What is Cisco AppDynamics?
Cisco AppDynamics is a real-time data platform for application and business performance monitoring. AppDynamics enables users to monitor applications at the code level to help them better understand their users' experience while also providing a real-time view of their applications' performance.
What Does the Cisco: AppDynamics PowerPack Monitor?
The "Cisco: AppDynamics" PowerPack enables you to monitor configuration and performance metrics for AppDynamics applications, tiers, and nodes. The PowerPack includes the following features:
- Dynamic Applications that discover and monitor AppDynamics devices
- Device Classes for each type of AppDynamics component device that the "Cisco: AppDynamics" PowerPack can monitor
- Event Policies and corresponding alerts that are triggered when AppDynamics devices meet certain status criteria
- Samples of SOAP/XML Credentials for discovering AppDynamics devices
- Run Book Actions and Policies that automatically create AppDynamics Application virtual devices
- A device template that is used to align the PowerPack's Dynamic Applications to AppDynamics Application virtual devices
ScienceLogic recommends running the latest version of the AppDynamics Agent when monitoring Cisco AppDynamics applications in Skylar One.
Installing the Cisco: AppDynamics PowerPack
