windows operating system and MS SQL database server.
- Select the button in the lower right. The selected devices appear in the Static Devices pane.
Skylar One automatically includes a default metric with each IT Service policy. The default metric is called Average Device Availability. The Average Device Availability metric aggregates the current availability value (0 or 1) of all devices in the IT Service and calculates the average value. The aggregation is performed at the frequency specified in the Aggregation Frequency setting in the basic properties for the IT Service policy. The availability of a device is determined every 5 minutes.
Before you can define a metric, you must determine what parameters you want to monitor for the IT Service policy. You can use data from the following sources to monitor the IT Service:
- Device Availability
- Device Latency
- Overall CPU Usage
- Physical Memory Usage
- Swap Usage
- Device Count
- Network Interface
- TCP/IP Port Monitor
- System Process Monitor
- Windows Service Monitor
- Email Round Trip Monitor
- Web Content Monitor
- SOAP/XML Transaction Monitor
- Domain Name Monitor
Our example includes three metrics:
- Device Latency
- System Process availability
We will create our metrics in Basic mode. We will edit the default metric and create two additional metrics. We will also define an alert/event for each metric.
Device Availability Metric
- First, we will edit the default metric. In the Service Metric Definitions pane, find the metric Average Device Availability and select its wrench icon (
). The Service Metric Editor modal page appears: - In the Service Metric Editor page, edit the following field:
- Service Metric Name. Enter Average DB Device Availability. This lets us know that the metric is measuring the device's availability, not the database server's availability.
- In the lower pane, we'll define an alert for the metric. This alert specifies that when the availability of the two database servers falls below 75%, trigger an event with a severity of Critical. To define this alert and event, supply values in the following fields:
- Metric Alerting. Select Single Threshold.
- Alert Policy Name. Enter "DB_availability_too_low".
- Event Severity. Select Critical.
- Increasing/Decreasing. Select Decreasing.
- Threshold. Drag the slider to 75.
- Select the button to save the metric.
Device Latency Metric
Next, we will define a new metric that examines the latency of the devices where the MS SQL servers reside. To do this:
- Go to Service Metric Definitions pane and select the button.
- The Service Metric Editor modal page appears. In this page, we'll define a metric that measures the latency of the two devices in our IT Service policy. We'll also define an alert that will trigger an event if the average latency of the two devices is greater than 30 milliseconds.
- To create the new metric, supply the following values in the fields:
- Service Metric Name. Enter "Average DB device latency".
- Metric Type. Select Internal.
- Device Metric. Select Device Latency.
- For all other fields in the top pane, you can accept the default values.
- In the lower pane, we'll define an alert for the metric. This alert specifies that when the average latency of the two devices where the database servers reside is greater than 30 milliseconds, it will trigger an event with a severity of Critical. To define this alert and event, supply values in the following fields:
- Alert Policy Name. Enter "db_too_slow".
- Increasing/Decreasing. Select Increasing.
- Threshold. Drag the slider to 30.
System Process Metric
Next, we will define a metric that makes sure that the process sqlservr.exe is running on both devices where the MS SQL databases reside.
- Before we can define this metric in the IT Service Editor, we must tell Skylar One to monitor the sqlservr.exe process, outside of the IT Service policy. To do this:
- Go to the Device Processes page (Devices > Processes).
- Use the Device Name column to search for the device ALLIANCECOPIA.
- Use the Process column to search for the process sqlservr.exe.
- Select the checkbox for sqlservr.exe running on ALLIANCECOPIA.
- Select the Select Actions menu. Select Enable (Create Policy).
- Use the Device Name column to search for the device BDC-TMS01.
- Select the checkbox for sqlservr.exe running on BDC-TMS01.
- Go back to the IT Service Manager page (Registry > IT Services > IT Service Manager). Find the IT Service policy Acme: MS SQL database server. Select its wrench icon (
). - Select the tab. Select the button.
- The Service Metric Editor modal page appears. In this page, we'll define a metric ensures that the process sqlservr.exe is running on both devices where the MS SQL database resides. We'll also define an alert that will trigger an event if the availability of the process sqlservr.exe is less than 99%. In other words, with the exceptions of very, very brief outages, the process sqlservr.exe should be running.
- Service Metric Name. Enter SQL Server process.
- Metric Type. Select System Process Monitor.
- Process Name. Enter sqlservr.exe.
- Metric. Select Process Running.
- In the lower pane, we'll define an alert for the metric. This alert specifies that if the process sqlservr.exe is not running on both devices in the IT Service policy, trigger an event with a severity of Critical. To define this alert and event, supply values in the following fields:
- Alert Policy Name. Enter "SQL Server process is not running".
- Threshold. Drag the slider to 99.
All IT Service policies define how Skylar One should calculate the following Key Metrics for the IT Service:
NOTE: Skylar One automatically includes a default metric with each IT Service policy. The default metric is called Average Device Availability. The Average Device Availability metric specifies that Skylar One should aggregate the availability data for all the devices in the policy and calculate the average availability.
Skylar One generates an event if the Service Health Key Metric has a value of Notice, Minor, Major, or Critical, and/or if the System Availability key metric has a value of unavailable.
Using the three metrics we created in the previous section, we'll define the Key Metrics for our IT Service Policy:
- Select the sub-tab.
- In the top pane, you will see the default metric, Average Device Availability. If you have already defined additional custom metrics, they will also appear in the top pane.
- In the bottom pane, you will see the three Key Metrics.
- To edit each metric, supply the following values:
- Service Health. Appears in the Health column in the IT Service Manager page (Registry > IT Services > IT Service Manager). Possible values are Healthy, Notice, Minor, Major, and Critical. By default, the Service Health Key Metric is based on the metric for Average Device Availability, with values set at 0-24 is Critical, 25-49 is Major, 50-74 is Minor, 75-89 is Notice, and 90 and above is Healthy.
- In the drop-down list that appears above the Service Health Key Metric, select Average DB device latency.
- Select Increasing.
- Enter the following thresholds: 30, 40, 50, 60.
- If average latency is below 30 milliseconds, the IT Service policy will have a Health value of Healthy.
- If average latency is between 30 - 40 milliseconds, the IT Service policy will have a Health value of Notice.
- If average latency is between 40 - 50 milliseconds, the IT Service policy will have a Health value of Minor.
- If average latency is between 50 - 60 milliseconds, the IT Service policy will have a Health value of Major.
- If average latency is greater than 60 milliseconds, the IT Service policy will have a Health value of Critical.
- Service Availability. Appears in the Availability column in IT Service Manager page (Registry > IT Services > IT Service Manager). Possible values are Available and Unavailable. By default, the Service Availability Key Metric is based on the same metric as is used for the Service Health Key Metric. By default, 0 - 24 is Unavailable and 25 - 100 is Available.
- In the drop-down list that appears above the Service Availability Key Metric, select Average DB Device Availability.
- Select Decreasing.
- Enter the threshold 75.
- If the average availability of the two devices in the IT Service policy falls below 75%, the IT Service policy will have an Availability value of Unavailable.
- Service Risk. Appears as a percentage in the Risk column in the IT Service Manager page (Registry > IT Services > IT Service Manager). Possible values are 0% - 100%. By default, the Service Risk Key Metric is based on the same metric as is used for the Service Health Key Metric. By default, 0 - 89 is Critical and 90 - 100 is Healthy.
- In the drop-down list that appears above the Service Risk Key Metric, select SQL Server process.
- Enter the threshold 99.
- If the process sqlservr.exe is not running an average of 99% of the time, the IT Service policy will have a Risk value of 100%.
- Select the button to save your changes to the Key Metrics.
Events for the IT Service Policy
To see the definitions for the events associated with each metric, go to the Event Policy Manager page (Registry > Events > Event Manager).
To find the event definitions, filter the Event Policy Name field by the name of the IT Service policy.
When an event for an IT Service is triggered, it displays the following message in the Event Console:
[name of metric] has violated threshold (%T) currently (%V).
where %T is the threshold you defined for the alert and %V is the current value for the metric.
Skylar One generates an event if the Service Health key metric has a value of Notice, Minor, Major, or Critical. In the event above the metric that we associated with the Service Health Key Metric exceeded the threshold for the metric.
IT Service Dashboard
If you select the tab for our example IT Service policy, you'll see the following:
- Service Name
- Service Owner
- Service Visibility
- Maintenance State
- Service Health
- Service Risk
- IT Service Health Last 12 Hours. Displays a graph of the Availability metric. The y-axis displays percent availability. The x-axis displays time in one-hour increments.
