What is Cisco Catalyst Center?
Cisco Catalyst Center is a network management and automation platform used for the management of Cisco Catalyst network infrastructure.
What Does the Cisco: Catalyst Center PowerPack Monitor?
The "Cisco: Catalyst Center" PowerPack enables you to discover and collect network data from the Cisco Catalyst Center's platform and its' infrastructure components.
The "Cisco: Catalyst Center" PowerPack includes:
- Dynamic Applications to discover, model, and monitor performance metrics and/or collect configuration data for Cisco Catalyst network infrastructure components:
- Cisco: Catalyst Center Applications
- Cisco: Catalyst Center Device Consumer Configuration
- Cisco: Catalyst Center Device Consumer Performance
- Cisco: Catalyst Center Devices Producer Performance
- Cisco: Catalyst Center Licenses Configuration
- Cisco: Catalyst CenterMembership Consumer Discovery
- Cisco: Catalyst Center Membership Producer Performance
- Cisco: Catalyst Center Nodes Configuration
- Cisco: Catalyst Center Release Summary
- Cisco: Catalyst Center Site Consumer Configuration
- Cisco: Catalyst Center Site Health Consumer Performance
- Cisco: Catalyst Center Site Health Producer Performance
- Cisco: Catalyst Center Sites Consumer Discovery
- Cisco: Catalyst Center Sites Producer Discovery
The "Cisco: Catalyst Center Applications" Dynamic Application is disabled by default. To enable it, go to the Dynamic Applications page (System > Manage > Dynamic Applications), click the wrench icon for this Dynamic Application, and select [Enabled] from the Operational State field.
- Cisco: Catalyst Center Tags Configuration
- Cisco: Catalyst Center Vlan
- Device classes for each type of Cisco Catalyst device that Skylar One monitors.
- A sample credential you can use as a template to connect to Cisco Catalyst Center network infrastructure components.
This PowerPack is compatible with Python 3.11.
Installing the Cisco: Catalyst Center PowerPack
