What is Cisco Unified Communications Manager?
Cisco Unified Communications Manager, also known as CallManager, is a unified call control and communications platform that provides services such as session management, voice, video, messaging, mobility, and web conferencing. Multiple CallManager servers can be grouped together into a cluster, which enables the CallManagers to share resources and features for better system scalability.
What Does the Cisco: CUCM Unified Communications Manager PowerPack Monitor?
To monitor Cisco Unified CM using Skylar One, you must install the "Cisco: CUCM Unified Communications Manager" PowerPack. This PowerPack enables you to discover, model, and collect data about your Cisco Unified CM system and clusters.
The "Cisco: CUCM Unified Communications Manager" PowerPack includes:
- An example credential you can use as a template to create a Basic/Snippet credential to connect to the Cisco Unified CM clusters you want to monitor
- Dynamic Applications to discover, model, and monitor performance metrics and collect configuration data for Cisco Unified CM clusters
- Device classes for each of the Cisco Unified CM clusters that Skylar One monitors
- Event policies and corresponding alerts that are triggered when Cisco Unified CM clusters meet certain status criteria
- Dashboards that display graphical information about Cisco Unified CM clusters
- Run book actions and automation policies that assign the Cisco Unified CM cluster root device to the appropriate device class, merge subscriber and physical component devices, and clear any unregistration events for a device when the same device is registered on another node in the cluster
The run book action that assigns the root device disables the Cisco Unified CM cluster root device's Auto-Update option.
Supported Versions
You can use this PowerPack to monitor versions 10.x, 11.x, 12.x and 14.x of Cisco Unified CM.
Installing the Cisco: CUCM Unified Communications Manager PowerPack
