The following sections describe how to configure and discover Cisco Intersight devices for monitoring by Skylar One using the "Cisco: Intersight" PowerPack:
Prerequisites for Monitoring Cisco Intersight
To configure the Skylar One system to monitor Cisco Intersight devices using the "Cisco: Intersight" PowerPack, you must first have the following information about Cisco Intersight:
  • The username and password for your Cisco Intersight account.
  • A Cisco Intersight REST API key ID and Secret Key. See the Introduction to the Cisco Intersight REST API section of the Cisco Intersight documentation to view how to generate the REST API key ID and Secret Key.
Creating a "Universal" Type Credential for Cisco Intersight
To configure Skylar One to monitor Cisco Intersight devices, you must create a "universal" type credential. This credential allows the Dynamic Applications in the "Cisco: Intersight "PowerPack to communicate with Cisco Intersight.
To define a "universal" type credential to access Cisco Intersight:
  2. Click Create New and select Create Cisco Intersight Credential. The Create Credential modal page appears.
  • URL. Keep the default URL (https://www.intersight.com/api/) or type the URL of your account.
  • Authentication type. Keep the default value (IntersightHTTPKeyAuth).
  • Cisco Intersight API Key ID.Type your Cisco Intersight API key ID.
  • Cisco Intersight private PEM key. Type your Cisco Intersight secret API key. The PowerPack supports the OpenAPI schema version 3 (ECDSA) and version 2 (RSA).
Proxy Settings
Toggle on this field if you are using a proxy server to communicate with your Cisco Intersight account, enter the values in the fields listed below:
  • Proxy scheme type. Select http or https from the drop-down field.
  • Proxy Hostname/IP. Enter the hostname or the IP address associated with your device.
  1. CIick Save & Close.
Cisco Intersight Guided Discovery
You can use the Guided Discovery Framework process in Skylar Oneto guide you through a variety of existing discovery types in addition to traditional SNMP discovery. This process, which is also called "guided discovery", lets you choose a discovery type based on the type of devices you want to monitor. The Guided Discovery workflow includes a button for Cisco Intersight.
To run a Guided Discovery:
  2. Select the Cisco - Intersight button. Additional information about the requirements for device discovery appears in the General Information pane to the right.
  3. Guided Discovery process for Cisco Intersight
  1. On the Credential Selection page of the guided discovery process, select the Cisco Intersight "universal" type credential that you configured, and then click Next. The Root Device Details page appears.
  • Root Device Name. Type the name of the root device for the Cisco Intersight root device you want to monitor.
  1. Click Next. Skylar One creates the Cisco Intersight root device with the appropriate Device Class assigned to it and aligns the relevant Dynamic Applications. The Final Summary page appears.
  1. Click Close.
This PowerPack uses the snippet framework in order to function. Not all values returned in an API call in a Dynamic Application may have a collection object. For more information about how collections can be modified, added, or deleted using the snippet framework, see the Snippet Framework documentation.
Viewing Cisco Intersight Component Devices
In addition to the Devices page, you can view the Cisco Intersight system and all associated component devices in the following places in the user interface:
  • The Device Investigator Map page (click Map in the Device Investigator page) displays a map of a particular device and all of the devices with which it has parent-child relationships. Double-clicking any of the listed devices reloads the page to make the selected device the primary device
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with a Kubernetes cluster, find the cluster device and click its plus icon (+).
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. Skylar One also updates each map with the latest status and event information. To view the map for a Kubernetes cluster, go to Classic Maps > Device Maps > Components, and select the map from the list in the left NavBar. To learn more about the Component Map page, see the section on Views.
Monitoring Cisco Intersight Alarms
The "Cisco: Intersight" PowerPack includes the "Cisco: Intersight Alarms Performance" Dynamic Application to monitor Cisco Intersight alarms and associate the alarms with the appropriate component devices, if applicable. This Dynamic Application replaces the functions previously provided by the "Cisco: Intersight Alarms Configuration" Dynamic Application.
The "Cisco: Intersight Alarms Performance" Dynamic Application aligns to the organization device level and collects uncleared critical, warning, and information alarms from the associated device. A warning or critical severity raise events on the corresponding device for each alarm. Informational alarms are ignored by default to prevent triggering alerts, as there is no available event associated with it.
Filtering the Default Intersight Organization
In Intersight, each device can belong to both the default organization and another organization at the same time. For more information see Cisco Intersight's documentation. To avoid duplicate devices, the "Cisco: Intersight" PowerPack supports filtering out the default organization so that the default organization will not be discovered in a new discovery session.
If you want to discover the default organization with the devices that only belong to it, you need to edit the snippet code of the "Cisco: Intersight Organization Discovery" Dynamic Application.
To discover the default organization:
  2. Find the "Cisco: Intersight Organization Discovery" Dynamic Application. Click its wrench icon (). The Dynamic Applications Properties Editor modal appears.
  3. Click the Snippets tab, and then click Organization Discovery near the bottom of the Snippet Editor modal.
  4. In the snippet details, locate the custom_substitution line and set the value of the "default_organization_name" to an empty string. For example, "default_organization_name": "".
  5. Setting the default filter in the Snippet editor.
If you changed the default organization name in the Intersight portal, you must also update the default name in the snippet code of the following Dynamic Applications:
  • Cisco: Intersight Organization Discovery
  • Cisco: Intersight Blade Server Discovery
  • Cisco: Intersight Chassis Discovery
  • Cisco: Intersight Fabric Interconnect Discovery
  • Cisco: Intersight Rack Units Discovery
  • Cisco: Intersight Alarms Performance
