NOTE: The "Cisco: Hyperflex" PowerPack supports only HyperFlex API version 4.5 and later.
What Does the Cisco: HyperFlex PowerPack Monitor?
To monitor HyperFlex data clusters using Skylar One, you must install the "Cisco: Hyperflex" PowerPack. This PowerPack enables you to discover, model, and collect data about HyperFlex data clusters.
The "Cisco: Hyperflex" PowerPack includes:
- An example credential you can use to create SOAP/XML credentials to connect to HyperFlex data clusters
- Dynamic Applications to discover and monitor HyperFlex data clusters
- A device class for HyperFlex data clusters
- Event policies and corresponding alerts that are triggered when HyperFlex data clusters meet certain status criteria
- A run book action and policy to ensure that HyperFlex devices are classified to the appropriate device class
Installing the Cisco: HyperFlex PowerPack
- Search for and download the PowerPack from the PowerPacks page on the ScienceLogic Support Site (Skylar One > PowerPacks).
