What is Cisco Intersight?
Cisco Intersight is a cloud operations platform allowing for advanced infrastructure, workload optimization, and Kubernetes services. Cisco Intersight infrastructure services include the deployment, monitoring, management, and support of physical and virtual infrastructure.
What Does the Cisco: Intersight PowerPack Monitor?
To monitor Cisco Intersight using Skylar One, you must install the "Cisco: Intersight" PowerPack. This PowerPack enables you to discover, model, and collect data about Cisco Intersight devices.
The "Cisco: Intersight" PowerPack includes:
- Dynamic Applications that enable Skylar One to discover, model, and monitor Cisco Intersight devices
- Event Policies that are triggered when Cisco Intersight devices meet certain status criteria
- Device Classes for each type of Cisco Intersight device monitored
- A universal credential type and a guided discovery workflow to discover Cisco Intersight devices
Installing the Cisco: Intersight PowerPack
