Discovery
The following sections describe the steps required to discover Cisco UC VOS devices in Skylar One:
Discovering VOS Application Clusters
To model and monitor your VOS applications, run a discovery session to discover the VOS application clusters that Skylar One will use as the root devices for monitoring the applications.
Several minutes after the discovery session has completed, the Dynamic Applications in the "Cisco: UC VOS ApplicationsPowerPack should automatically align to the cluster root devices and then discover, model, and monitor the remaining VOS application component devices.
Cisco Prime Collaboration Deployment (PCD) and Cisco SocialMiner do not support cluster deployment. However, to create component-level devices that can be monitored using the Dynamic Applications in the "Cisco: UC VOS ApplicationsPowerPack, the Skylar One system creates a virtual PCD cluster device or a virtual SocialMiner cluster in addition to the PCD or SocialMiner component-level devices during discovery.
To discover the VOS application clusters that you want to monitor, perform the following steps:
Image of the Discovery Session Editor page
  1. Click Select. The Basic Information page appears.
  1. Click Next. The Credential Selection page appears:
  1. On the Select Credentials page, locate and select the credential(s) you created for the device clusters.
  1. Click Next. The Discovery Session Details page appears:
  • List of IPs/Hostnames. Enter the IP address(es) and/or hostname(s) for all the nodes in the cluster you want to discover.
All VOS devices on a single ScienceLogic collector must have unique host names.
  3. Repeat the above steps for every set of device clusters you want to monitor, using a different credential for each set of devices.
Discovering VOS Application Clusters in the Skylar One Classic User Interface
  • IP Address/Hostname Discovery List. Enter the IP address(es) and/or hostname(s) for all the nodes in the cluster you want to discover.
  • SNMP Credentials. Select the SNMP credential you created for the device clusters.
  • Other Credentials. Select the Basic/Snippet and SOAP/XML credentials you created for the device clusters.
Viewing VOS Devices
When Skylar One discovers your VOS devices, Skylar One will create component devices that represent each component in your VOS device clusters.
Image of the Device View page
  • The Device Components page (Devices > Device Components) displays a list of all root devices and component devices discovered by Skylar One, in an indented view, so you can easily view the hierarchy and relationships between child devices, parent devices, and root devices. To view the component devices associated with your VOS device clusters, find a device cluster and click its plus icon (+):
Image of the Device Components page
  • The Component Map page (Classic Maps > Device Maps > Components) allows you to view devices by root node and view the relationships between root nodes, parent components, and child components in a map. This makes it easy to visualize and manage root nodes and their components. Skylar One automatically updates the Component Map as new component devices are discovered. The platform also updates each map with the latest status and event information. To view the map for your VOS device clusters, go to the Component Map page and select a map from the list in the left NavBar. To learn more about the Component Map page, see the section on Views.
