The "ELK: AWS CloudTrail" PowerPack is meant to be used in conjunction with the "Amazon Web Services" PowerPack. For more information about the "Amazon Web Services" PowerPack, including how to install the PowerPack and discover AWS devices, see
What is an AWS ELK Stack?
An ELK stack is a centralized log management platform consisting of three open-source products:
- Elasticsearch, a storage solution with search and indexing capabilities
- Logstash, a server-side data collection engine
- Kibana, a web user interface used for visualizing stored data
In an ELK stack, Logstash collects data, Elasticsearch indexes and stores the data, and Kibana visually presents the data in a user-friendly manner.
You can install an ELK stack on an Amazon Web Services instance to collect, store, and visualize data about that instance.
What Does the ELK: AWS CloudTrail PowerPack Monitor?
The "ELK: AWS CloudTrail" PowerPack includes the following features:
- A sample credential that you can use to create Basic/Snippet credentials to monitor AWS component devices in ELK stacks
- Dynamic Applications that align to AWS component devices in ELK stacks and then monitor CloudTrail logs and states changes on EC2 instances
- An event policy that notifies users when the ELK Dynamic Applications have aligned to AWS components
- Run book policies and actions that align the ELK Dynamic Applications to AWS components and update the alignment status on the ScienceLogic Data Collector or All-In-One Appliance
Installing the ELK: AWS CloudTrail PowerPack
