Introduction
This section describes how to monitor Cisco Email Security Appliances (ESA) in SL1 using the "Cisco: ESAPowerPack.
What is Cisco ESA?
Cisco Email Security Appliance (ESA) is a virtual, all-in-one appliance that provides protection against spam, malware, viruses, and other inbound and outbound email threats and annoyances.
What Does the Cisco: ESA PowerPack Monitor?
To monitor Cisco Email Security Appliances devices using SL1, you must install the "Cisco: ESAPowerPack. This PowerPack enables you to discover and collect data about Cisco Email Security Appliances.
The "Cisco: ESAPowerPack includes:
  • Dynamic Applications to discover and monitor performance and configuration data for Cisco ESA devices
  • Device classes for each of the Cisco ESA devices that SL1 monitors
  • Event policies that are triggered when Cisco ESA devices meet certain status criteria
  • A device dashboard that displays performance data about Cisco ESA devices
Installing the Cisco: ESA PowerPack
Before completing the steps in this section, you must import and install the latest version of the "Cisco: ESAPowerPack.
