Monitoring Networks
During discovery, Skylar One (formerly SL1) discovers all IP networks. The list of all networks is displayed in the IPv4 Networks page (Registry > Networks > IPv4 Networks).
The IPv4 Networks page allows you to view a list of all networks, manage networks and IPs, view devices and interfaces in each network, and view maps and reports for each network.
IPv4 Networks
The IPv4 Networks page (Registry > Networks > IPv4 Networks) lists all networks and subnets detected by ScienceLogic auto-discovery and all manually defined (new) networks.
The IPv4 Networks page allows you to easily manage networks and IP addresses. From the IPv4 Networks page, you can view detailed data about the network, keep records of subnets, and determine which IP addresses are in use and which IP addresses are available.
NOTE: Users of type "user" can view only IPv4 networks that are aligned with the same organization(s) to which the user is aligned. Users of type "administrator" can view all IPv4 networks.
Viewing the List of IPv4 Networks
The table in the IPv4 Networks page (Registry > Networks > IPv4 Networks) contains an entry for each network managed by Skylar One.
The IPv4 Networks page displays the following about each managed network:
To sort the list of networks, click on a column heading. The list will be sorted by the column value, in ascending order. To sort by descending order, click the column heading again. The Edit Date column sorts by descending order on the first click; to sort by ascending order, click the column heading again.
  • Network. IP address of the entire network.
  • Subnet Mask. Subnet mask for the subnet.
  • Bits. The number of bits used for the network address.
  • Used/Max. Number of IP addresses discovered and monitored by Skylar One and the maximum number of IP addresses allowed in the subnet.
  • % Used. Percentage of total addresses in the network that have been discovered and monitored by Skylar One. In the Account Preferences page, you can specify whether or not you want to include empty networks (networks with no devices or interfaces) in the list of networks. These networks will have 0% in the % Used column.
  • Devs. Number of devices in the subnet.
  • IFs. Number of interfaces in the subnet.
  • Collection Group. The collector group associated with the network. For All-In-One Appliances, this field displays only the built-in Collector Group (and any virtual Collector Groups).
  • Organization. Organization associated with the network.
  • Net ID. Unique network ID, assigned by Skylar One.
  • Creation Date. Date the network was discovered or manually defined.
  • Edit User. User who created or last edited the network's properties.
  • Edit Date. Date the network was created or last edited, whichever is later.
  • Tools. For each network in the table, the following tools are available:
  • View/Edit Network Properties (). Displays the Network Properties modal page, where you can view and edit the basic properties of an IPv4 network.
  • Browse Network (). Leads to the Network Browser page. From this page, you can view a list of IP addresses (used and unused) included in a network, a list of devices included in a network, and a list of interfaces included in a network.
  • View/Edit Aligned Devices (). Leads to the Network Browser page, where you can view a list of devices associated with a network.
  • View/Edit Aligned Interfaces (). Leads to the Network Browser page, where you can view a list of interfaces associated with a network.
  • View/Edit Organization (). Leads to the Organizational Summary page, where you can view and edit information associated with the organization.
  • View Network Map (). Leads to the Layer-2 Maps page, where you can view and edit a graphical representation of a layer-2 network.
  • View a Network Report (). Opens the Report Creator modal page, where you can specify information to include in the report and the format in which to generate the report.
  • Add Network to Dynamic Discovery (). Adds the network to the dynamic-discovery queue. Skylar One will perform dynamic-discovery on all of the IP addresses in the network and gather information about any devices and interfaces in the network. Leads to the Discovery Control Panel page, with the selected network as the value in the discovery list.
  • Create a Ticket (). Leads to the Ticket Editor page, where you can create a ticket that will be associated with the selected network.
  • Delete (). To delete the network, select this checkbox and then click the Delete button. To select all the checkboxes, click the large red check icon.
Browsing a Network
From the IPv4 Networks page, you can browse a network and view the IPs, devices, and interfaces within the network. To do this:
NOTE: Users of type "user" can view only devices that are aligned with the same organization(s) to which the user is aligned. Users of type "administrator" can view all devices. Users of type "user" can view only interfaces that are aligned with the same organization(s) to which the user is aligned or have been emissaried to the user's organization(s). Users of type "administrator" can view all interfaces.
  1. Go to the IPv4 Networks page (Registry > Networks > IPv4 Networks).
  2. In the IPv4 Networks page, find the network you want to browse.
  3. Click the magnifying glass icon () for that network.
  4. The Network Browser page appears.
  5. In the drop-down menu in the upper left, you can choose to view all IP addresses in the network, all devices in the network, or all interfaces in the network.
Viewing Used and Unused IP Addresses in a Network
From the IPv4 Networks page, you can view a list of all IP addresses, used and unused, in a network. To do this:
  • Go to the IPv4 Networks page (Registry > Networks > IPv4 Networks).
  • In the IPv4 Networks page, find the network you want to view.
  • Click the magnifying glass icon () for that network.
  • The Network Browser page appears.
  • In the drop-down menu in the upper left, you can choose to view all IP addresses in the network, all devices in the network, or all interfaces in the network.
Viewing Devices Aligned with a Network
From the IPv4 Networks page, you can view a list of all devices in a network To do this:
  2. In the IPv4 Networks page, find the network you want to view.
  3. Click the devices icon () for that network.
  4. The Network Browser page appears and displays the list of devices in the network.
Viewing Interfaces Aligned with a Network
From the IPv4 Networks page, you can view a list of all interfaces in a network To do this:
  3. Click the interface icon () for that network.
  4. The Network Browser page appears and displays the list of interface in the network.
Generating a Report for a Network
To generate a report for a network:
  2. In the IPv4 Networks page, find the network for which you want to view a map.
  3. Click the printer icon () for that network.
  4. The Report Creator modal page appears. In this page, you can specify information to include in the report and the format in which to generate the report.
Defining a New Network
In the IPv4 Networks page, you can manually define a network. To do this:
  2. In the IPv4 Networks page, click the Actions button and select Create.
  3. The Network Properties modal page appears.
  4. In the Network Properties modal page, supply values in the following fields:
  • Network. IP address of the entire network (first IP). This field is read-only.
  • Description. Description of the new network. This field is read-only.
  • Subnet Mask. The subnet mask for the network, in use standard dotted-decimal format and the number of bits used for the network address.
  • Organization. Select from the drop-down list. The drop-down contains a list of all organizations in Skylar One.
  • Network Type. Description of the network type. Choices are:
  • ARIN Registered Public
  • Private Admin Network
  • Private Backup Network
  • Private NAT to ARIN Public
  • Provider Leased Public
  • Network Usage. Description of how the network will be used. The entries in this drop-down can be edited in the Select Objects Editor page (System > Customize > Selected Objects). The default values are:
  • DHCP Block
  • DNS Servers
  • Email/Messaging Servers
  • File Server
  • Firewalls
  • Printers
  • Web Servers
  1. Click the Save button to save the new network.
Merging One or More Networks
From the IPv4 Networks page, you can merge two or more networks. To merge networks, select a network to merge into and then select networks to add to the "merge into" network. When you merge networks, all devices in each selected network will become part of the "merge into" network. In the future, Skylar One will automatically move any devices from the selected networks to the "merge into" network.
To merge networks:
  2. In the IPv4 Networks page, click the Actions button and select Merge.
  3. The IPv4 Network Merge modal page appears.
  4. In the IPv4 Network Merge modal page, supply a value in the following fields:
  • Available Networks. Select one or more networks that you want to merge. Use the arrow button >> to add each network to the list of Networks to Merge.
  • Select network to merge into. From the list of networks in the Networks to Merge list, you must select one network to be the "merge into" network. The other networks in the Networks to Merge list will be added to the "merge into" network.
  1. Click the Merge button to save the newly merged network.
Synchronizing One or More Networks
When you synchronize a network, you remove any duplicate IPs from the network. The synchronize tool will remove only duplicate IPs from a single subnet where all the devices use the same Data Collector or Collector Group. To remove duplicate IPs:
  2. In the IPv4 Networks page, click the Actions button and select Synchronize.
  3. Text appears in the upper left of the page detailing how many networks were searched and how many addresses were synchronized.
Editing a Network's Properties
In the IPv4 Networks page, you can edit the basic properties of a network. To do this:
  1. In the IPv4 Networks page, find the network you want to edit.
  2. Click the wrench icon () for that network. The Network Properties modal page appears.
  3. In the Network Properties modal page, you can edit the values for one or more parameters.
  4. To save your changes to the network, click the Save button.
Performing Dynamic Discovery for a Network
You can perform dynamic discovery for a selected network. Skylar One will then use Dynamic Applications to retrieve information about each device and application in the network. To manually trigger dynamic discovery for a network:
  2. In the IPv4 Networks page, find the network for which you want to perform dynamic discovery. Click the lightning bolt icon () for that network.
  3. The Discovery Control Panel page appears, with the field IP Address Discovery List already populated with the IP range from the selected network.
Creating a Ticket About a Network
From the IPv4 Networks page, you can create a ticket about a network (the ticket's element will be the selected network). To do this:
  2. In the IPv4 Networks page, find the network for which you want to create a ticket.
  3. Click the ticket icon () for that network.
  4. The Ticket Editor page appears.
  5. To create a ticket, supply a value in each field. Click the Save button to save the new ticket.
Deleting One or More IPv4 Networks
You can delete one or more networks from the IPv4 Networks page. When you delete a network, the devices and interfaces associated with the network still remain in Skylar One and are unchanged. When you delete a network from the IPv4 Networks page, only the information in the IPv4 Networks page and related pages is deleted; the network itself and the devices and interfaces are not affected.
To delete one or more networks from the IPv4 Networks page:
  1. In the IPv4 Networks page, find the network you want to delete from the page.
  2. Select the checkbox for the network.
  3. Repeat steps 2-3 for each network you want to delete.
  4. From the Select Action field (in the lower right), choose Delete Monitors. Click the Go button.
  5. Each selected network will be deleted from the IPv4 Networks page.
