What Does the Cisco: UCS Director PowerPack Monitor?
The Dynamic Applications in the "Cisco: UCS Director" PowerPack can monitor performance metrics and/or collect configuration data for the following UCS Director components:
- ACI Applications
- ACI Tenants
- Application Containers
- Cloud Services
- Pods
- Servers
- Sites
Installing the Cisco: UCS Director PowerPack
Before completing the steps to this
