Introduction
The following sections provide an overview of Cisco ACI Multi-Site Manager and the "Cisco: ACI Multi-Site ManagerPowerPack:
What Does the Cisco: ACI Multi-Site Manager PowerPack Monitor?
To monitor Cisco ACI Multi-Site architectures using SL1, you must install the "Cisco: ACI Multi-Site Manager" PowerPack. This PowerPack enables you to discover, model, and collect data about Cisco ACI Multi-Site architectures.
The "Cisco: ACI Multi-Site Manager" PowerPack includes:
  • A sample credential you can use as a template to create a SOAP/XML credential to connect to the Cisco ACI Multi-Site architecture you want to monitor
  • Dynamic Applications to discover, model, and monitor performance metrics and/or collect configuration data
  • Device Classes for each type of ACI Multi-Site Manager device monitored
  • Event Policies and corresponding alerts that are triggered when ACI Multi-Site Manager devices meet certain status criteria
Installing the Cisco: ACI Multi-Site Manager PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Cisco: ACI Multi-Site Manager" PowerPack.
